underconstrained
I'm relatively new to coding and find myself currently using a Teensy 4.0 (will upgrade to 4.1 shortly) to control a bunch of high speed stepper motors for an art installation. I'm currently running a single axis system using a DM542T drive and running at speeds of up to 50k steps/sec, but plan to use other drives and waaay more motors. I looked into teesnystep, and may go back to it, but at the time of this post, it does not support teensy 4's. Furthermore, my moves have different acceleration and deceleration profiles and are non-blocking which seem to be rare features in open source motion control libraries. For overkill, I'm re-calculating the acceleration delays for every step which is currently taking under 1us to perform the calcs for every pulse on/off. I plan on controlling 4 or more motors with each teensy 4.1 depending on how things shake out. I'm sure I'm not the only one to have gone down this rabbit hole and welcome any "constructive" comments or direction.
Now for the main reason for this post. I'm currently working on using another Teensy 4.0 to process a bunch of data that will include wireless signals and PWM Analog sensors that batch send this data to the 1st teensy. I plan to send this data unfrequently (say every 10ms) and it would be 128 bytes/characters, or less if needed, to allow the sensing Teensy time to process a bunch pwm inputs and wireless data. The two teensys will hardwired right next to each other. Is UART the quickest method communicate between the two? Ideally I would like to send/receive the data in under 5us in order to not mess with the motion control on the first Teensy by very much...
Regards,
Matthew
Regards,
Matthew
