Results 1 to 7 of 7
Thread: Visualteensy & Teensyduino 1.54 beta 6 issue with multiple definitions?
    Can't seem to get past this issue. Forgive me if I'm not seeing something obvious here.
    I've clean installed Arduino 1.8.13 and Teensyduino 1.54-beta 6.
    I've downloaded https://raw.githubusercontent.com/vj...eiveString.ino
    It compiles in Arduino nicely.
    I typically run VisualTeensy v0.9.9.2 and I'm having issues with getting this to compile in that environment.
    To recreate that, I've created a new VisualTeensy project, pulled in the TeensyDuino libs
    When I save the VisualTeensy project, opens up in VSCode, like normal, it compiles, but I get this:
    .vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o: In functionfnet_mimxrt_serial_init':
    C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: multiple definition of `fnet_mimxrt_serial_init'
    .vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o:C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: first defined here
    c:/progra~2/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
    .vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o: In function fnet_mimxrt_serial_init': C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: multiple definition of fnet_mimxrt_serial_putchar'
    .vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o: In function fnet_mimxrt_serial_init': C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: multiple definition of fnet_mimxrt_serial_getchar'
    .vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o: In function fnet_mimxrt_serial_init': C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: multiple definition of Serials'
    collect2.exe: error: ld returned 1 exit status`
    I'm not sure if this is an issue with FNET.H, or with VisualTeensy or Teensyduino beta libraries.
    Any tips would be appreciated.
    Germany
    1,422
    I can have a look. Which board are you compiling for?
    Germany
    1,422
    I just tried what you described above. Compiles without a single warning here. (TD 1.54, Arduino 1.8.12, T4.1)
    IB [CC]  cipher_wrap.c
    LIB [CC]  ctr_drbg.c
    LIB [CC]  ccm.c
    LIB [CC]  pk_wrap.c
    LIB [CC]  ecp_curves.c
    LIB [CC]  pkcs12.c
    LIB [CC]  x509write_csr.c
    LIB [CC]  fnet_mimxrt.c
    LIB [CC]  fnet_mimxrt_isr_inst.c
    LIB [CC]  fnet_cpu.c
    LIB [CC]  fnet_mimxrt_eth.c
    LIB [CC]  fnet_mimxrt_serial.c
    LIB [CC]  memory_buffer_alloc.c
    LIB [CC]  fnet_mimxrt_isr.c
    LIB [CC]  des.c
    LIB [CC]  hmac_drbg.c
    LIB [CC]  fnet_fec.c
    CORE [AR] .vsteensy/build/core.a
    Teensy core built successfully
    USER [CPP] main.cpp
    [LD]  .vsteensy/build/fnet.elf
    Memory region         Used Size  Region Size  %age Used
                ITCM:         96 KB       512 KB     18.75%
                DTCM:       39680 B       512 KB      7.57%
                 RAM:       12416 B       512 KB      2.37%
               FLASH:      296976 B      7936 KB      3.65%
                ERAM:          0 GB        16 MB      0.00%
    User code built and linked to libraries
    [HEX] .vsteensy/build/fnet.hex
    [SYM] .vsteensy/build/fnet.sym
    [LST] .vsteensy/build/fnet.lst
    Sucessfully built project
    Edit: also tried a current clone of the core libraries -> also works without issues
    Germany
    1,422
    Wild guess: Can it be that you installed the FNET library to your sketchbook/library folder as well?
    Thanks for looking into this Luni.
    I'm using T4.1
    I uninstalled Arduino and wiped out that folder. Reinstalled and the sketchbook library folder is library free.
    I'll try the non-beta Teensyduino
    TD 1.53, Arduino 1.8.12, T4.1 compiles clean in Arduino & VSCode (libs FNET V0.1.3 & NativeEthernet v1.0.1)
    TD 1.53, Arduino 1.8.13, T4.1 compiles clean in Arduino & VSCode (libs FNET V0.1.3 & NativeEthernet v1.0.1)
    1,569
    Just FYI: When I compile that code with Arduino 1.8.13 and TD 1.54-beta6, it spits out an error message early on in the compilation.
    Error while detecting libraries included by C:\arduino-1.8.13_1.54_b6\hardware\teensy\avr\libraries\FNET\src\service\serial\fnet_serial.c
    There's no other information and it doesn't prevent the code compiling and linking. I haven't figured out why that error occurs (but haven't looked too hard) but maybe it's indicating a problem somewhere in the files included by FNET.
    Pete
