Serial Monitor will not read temperature or barometric pressure. Altitude reads 44380 m.
BMP280 VIN==> Teensy 3.3V
BMP280 BND==> Teensy GND
BMP280 SDI==> Teensy 18 (A4)
BMP280 SCK==> Teensy 19 (A5)
I am using the following code:
/* Arduino Tutorial - Testing the Adafruits BMP280 Presure & Temperature Sensor
I2C Connection: Vin: 5V/3V, GND: GND, SCK: A5 (SCL), SDI: A4 (SDA)
Dev: Michalis Vasilakis // Date: 8/3/206 // Info: www.ardumotive.com */
#include "SPI.h" //Why? Because library supports SPI and I2C connection
#include <Adafruit_Sensor.h>
#include "Adafruit_BMP280.h"
//Setup connection of the sensor
Adafruit_BMP280 bmp; // I2C
/*//For SPI connection!
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 11
#define BMP_CS 10
//Adafruit_BMP280 bme(BMP_CS); // hardware SPI
//Adafruit_BMP280 bme(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
//Variables
float pressure; //To store the barometric pressure (Pa)
float temperature; //To store the temperature (oC)
int altimeter; //To store the altimeter (m) (you can also use it as a float variable)
bmp.begin(); //Begin the sensor
Serial.begin(9600); //Begin serial communication at 9600bps
Serial.println("Adafruit BMP280 test:");
//Read values from the sensor:
pressure = bmp.readPressure();
temperature = bmp.readTemperature();
altimeter = bmp.readAltitude (1050.35); //Change the "1050.35" to your city current barrometric pressure (https://www.wunderground.com)
//Print values to serial monitor:
Serial.print(F("Pressure: "));
Serial.print(pressure);
Serial.print(" Pa");
Serial.print("\t");
Serial.print(("Temp: "));
Serial.print(temperature);
Serial.print(" oC");
Serial.print("\t");
Serial.print("Altimeter: ");
Serial.print(altimeter); // this should be adjusted to your local forcase
Serial.println(" m");
delay(2000);
TIA
NealA
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 11
#define BMP_CS 10
//Variables
Serial.print("\t");
Serial.print("\t");
delay(2000);
TIA
NealA
