Digging into the Teensy Midi library's API put this loopback tester together. Code is based on the example in File>Examples>Teensy>USB_MIDI>TransmitEverything.
Running on a T3.5, USB Type MIDIx4, pressing the button a Midi message is sent concurrently on usbMIDI cable 0 and Serial 1 TX. Serial1 TX and RX are connected via 470 Ohm resistor. Callbacks are used to send looped messages via usbMIDI cable 1.
Here's its pic:-
Compiled, uploaded with IDE1.8.13 TD 1.53 on Win7 or 10 and monitored with MidiOx, however there is a subtle difference in the behavior depending on the OS.
Works as expected on Win 10, however first time through on Win 7, messages are seen on both cables until the first Sysex message is sent then no messages are seen on either cable until the button has been pressed another eighteen times and we see note On and Off messages. Thereafter, behavior is as expected.
The contents of void sendNextMessage() line 91 show us the differences between the MIDI and usbMIDI API details.
Here's a snip of a screen snapshot from MidiOx. In 7 = cable 0 and In 8 = cable 1.
And here's its code:-
WRT line 160, dunno if I've missed something obvious or what with Midi TimeCode, not needed to use it yet.
Here's its pic:-
A pushbutton (ordinary momentary type) needs to be connected
between pin 8 and GND. Serial1 TX and RX are connected with a
470R resistor.
You must select MIDIx4 from the "Tools > USB Type" menu
Each time a button is pressed, send another usbMIDI message
concurrently on the primaryCable and Serial1 TX.
Serial1 RX is decoded and re-sent on loopedCable.
This very long example demonstrates all possible usbMIDI
and Serial Midi message send functions. It's mostly meant
for testing and as a reference to easily copy-and-paste
the code for every message send function.
#include <MIDI.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
#include <Bounce.h>
// the MIDI channel number to send messages
const int channel = 1;
// the MIDI virtual cable to use
int primaryCable = 0;
int loopedCable = 1;
// Create a Bounce object for the button.
const int pin = 47;
Bounce button1 = Bounce(pin, 10);
// remember when a note-on message has been sent
int note = 0;
// which message will we do next
int state = 0;
// sysex message to send
uint8_t buf[] = {0xF0, 6, 24, 64, 5, 1, 0xF7};
pinMode(pin, INPUT_PULLUP);
MIDI.begin();
MIDI.turnThruOff();// To prevent Midi feedback
MIDI.setHandleNoteOff(myNoteOff);
MIDI.setHandleNoteOn(myNoteOn);
MIDI.setHandleAfterTouchPoly(myAfterTouchPoly);
MIDI.setHandleControlChange(myControlChange);
MIDI.setHandleProgramChange(myProgramChange);
MIDI.setHandleAfterTouchChannel(myAfterTouchChannel);
MIDI.setHandlePitchBend(myPitchBend);
MIDI.setHandleSystemExclusive(mySystemExclusive);
MIDI.setHandleClock(myClock);
MIDI.setHandleStart(myStart);
MIDI.setHandleContinue(myContinue);
MIDI.setHandleStop(myStop);
MIDI.setHandleActiveSensing(myActiveSensing);
MIDI.setHandleSystemReset(mySystemReset);
MIDI.setHandleTimeCodeQuarterFrame(myTimeCodeQuarterFrame);
MIDI.setHandleTuneRequest(myTuneRequest);
MIDI.setHandleSongPosition(mySongPosition);
MIDI.setHandleSongSelect(mySongSelect);
while (MIDI.read()) {
// controllers must call .read() to keep the queue clear even if they are not responding to MIDI
while (usbMIDI.read()) {
// ignore incoming messages
button1.update();
if (button1.fallingEdge()) {
// when the button is pressed, send another message
sendNextMessage();
if (button1.risingEdge()) {
// when the button is release, send note off if we left a note on
if (note > 0) {
usbMIDI.sendNoteOff(note, 0, channel, primaryCable);
MIDI.sendNoteOff(note, 0, channel);
note = 0;
void sendNextMessage() {
switch (state) {
case 0:
note = analogRead(A0) / 8;
if (note == 0) note = 1;
usbMIDI.sendNoteOn(note, 99, channel, primaryCable);
MIDI.sendNoteOn(note, 99, channel);
case 1:
usbMIDI.sendAfterTouchPoly(65, 110, channel, primaryCable);
MIDI.sendAfterTouch(65, 110, channel);
case 2:
usbMIDI.sendControlChange(7, 100, channel, primaryCable);
MIDI.sendControlChange(7, 100, channel);
case 3:
usbMIDI.sendProgramChange(2, channel, primaryCable);
MIDI.sendProgramChange(2, channel);
case 4:
usbMIDI.sendAfterTouch(108, channel, primaryCable);
MIDI.sendAfterTouch(108, channel);
case 5:
usbMIDI.sendPitchBend(911, channel, primaryCable);
MIDI.sendPitchBend(911, channel);
case 6:
usbMIDI.sendSysEx(sizeof(buf), buf, true, primaryCable);
MIDI.sendSysEx(sizeof(buf), buf, true);
case 7:
usbMIDI.sendSysEx(sizeof(buf) - 2, buf + 1, false, primaryCable);
MIDI.sendSysEx(sizeof(buf) - 2, buf + 1, false);
case 8:
usbMIDI.sendRealTime(usbMIDI.Clock, primaryCable);
MIDI.sendClock();
case 9:
usbMIDI.sendRealTime(usbMIDI.Start, primaryCable);
MIDI.sendStart();
case 10:
usbMIDI.sendRealTime(usbMIDI.Continue, primaryCable);
MIDI.sendContinue();
case 11:
usbMIDI.sendRealTime(usbMIDI.Stop, primaryCable);
MIDI.sendStop();
case 12:
usbMIDI.sendRealTime(usbMIDI.ActiveSensing, primaryCable);
MIDI.sendActiveSensing();
case 13:
usbMIDI.sendRealTime(usbMIDI.SystemReset, primaryCable);
MIDI.sendSystemReset();
case 14:
usbMIDI.sendTimeCodeQuarterFrame(0, 3, primaryCable);
usbMIDI.sendTimeCodeQuarterFrame(1, 1, primaryCable);
usbMIDI.sendTimeCodeQuarterFrame(2, 7, primaryCable);
usbMIDI.sendTimeCodeQuarterFrame(3, 4, primaryCable);
usbMIDI.sendTimeCodeQuarterFrame(4, 1, primaryCable);
usbMIDI.sendTimeCodeQuarterFrame(5, 1, primaryCable);
usbMIDI.sendTimeCodeQuarterFrame(6, 0, primaryCable);
usbMIDI.sendTimeCodeQuarterFrame(7, 0, primaryCable);
Commented out as these messages are actually sent
on usbMIDI primaryCable
MIDI.sendTimeCodeQuarterFrame(0, 3);
MIDI.sendTimeCodeQuarterFrame(1, 1);
MIDI.sendTimeCodeQuarterFrame(2, 7);
MIDI.sendTimeCodeQuarterFrame(3, 4);
MIDI.sendTimeCodeQuarterFrame(4, 1);
MIDI.sendTimeCodeQuarterFrame(5, 1);
MIDI.sendTimeCodeQuarterFrame(6, 0);
MIDI.sendTimeCodeQuarterFrame(7, 0);
case 15:
usbMIDI.sendTuneRequest(primaryCable);
MIDI.sendTuneRequest();
case 16:
usbMIDI.sendSongPosition(2531, primaryCable);
MIDI.sendSongPosition(2531);
case 17:
usbMIDI.sendSongSelect(107, primaryCable);
MIDI.sendSongSelect(107);
case 18:
usbMIDI.beginRpn(1, channel, primaryCable);
usbMIDI.sendRpnValue(6489, channel, primaryCable);
usbMIDI.endRpn(channel, primaryCable);
MIDI.beginRpn(1, channel);
MIDI.sendRpnValue(6489, channel);
MIDI.endRpn(channel);
case 19:
usbMIDI.sendRpnIncrement(14, channel, primaryCable);
MIDI.sendRpnIncrement(14, channel);
case 20:
usbMIDI.sendRpnDecrement(9, channel, primaryCable);
MIDI.sendRpnDecrement(9, channel);
case 21:
usbMIDI.beginNrpn(417, channel, primaryCable);
MIDI.beginNrpn(417, channel);
case 22:
usbMIDI.sendRpnIncrement(3, channel, primaryCable);
MIDI.sendRpnIncrement(3, channel);
case 23:
usbMIDI.sendRpnDecrement(2, channel, primaryCable);
MIDI.sendRpnDecrement(2, channel);
state = state + 1;
if (state > 23) state = 0;
//******************* Handlers **************************************
void myNoteOff(byte channel, byte note, byte velocity) {
usbMIDI.sendNoteOff(note, velocity, channel, loopedCable);
void myNoteOn(byte channel, byte note, byte velocity) {
usbMIDI.sendNoteOn(note, velocity, channel, loopedCable);
void myAfterTouchPoly(byte channel, byte note, byte velocity) {
usbMIDI.sendAfterTouchPoly(note, velocity, channel, loopedCable);
void myControlChange(byte channel, byte control, byte value) {
usbMIDI.sendControlChange(control, value, channel, loopedCable);
void myProgramChange(byte channel, byte program) {
usbMIDI.sendProgramChange(program, channel, loopedCable);
void myAfterTouchChannel(byte channel, byte pressure) {
usbMIDI.sendAfterTouch(pressure, channel, loopedCable);
void myPitchBend(byte channel, int pitch) {
usbMIDI.sendPitchBend(pitch, channel, loopedCable);
void mySystemExclusive(const byte *data, uint16_t length) {
usbMIDI.sendSysEx( length, data, true, loopedCable);
void myClock() {
usbMIDI.sendRealTime(usbMIDI.Clock, loopedCable);
void myStart() {
usbMIDI.sendRealTime(usbMIDI.Start, loopedCable);
void myContinue() {
usbMIDI.sendRealTime(usbMIDI.Continue, loopedCable);
void myStop() {
usbMIDI.sendRealTime(usbMIDI.Stop, loopedCable);
void myActiveSensing() {
usbMIDI.sendRealTime(usbMIDI.ActiveSensing, loopedCable);
void mySystemReset() {
usbMIDI.sendRealTime(usbMIDI.SystemReset, loopedCable);
void myTimeCodeQuarterFrame(byte data) {
usbMIDI.sendTimeCodeQuarterFrame(data, loopedCable);
void myTuneRequest() {
usbMIDI.sendTuneRequest(loopedCable);
// needed unsigned to remove compiler warning
void mySongPosition(unsigned beats) {
usbMIDI.sendSongPosition(beats, loopedCable);
void mySongSelect(byte songNumber) {
usbMIDI.sendSongSelect(songNumber, loopedCable);
