Results 1 to 9 of 9
Thread: OPEN SOURCE BOUNTY: volumeInput(); similar to volume();
    Jun 2018
    USA
    186
    I'm offering a $300 reward to anyone who will successfully provide/commit a patch to the audio library so that I can call volumeInput(); and receive the volume level from windows (and I guess any other OS that follows the USB spec). This is similar to the volume(); call that currently exists but for the input level. If you figure this out I'd bet its a total of 3 lines of code.
    Additional details on this bounty is discussed here:
    https://forum.pjrc.com/threads/55669...l=1#post249074
    Please let me know if anyone is interested!
    Jay
    9,053
    I may be completely wrong here:
    I took a look at this earlier this evening.
    The volume control is done by means of a "Feature Unit Audio Class Descriptor".
    The problem is, this is only valid for so-called "Input Terminal"s. This is what the "Input Terminal Audio Class Descriptor" is for. However, this describes the direction Host->Device, and not vice versa.
    So I don't think what you want is possible.
    I just looked at this for the very first time and I may be wrong!?! In this case I would like to know how to do it.
    There are mixers described etc. Perhaps it's possible with these?
    USB is complicated...
    A document that may be useful:
    https://www.silabs.com/documents/pub...otes/AN295.pdf
    24,759
    If anyone works on this, we please also consider what sort of numerical range is normally used by "typical" USB audio devices.
    Linux prints a warning (syslog message) about the range we have now....
    9,053
    Yup, "Warning! Unlikely big volume range (=4095), cval->res is probably wrong."
    Tried different values, the biggest allowed seems to be 255. I'll make a pullrequest..
    https://github.com/PaulStoffregen/co...diff=split&w=1
    Jun 2018
    USA
    186
    Hello Frank B,
    Thanks for your time.
    This image shows the microphone and calls it an Input Terminal (IT).
    PaulS pointed this out before, and provided the link to this document section 4.7.2.4.
    Universal Serial Bus Device Class Definition for Audio Devices Release 2.0
    Jay
    Jun 2018
    USA
    186
    There is a utility called Thesycon USB Descriptor Dumper which might help us figure out what descriptors are common among soundcards. This might help us.
    Here is a dump from the popular Cmedia CM6206-LX USB Audio Chip.
    Information for device USB Sound Device         (VID=0x0D8C PID=0x0102):
    Connection Information:
    Device current bus speed: FullSpeed
    Device supports USB 1.1 specification
    Device supports USB 2.0 specification
    Device address: 0x0002
    Current configuration value: 0x01
    Number of open pipes: 1
    Device Descriptor:
    0x12	bLength
    0x01	bDescriptorType
    0x0110	bcdUSB
    0x00	bDeviceClass
    0x00	bDeviceSubClass
    0x00	bDeviceProtocol
    0x08	bMaxPacketSize0   (8 bytes)
    0x0D8C	idVendor
    0x0102	idProduct
    0x0010	bcdDevice
    0x00	iManufacturer
    0x02	iProduct
    0x00	iSerialNumber
    0x01	bNumConfigurations
    Configuration Descriptor:
    0x09	bLength
    0x02	bDescriptorType
    0x0216	wTotalLength   (534 bytes)
    0x04	bNumInterfaces
    0x01	bConfigurationValue
    0x00	iConfiguration
    0x80	bmAttributes   (Bus-powered Device)
    0xFA	bMaxPower      (500 mA)
    Interface Descriptor:
    0x09	bLength
    0x04	bDescriptorType
    0x00	bInterfaceNumber
    0x00	bAlternateSetting
    0x00	bNumEndPoints
    0x01	bInterfaceClass      (Audio Device Class)
    0x01	bInterfaceSubClass   (Audio Control Interface)
    0x00	bInterfaceProtocol   (Audio Protocol undefined)
    0x00	iInterface
    AC Interface Header Descriptor:
    0x0A	bLength
    0x24	bDescriptorType
    0x01	bDescriptorSubtype
    0x0100	bcdADC
    0x00C8	wTotalLength   (200 bytes)
    0x02	bInCollection
    0x01	baInterfaceNr(1)
    0x02	baInterfaceNr(2)
    AC Input Terminal Descriptor:
    0x0C	bLength
    0x02	bDescriptorSubtype
    0x01	bTerminalID
    0x0101	wTerminalType   (USB Streaming)
    0x00	bAssocTerminal
    0x08	bNrChannels   (8 channels)
    0x063F	wChannelConfig
    0x00	iChannelNames
    0x00	iTerminal
    0x0C	bLength
    0x04	bTerminalID
    0x0201	wTerminalType   (Microphone)
    0x00	bAssocTerminal
    0x02	bNrChannels   (2 channels)
    0x0003	wChannelConfig
    0x00	iChannelNames
    0x00	iTerminal
    AC Feature Unit Descriptor:
    0x0A	bLength
    0x06	bDescriptorSubtype
    0x08	bUnitID
    0x04	bSourceID
    0x01	bControlSize
    bmaControls:
     0x01	Channel(0) - Mute
     0x02	Channel(1) - Volume
     0x02	Channel(2) - Volume
    0x00	iFeature
    0x0A	bLength
    0x09	bUnitID
    0x04	bSourceID
    0x01	bControlSize
    bmaControls:
    0x00	iFeature
    AC Mixer Unit Descriptor:
    0x19	bLength
    0x04	bDescriptorSubtype
    0x0C	bUnitID
    0x03	bBrInPins
    0x01	baSourceID(1)
    0x09	baSourceID(2)
    0x0B	baSourceID(3)
    0x08	bNrChannels
    0x00	iChannelNames
    bmControls:
    0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    0x00 0x00
    0x00	iMixer
    0x10	bLength
    0x0D	bUnitID
    0x0C	bSourceID
    0x01	bControlSize
    bmaControls:
     0x02	Channel(3) - Volume
     0x02	Channel(4) - Volume
     0x02	Channel(5) - Volume
     0x02	Channel(6) - Volume
     0x02	Channel(7) - Volume
     0x02	Channel(8) - Volume
    0x00	iFeature
    AC Output Terminal Descriptor:
    0x09	bLength
    0x03	bDescriptorSubtype
    0x03	bTerminalID
    0x0301	wTerminalType   (Speaker)
    0x00	bAssocTerminal
    0x0D	bSourceID
    0x00	iTerminal
    0x0D	bLength
    0x11	bUnitID
    0x02	bBrInPins
    0x09	baSourceID(1)
    0x0B	baSourceID(2)
    0x02	bNrChannels
    0x00	iChannelNames
    bmControls:
    0x00
    0x00	iMixer
    0x09	bLength
    0x0A	bTerminalID
    0x00	bAssocTerminal
    0x07	bSourceID
    0x00	iTerminal
    AC Selector Unit Descriptor:
    0x0A	bLength
    0x05	bDescriptorSubtype
    0x07	bUnitID
    0x04	bBrInPins
    0x08	baSourceID(1)
    0x0F	baSourceID(2)
    0x10	baSourceID(3)
    0x02	baSourceID(4)
    0x00	iSelector
    0x0C	bLength
    0x06	bTerminalID
    0x0603	wTerminalType   (Line connector)
    0x00	bAssocTerminal
    0x00	iChannelNames
    0x00	iTerminal
    0x0A	bLength
    0x0F	bUnitID
    0x06	bSourceID
    0x01	bControlSize
    bmaControls:
    0x00	iFeature
    0x0A	bLength
    0x0B	bUnitID
    0x06	bSourceID
    0x01	bControlSize
    bmaControls:
    0x00	iFeature
    0x0C	bLength
    0x05	bTerminalID
    0x0605	wTerminalType   (S/PDIF interface)
    0x00	bAssocTerminal
    0x00	iChannelNames
    0x00	iTerminal
    0x0A	bLength
    0x02	bUnitID
    0x11	bSourceID
    0x01	bControlSize
    bmaControls:
    0x00	iFeature
    0x0A	bLength
    0x10	bUnitID
    0x05	bSourceID
    0x01	bControlSize
    bmaControls:
     0x00	Channel(1)
     0x00	Channel(2)
    0x00	iFeature
    0x09	bLength
    0x01	bInterfaceNumber
    0x00	bNumEndPoints
    0x02	bInterfaceSubClass   (Audio Streaming Interface)
    0x00	iInterface
    0x09	bLength
    0x01	bAlternateSetting
    0x01	bNumEndPoints
    0x00	iInterface
    AS Interface Descriptor:
    0x07	bLength
    0x01	bTerminalLink
    0x01	bDelay
    0x0001	wFormatTag   (PCM)
    AS Format Type 1 Descriptor:
    0x0E	bLength
    0x01	bFormatType   (FORMAT_TYPE_1)
    0x02	bSubframeSize
    0x10	bBitResolution   (16 bits per sample)
    0x02	bSamFreqType   (Discrete sampling frequencies)
    0x00AC44 	tSamFreq(1)   (44100 Hz)
    0x00BB80 	tSamFreq(2)   (48000 Hz)
    Endpoint Descriptor (Audio/MIDI 1.0):
    0x09	bLength
    0x05	bDescriptorType
    0x06	bEndpointAddress  (OUT endpoint 6)
    0x09	bmAttributes      (Transfer: Isochronous / Synch: Adaptive / Usage: Data)
    0x0310	wMaxPacketSize    (1 x 784 bytes)
    0x01	bInterval         (1 frames)
    0x00	bRefresh
    0x00	bSynchAddress
    AS Isochronous Data Endpoint Descriptor:
    0x07	bLength
    0x25	bDescriptorType
    0x01	bmAttributes   (Sampling Frequency)
    0x00	bLockDelayUnits   (undefined)
    0x0000	wLockDelay
    0x09	bLength
    0x02	bAlternateSetting
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x01	bTerminalLink
    0x01	bDelay
    0x0E	bLength
    0x02	bSubframeSize
    0x09	bLength
    0x00C4	wMaxPacketSize    (1 x 196 bytes)
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x0000	wLockDelay
    0x09	bLength
    0x03	bAlternateSetting
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x01	bTerminalLink
    0x01	bDelay
    0x0E	bLength
    0x04	bNrChannels   (4 channels)
    0x02	bSubframeSize
    0x09	bLength
    0x0188	wMaxPacketSize    (1 x 392 bytes)
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x0000	wLockDelay
    0x09	bLength
    0x04	bAlternateSetting
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x01	bTerminalLink
    0x01	bDelay
    0x0E	bLength
    0x06	bNrChannels   (6 channels)
    0x02	bSubframeSize
    0x09	bLength
    0x0248	wMaxPacketSize    (1 x 584 bytes)
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x0000	wLockDelay
    0x09	bLength
    0x05	bAlternateSetting
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x01	bTerminalLink
    0x01	bDelay
    0x0B	bLength
    0x02	bSubframeSize
    0x01	bSamFreqType   (Discrete sampling frequencies)
    0x00BB80 	tSamFreq(1)   (48000 Hz)
    0x09	bLength
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x0000	wLockDelay
    0x09	bLength
    0x02	bInterfaceNumber
    0x00	bNumEndPoints
    0x00	iInterface
    0x09	bLength
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x0A	bTerminalLink
    0x01	bDelay
    0x0E	bLength
    0x02	bSubframeSize
    0x09	bLength
    0x85	bEndpointAddress  (IN endpoint 5)
    0x05	bmAttributes      (Transfer: Isochronous / Synch: Asynchronous / Usage: Data)
    0x00C8	wMaxPacketSize    (1 x 200 bytes)
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x0000	wLockDelay
    0x09	bLength
    0x03	bInterfaceNumber
    0x01	bNumEndPoints
    0x03	bInterfaceClass      (Human Interface Device Class)
    0x00	bInterfaceSubClass
    0x00	iInterface
    HID Descriptor:
    0x09	bLength
    0x21	bDescriptorType
    0x0100	bcdHID
    0x00	bCountryCode
    0x01	bNumDescriptors
    0x22	bDescriptorType   (Report descriptor)
    0x0032	bDescriptorLength
    0x07	bLength
    0x81	bEndpointAddress  (IN endpoint 1)
    0x03	bmAttributes      (Transfer: Interrupt / Synch: None / Usage: Data)
    0x0003	wMaxPacketSize    (1 x 3 bytes)
    Microsoft OS Descriptor is not available. Error code: 0x0000001F
    String Descriptor Table
    Index  LANGID  String
    0x00   0x0000
    0x02   0x0000  "USB Sound Device        "
    Connection path for device:
    USB xHCI Compliant Host Controller
    Root Hub
    USB Sound Device         (VID=0x0D8C PID=0x0102) Port: 2
    Running on: Windows 10 or greater (Build Version 19041)
    Brought to you by TDD v2.15.0, Jun  8 2020, 17:18:07
    Here is a dump from the CM119 audio chip.
    Information for device C-Media USB Audio Device    (VID=0x0D8C PID=0x0008):
    Device address: 0x0004
    Device Descriptor:
    0x12	bLength
    0x0110	bcdUSB
    0x00	bDeviceClass
    0x40	bMaxPacketSize0   (64 bytes)
    0x0D8C	idVendor
    0x0008	idProduct
    0x0100	bcdDevice
    0x00	iManufacturer
    0x01	iProduct        "C-Media USB Audio Device   "
    0x00	iSerialNumber
    0x09	bLength
    0x00FD	wTotalLength   (253 bytes)
    0x04	bNumInterfaces
    0x00	iConfiguration
    0xA0	bmAttributes   (Bus-powered Device, Remote-Wakeup)
    0x32	bMaxPower      (100 mA)
    0x09	bLength
    0x00	bNumEndPoints
    0x00	iInterface
    0x0A	bLength
    0x0100	bcdADC
    0x0064	wTotalLength   (100 bytes)
    0x02	bInCollection
    0x0C	bLength
    0x01	bTerminalID
    0x00	bAssocTerminal
    0x00	iChannelNames
    0x00	iTerminal
    0x0C	bLength
    0x02	bTerminalID
    0x00	bAssocTerminal
    0x01	bNrChannels   (1 channels)
    0x0001	wChannelConfig
    0x00	iChannelNames
    0x00	iTerminal
    0x09	bLength
    0x06	bTerminalID
    0x00	bAssocTerminal
    0x09	bSourceID
    0x00	iTerminal
    0x09	bLength
    0x07	bTerminalID
    0x00	bAssocTerminal
    0x08	bSourceID
    0x00	iTerminal
    0x07	bLength
    0x08	bUnitID
    0x01	bBrInPins
    0x0A	baSourceID(1)
    0x00	iSelector
    0x0A	bLength
    0x09	bUnitID
    0x0F	bSourceID
    0x01	bControlSize
    bmaControls:
    0x00	iFeature
    0x09	bLength
    0x0A	bUnitID
    0x02	bSourceID
    0x01	bControlSize
    bmaControls:
     0x43	Channel(0) - Mute / Volume / Automatic Gain
     0x00	Channel(1)
    0x00	iFeature
    0x09	bLength
    0x0D	bUnitID
    0x02	bSourceID
    0x01	bControlSize
    bmaControls:
     0x03	Channel(0) - Mute / Volume
     0x00	Channel(1)
    0x00	iFeature
    0x0D	bLength
    0x0F	bUnitID
    0x02	bBrInPins
    0x01	baSourceID(1)
    0x0D	baSourceID(2)
    0x02	bNrChannels
    0x00	iChannelNames
    bmControls:
    0x00
    0x00	iMixer
    0x09	bLength
    0x00	bNumEndPoints
    0x00	iInterface
    0x09	bLength
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x01	bTerminalLink
    0x01	bDelay
    0x0E	bLength
    0x02	bSubframeSize
    0x00AC44 	tSamFreq(2)   (44100 Hz)
    0x09	bLength
    0x01	bEndpointAddress  (OUT endpoint 1)
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x01	bLockDelayUnits   (milliseconds)
    0x0001	wLockDelay
    0x09	bLength
    0x00	bNumEndPoints
    0x00	iInterface
    0x09	bLength
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x07	bTerminalLink
    0x01	bDelay
    0x0E	bLength
    0x02	bSubframeSize
    0x09	bLength
    0x82	bEndpointAddress  (IN endpoint 2)
    0x0064	wMaxPacketSize    (1 x 100 bytes)
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x0000	wLockDelay
    0x09	bLength
    0x01	bNumEndPoints
    0x00	iInterface
    HID Descriptor:
    0x09	bLength
    0x0100	bcdHID
    0x00	bCountryCode
    0x07	bLength
    0x83	bEndpointAddress  (IN endpoint 3)
    0x0004	wMaxPacketSize    (1 x 4 bytes)
    0x20	bInterval         (32 frames)
    Index  LANGID  String
    0x00   0x0000  0x0409
    0x01   0x0409  "C-Media USB Audio Device   "
    Root Hub
    C-Media USB Audio Device    (VID=0x0D8C PID=0x0008) Port: 2
    Here is a dump from the Teensy 4.1.
    Information for device Teensy MIDI/Audio (VID=0x16C0 PID=0x048A):
    Device current bus speed: HighSpeed
    Device address: 0x0006
    Number of open pipes: 5
    Device Descriptor:
    0x12	bLength
    0x0200	bcdUSB
    0x00	bDeviceClass
    0x16C0	idVendor
    0x048A	idProduct
    0x0280	bcdDevice
    0x01	iManufacturer
    0x02	iProduct
    0x03	iSerialNumber
    Device Qualifier Descriptor:
    0x0A	bLength
    0x06	bDescriptorType
    0x0200	bcdUSB
    0x00	bDeviceClass
    0x00	bReserved
    0x09	bLength
    0x0155	wTotalLength   (341 bytes)
    0x06	bNumInterfaces
    0x00	iConfiguration
    0xC0	bmAttributes   (Self-powered Device)
    Interface Association Descriptor:
    0x08	bLength
    0x0B	bDescriptorType
    0x00	bFirstInterface
    0x02	bInterfaceCount
    0x02	bFunctionClass      (Communication Device Class)
    0x02	bFunctionSubClass   (Abstract Control Model - ACM)
    0x01	bFunctionProtocol   (ITU-T V.250)
    0x00	iFunction
    0x09	bLength
    0x01	bNumEndPoints
    0x02	bInterfaceClass      (Communication Device Class)
    0x02	bInterfaceSubClass   (Abstract Control Model - ACM)
    0x01	bInterfaceProtocol   (ITU-T V.250)
    0x00	iInterface
    CDC Header Functional Descriptor:
    0x05	bFunctionalLength
    0x00	bDescriptorSubtype
    0x0110	bcdCDC
    CDC Call Management Functional Descriptor:
    0x01	bmCapabilities
    0x01	bDataInterface
    CDC Abstract Control Management Functional Descriptor:
    0x04	bFunctionalLength
    0x06	bmCapabilities
    CDC Union Functional Descriptor:
    0x00	bControlInterface
    0x01	bSubordinateInterface(0)
    0x07	bLength
    0x0010	wMaxPacketSize    (1 x 16 bytes)
    0x05	bInterval         (16 microframes)
    0x09	bLength
    0x02	bNumEndPoints
    0x0A	bInterfaceClass      (CDC Data)
    0x00	iInterface
    0x07	bLength
    0x03	bEndpointAddress  (OUT endpoint 3)
    0x02	bmAttributes      (Transfer: Bulk / Synch: None / Usage: Data)
    0x0200	wMaxPacketSize    (512 bytes)
    0x00	bInterval
    0x07	bLength
    0x00	bInterval
    0x09	bLength
    0x02	bNumEndPoints
    0x03	bInterfaceSubClass   (MIDI Streaming Interface)
    0x00	iInterface
    MS Interface Header Descriptor:
    0x07	bLength
    0x0100	bcdMSC
    0x0025	wTotalLength   (37 bytes)
    MS MIDI IN Jack Descriptor:
    0x06	bLength
    0x01	bJackType
    0x01	bJackID
    0x00	iJack
    0x06	bLength
    0x02	bJackType
    0x02	bJackID
    0x00	iJack
    MS MIDI OUT Jack Descriptor:
    0x09	bLength
    0x01	bJackType
    0x03	bJackID
    0x01	bNrInputPins
    0x02	baSourceID(1)
    0x01	baSourcePin(1)
    0x00	iJack
    0x09	bLength
    0x02	bJackType
    0x04	bJackID
    0x01	bNrInputPins
    0x01	baSourceID(1)
    0x01	baSourcePin(1)
    0x00	iJack
    0x09	bLength
    0x04	bEndpointAddress  (OUT endpoint 4)
    0x00	bInterval
    0x00	bRefresh
    0x00	bSynchAddress
    MS Bulk Data Endpoint Descriptor:
    0x05	bLength
    0x01	bNumEmbMIDIJack
    0x01	baAssocJackID(1)
    0x09	bLength
    0x84	bEndpointAddress  (IN endpoint 4)
    0x00	bInterval
    0x00	bRefresh
    0x00	bSynchAddress
    0x05	bLength
    0x03	baAssocJackID(1)
    0x08	bLength
    0x03	bFirstInterface
    0x03	bInterfaceCount
    0x01	bFunctionClass      (Audio Device Class)
    0x01	bFunctionSubClass   (Audio Control Interface)
    0x00	bFunctionProtocol   (Audio Protocol undefined)
    0x00	iFunction
    0x09	bLength
    0x00	bNumEndPoints
    0x00	iInterface
    0x0A	bLength
    0x0100	bcdADC
    0x003E	wTotalLength   (62 bytes)
    0x02	bInCollection
    0x04	baInterfaceNr(1)
    0x05	baInterfaceNr(2)
    0x0C	bLength
    0x01	bTerminalID
    0x0602	wTerminalType   (Digital audio interface)
    0x00	bAssocTerminal
    0x00	iChannelNames
    0x00	iTerminal
    0x09	bLength
    0x02	bTerminalID
    0x00	bAssocTerminal
    0x01	bSourceID
    0x00	iTerminal
    0x0C	bLength
    0x03	bTerminalID
    0x00	bAssocTerminal
    0x00	iChannelNames
    0x00	iTerminal
    0x0A	bLength
    0x31	bUnitID
    0x03	bSourceID
    0x01	bControlSize
    bmaControls:
    0x00	iFeature
    0x09	bLength
    0x04	bTerminalID
    0x00	bAssocTerminal
    0x31	bSourceID
    0x00	iTerminal
    0x09	bLength
    0x04	bInterfaceNumber
    0x00	bNumEndPoints
    0x00	iInterface
    0x09	bLength
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x02	bTerminalLink
    0x03	bDelay
    0x0B	bLength
    0x02	bSubframeSize
    0x09	bLength
    0x00B4	wMaxPacketSize    (1 x 180 bytes)
    0x04	bInterval         (8 microframes)
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x00	bmAttributes
    0x0000	wLockDelay
    0x09	bLength
    0x05	bInterfaceNumber
    0x00	bNumEndPoints
    0x00	iInterface
    0x09	bLength
    0x02	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x03	bTerminalLink
    0x03	bDelay
    0x0B	bLength
    0x02	bSubframeSize
    0x09	bLength
    0x05	bEndpointAddress  (OUT endpoint 5)
    0x00	bRefresh
    0x86	bSynchAddress
    0x07	bLength
    0x00	bmAttributes
    0x0000	wLockDelay
    0x09	bLength
    0x86	bEndpointAddress  (IN endpoint 6)
    0x11	bmAttributes      (Transfer: Isochronous / Synch: None / Usage: Feedback)
    0x07	bRefresh
    0x00	bSynchAddress
    Other Speed Configuration Descriptor:
    0x09	bLength
    0x07	bDescriptorType
    0x06	bNumInterfaces
    0x00	iConfiguration
    0x08	bLength
    0x00	iFunction
    0x09	bLength
    0x01	bNumEndPoints
    0x00	iInterface
    0x0110	bcdCDC
    0x01	bmCapabilities
    0x01	bDataInterface
    0x06	bmCapabilities
    0x07	bLength
    0x10	bInterval         (16 frames)
    0x09	bLength
    0x02	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x0040	wMaxPacketSize    (64 bytes)
    0x00	bInterval
    0x07	bLength
    0x00	bInterval
    0x09	bLength
    0x02	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x0100	bcdMSC
    0x06	bLength
    0x01	bJackType
    0x01	bJackID
    0x00	iJack
    0x06	bLength
    0x02	bJackType
    0x02	bJackID
    0x00	iJack
    0x09	bLength
    0x01	bJackType
    0x03	bJackID
    0x01	bNrInputPins
    0x02	baSourceID(1)
    0x01	baSourcePin(1)
    0x00	iJack
    0x09	bLength
    0x02	bJackType
    0x04	bJackID
    0x01	bNrInputPins
    0x01	baSourceID(1)
    0x01	baSourcePin(1)
    0x00	iJack
    0x09	bLength
    0x00	bInterval
    0x00	bRefresh
    0x00	bSynchAddress
    0x05	bLength
    0x09	bLength
    0x00	bInterval
    0x00	bRefresh
    0x00	bSynchAddress
    0x05	bLength
    0x08	bLength
    0x00	iFunction
    0x09	bLength
    0x00	bNumEndPoints
    0x00	iInterface
    0x0A	bLength
    0x0100	bcdADC
    0x02	bInCollection
    0x0C	bLength
    0x01	bTerminalID
    0x00	bAssocTerminal
    0x00	iChannelNames
    0x00	iTerminal
    0x09	bLength
    0x02	bTerminalID
    0x00	bAssocTerminal
    0x01	bSourceID
    0x00	iTerminal
    0x0C	bLength
    0x03	bTerminalID
    0x00	bAssocTerminal
    0x00	iChannelNames
    0x00	iTerminal
    0x0A	bLength
    0x31	bUnitID
    0x03	bSourceID
    0x01	bControlSize
    bmaControls:
    0x00	iFeature
    0x09	bLength
    0x04	bTerminalID
    0x00	bAssocTerminal
    0x31	bSourceID
    0x00	iTerminal
    0x09	bLength
    0x00	bNumEndPoints
    0x00	iInterface
    0x09	bLength
    0x01	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x02	bTerminalLink
    0x03	bDelay
    0x0B	bLength
    0x02	bSubframeSize
    0x09	bLength
    0x00	bRefresh
    0x00	bSynchAddress
    0x07	bLength
    0x00	bmAttributes
    0x0000	wLockDelay
    0x09	bLength
    0x00	bNumEndPoints
    0x00	iInterface
    0x09	bLength
    0x02	bNumEndPoints
    0x00	iInterface
    0x07	bLength
    0x03	bTerminalLink
    0x03	bDelay
    0x0B	bLength
    0x02	bSubframeSize
    0x09	bLength
    0x00	bRefresh
    0x86	bSynchAddress
    0x07	bLength
    0x00	bmAttributes
    0x0000	wLockDelay
    0x09	bLength
    0x05	bRefresh
    0x00	bSynchAddress
    Index  LANGID  String
    0x00   0x0000
    0x01   0x0000  "Teensyduino"
    0x02   0x0000  "Teensy MIDI/Audio"
    0x03   0x0000  "7681380"
    Root Hub
    Teensy MIDI/Audio (VID=0x16C0 PID=0x048A) Port: 2
    Jun 2018
    USA
    186
    Hey Frank,
    The "host" is the PC right? I am looking for information to flow from the PC -> Teensy.
    To test this functionality without breaking anything I think it makes sense to create a new AC Input Terminal Descriptor for "Line In".
    This line in can have a Terminal Unit, Mixer Unit, Processing Unit, and a Feature Unit. I think we are interested in the Terminal and the Feature Unit types.
    We can use this document to determine the Descriptor Types and Subtypes, etc. USB Device Class Definition for Terminal Types
    So I think this is what we want for the LINE IN Terminal.
    0x0C	bLength
    0x06	bTerminalID
    0x00	bAssocTerminal
    0x00	iChannelNames
    0x00	iTerminal
    Now we need the Feature Unit.
    page 58 of http://dl.project-voodoo.org/usb-aud...20%20final.pdf
    The bSourceID field is used to describe the connectivity for this Feature Unit. It contains the ID of the
    Unit or Terminal to which this Feature Unit is connected via its Input Pin.
    So I think this is what we will want for our feature unit.
    0x0A	bLength
    0x0F	bUnitID
    0x06	bSourceID
    0x01	bControlSize
    bmaControls:
    0x00	iFeature
    I think that might do it. What do you think?
    Jun 2018
    USA
    186
    Note: Paul describes how to edit the USB Descriptor:
    https://forum.pjrc.com/threads/27265...ion-Descriptor
    Jun 2018
    USA
    186
    Note, I found where the descriptor definitions are.
    Maybe I can simply add my feature to this, and maybe I can start getting something to work. Will try when I have a moment!
    https://github.com/PaulStoffregen/co...sy4/usb_desc.c
    	// Volume feature descriptor
    	10,					// bLength
    	0x24, 				// bDescriptorType = CS_INTERFACE
    	0x06, 				// bDescriptorSubType = FEATURE_UNIT
    	0x31, 				// bUnitID
    	0x03, 				// bSourceID (Input Terminal)
    	0x01, 				// bControlSize (each channel is 1 byte, 3 channels)
    	0x01, 				// bmaControls(0) Master: Mute
    	0x02, 				// bmaControls(1) Left: Volume
    	0x02, 				// bmaControls(2) Right: Volume
    	0x00,				// iFeature
