TWhat did you use on the PC side to work the image data?
Thank you for your interest!
In my program there is a lot of serial communication, there are about 300 properties in both directions, therefore here only for understanding.
I use as a basis for communication TeensySharp:
https://github.com/luni64/TeensySharp
After the port is opened, I do not subscribe to the event that provides the data, but use the Win API BaseStream according to this article by Ben Voigt:
https://www.sparxeng.com/blog/software/must-use-net-system-io-ports-serialport
This method is called once right after the port is opened and then returns a permanent stream of data:
/// <summary>
/// Continuous Read from Serial BaseStream
/// </summary>
private void ContinuousRead() {
byte[] buffer = new byte[4096];
Action kickoffRead = null;
kickoffRead = () => port.BaseStream.BeginRead(buffer, 0, buffer.Length, delegate (IAsyncResult ar) {
int count = port.BaseStream.EndRead(ar);
byte[] dst = new byte[count];
Buffer.BlockCopy(buffer, 0, dst, 0, count);
this.Invoke((MethodInvoker)delegate { BytesReceived(dst); });
kickoffRead();
}, null); kickoffRead();
Now the data is processed further.
I distinguish between text messages from the Teensy, which are wrapped in "<text>" and raw data, which are wrapped in "* ... #" packets. For the screenshot of course only the section "RAW Data Bytes" is interesting:
/// <summary>
/// Handle Serial Byte Stream
/// </summary>
/// <param name="dataBlock"></param>
private void BytesReceived(byte[] dataBlock) {
// Emcoding current byteblock and clean up.
string readStr = Encoding.Default.GetString(dataBlock).Replace("\r", "").Replace("\n", "");
// RAW Data Bytes
if (readStr.StartsWith("*")) { addSerialBytes = true; listSerialBytes.Clear(); }
if (addSerialBytes) listSerialBytes.AddRange(dataBlock);
if (addSerialBytes && readStr.EndsWith("#")) HandleBytes(listSerialBytes);
// Text Message
if (readStr.StartsWith("<")) { addSerialMessage = true; sbSerialMessage.Clear(); }
if (addSerialMessage) sbSerialMessage.Append(readStr);
if (addSerialMessage && readStr.EndsWith(">")) WasMessage(sbSerialMessage.ToString());
For text messages, continue here:
/// <summary>
/// Serial Data was a Message
/// </summary>
/// <param name="msg"></param>
private void WasMessage(string msg) {
addSerialMessage = false;
string str = msg.Replace("<", "");
string[] items = str.Split(new[] { ">" }, StringSplitOptions.RemoveEmptyEntries);
foreach (string s in items) {
// Do something with the text
And if bytes come as a screenshot and the length fits, then the image is assembled here and displayed in a PictureBox:
/// <summary>
/// Handle Byte Stream from Serial
/// </summary>
private void HandleBytes(List<byte> lst) {
addSerialBytes = false;
lst.RemoveAt(0); // Remove first Element '*'
lst.RemoveAt(listSerialBytes.Count - 1); // Remove last Element '#'
if (lst.Count == 240 * 320 * 2) {
byte[] bytes = lst.ToArray();
Bitmap bmp = new Bitmap(240, 320, PixelFormat.Format24bppRgb);
BitmapData data = bmp.LockBits(new Rectangle(0, 0, bmp.Width, bmp.Height), ImageLockMode.ReadWrite, PixelFormat.Format24bppRgb);
int stride = data.Stride;
unsafe {
byte* ptr = (byte*)data.Scan0;
int count = 0;
for (int y = 0; y < 320; y++) {
for (int x = 0; x < 240; x++) {
Color c = Utility.RGB565toRGB(BitConverter.ToUInt16(bytes, count));
ptr[(x * 3) + y * stride] = c.B;
ptr[(x * 3) + y * stride + 1] = c.G;
ptr[(x * 3) + y * stride + 2] = c.R;
if (count < 153588) count += 2;
bmp.UnlockBits(data);
PictureBoxScreenShot.BackgroundImage = bmp;
WriteControllerLog("Sorry, screenshot is not possible.", Logging.LogType.error);
Here is the method to convert the 16bit colors:
/// <summary>
/// Converts RGB565 color to RGB color.
/// </summary>
/// <param name="rgb565"></param>
/// <returns></returns>
public static Color RGB565toRGB(ushort rgb565) {
byte b = (byte)((rgb565 & 0x001F) << 3);
byte g = (byte)((rgb565 & 0x07E0) >> 3);
byte r = (byte)((rgb565 & 0xF800) >> 8);
return Color.FromArgb(r |= (byte)(r >> 5), g |= (byte)(g >> 6), b |= (byte)(b >> 5));
In the class you still need these lists and variables, which must be outside the methods:
// Serial Handling
private List<byte> listSerialBytes = new List<byte>();
private StringBuilder sbSerialMessage = new StringBuilder();
private bool addSerialMessage = false;
private bool addSerialBytes = false;
So if you send the Teensy the command to execute a screenshot, it should call this method (teensy side):
/// <summary>
/// Take a screenshot from display.
/// </summary>
void ScreenShot() {
uint8_t color[2 * 240]; // Line Buffer
_LockScreenUpdate = true;
Serial.print("*");
for (uint16_t y = 0; y < 320; y++) {
tft.readRect(0, y, 240, 1, (uint16_t*)color);
Serial.write(color, 2 * 240);
delay(2);
Serial.print("#");
_LockScreenUpdate = false;
_LockScreenUpdate (bool) I use in Teensy to block the complete redraw until the screenshot is ready.
Have fun trying
Bruno
