Visualteensy & Teensyduino 1.54 beta 6 issue with multiple definitions?
TeensyWolf
Can't seem to get past this issue. Forgive me if I'm not seeing something obvious here.
I've clean installed Arduino 1.8.13 and Teensyduino 1.54-beta 6.
I've downloaded https://raw.githubusercontent.com/v...UDPSendReceiveString/UDPSendReceiveString.ino
It compiles in Arduino nicely.
I typically run VisualTeensy v0.9.9.2 and I'm having issues with getting this to compile in that environment.
To recreate that, I've created a new VisualTeensy project, pulled in the TeensyDuino libs
When I save the VisualTeensy project, opens up in VSCode, like normal, it compiles, but I get this:
.vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o: In functionfnet_mimxrt_serial_init':
C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: multiple definition of `fnet_mimxrt_serial_init'
.vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o:C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: first defined here
c:/progra~2/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
.vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o: In function fnet_mimxrt_serial_init': C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: multiple definition of fnet_mimxrt_serial_putchar'
.vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o: In function fnet_mimxrt_serial_init': C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: multiple definition of fnet_mimxrt_serial_getchar'
.vsteensy/build/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.o: In function fnet_mimxrt_serial_init': C:\Users\pc\GitHub\pc\pc-network/lib/FNET/src/port/cpu/mimxrt//fnet_mimxrt_serial.cpp:56: multiple definition of Serials'
collect2.exe: error: ld returned 1 exit status`
I'm not sure if this is an issue with FNET.H, or with VisualTeensy or Teensyduino beta libraries.
Any tips would be appreciated.
I just tried what you described above. Compiles without a single warning here. (TD 1.54, Arduino 1.8.12, T4.1)
IB [CC]  cipher_wrap.c
LIB [CC]  ctr_drbg.c
LIB [CC]  ccm.c
LIB [CC]  pk_wrap.c
LIB [CC]  ecp_curves.c
LIB [CC]  pkcs12.c
LIB [CC]  x509write_csr.c
LIB [CC]  fnet_mimxrt.c
LIB [CC]  fnet_mimxrt_isr_inst.c
LIB [CC]  fnet_cpu.c
LIB [CC]  fnet_mimxrt_eth.c
LIB [CC]  fnet_mimxrt_serial.c
LIB [CC]  memory_buffer_alloc.c
LIB [CC]  fnet_mimxrt_isr.c
LIB [CC]  des.c
LIB [CC]  hmac_drbg.c
LIB [CC]  fnet_fec.c
CORE [AR] .vsteensy/build/core.a
Teensy core built successfully
USER [CPP] main.cpp
[LD]  .vsteensy/build/fnet.elf
Memory region         Used Size  Region Size  %age Used
            ITCM:         96 KB       512 KB     18.75%
            DTCM:       39680 B       512 KB      7.57%
             RAM:       12416 B       512 KB      2.37%
           FLASH:      296976 B      7936 KB      3.65%
            ERAM:          0 GB        16 MB      0.00%
User code built and linked to libraries
[HEX] .vsteensy/build/fnet.hex
[SYM] .vsteensy/build/fnet.sym
[LST] .vsteensy/build/fnet.lst
Sucessfully built project
Edit: also tried a current clone of the core libraries -> also works without issues
Wild guess: Can it be that you installed the FNET library to your sketchbook/library folder as well?
Thanks for looking into this Luni.
I'm using T4.1
I uninstalled Arduino and wiped out that folder. Reinstalled and the sketchbook library folder is library free.
I'll try the non-beta Teensyduino
TD 1.53, Arduino 1.8.12, T4.1 compiles clean in Arduino & VSCode (libs FNET V0.1.3 & NativeEthernet v1.0.1)
TD 1.53, Arduino 1.8.13, T4.1 compiles clean in Arduino & VSCode (libs FNET V0.1.3 & NativeEthernet v1.0.1)
Just FYI: When I compile that code with Arduino 1.8.13 and TD 1.54-beta6, it spits out an error message early on in the compilation.
Error while detecting libraries included by C:\arduino-1.8.13_1.54_b6\hardware\teensy\avr\libraries\FNET\src\service\serial\fnet_serial.c
There's no other information and it doesn't prevent the code compiling and linking. I haven't figured out why that error occurs (but haven't looked too hard) but maybe it's indicating a problem somewhere in the files included by FNET.
Pete
@luni, I'm seeing this issue again (had forgotten about it, and mentioned it in the Teensyduino 1.54 Released thread). All I have to do is update FNET from 4.6.3 to 4.7.0 (or 4.7.1) to see errors, multiple definition of `fnet_mimxrt_serial_init' and others.
Saw this on 2 separate Win 10 PCs. Fresh install of Arduino, Teensyduino 1.54 and VisualTeensy v1.0.0.0 (or v0.9.9.3).
Code compiles with regular Arduino 1.8.15
To recreate:
1. New Visualteensy project
2. Add SPI (v1.0), FNET (v0.1.3) & NativeEthernet (v1.0.5) libs (from Teensyduino) to VisualTeensy
3. Add this code: https://raw.githubusercontent.com/v...master/examples/UdpNtpClient/UdpNtpClient.ino
4. Comment out the error in loop or move loop to bottom of file
5. Save, opens in VSCode
6. Build and see error
Teensy 4.1
vsteensy.json
  "version": "1",
  "target": "vsCode",
  "buildSystem": "makefile",
  "debugSupport": "cortex_debug",
  "configurations": [
      "name": "default",
      "guid": "0f94abb2-468b-410c-be81-9369a3205b2c",
      "setupType": "expert",
      "coreBase": "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr",
      "compilerBase": "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\arm",
      "makefileExtension": null,
      "copyCore": true,
      "sharedLibraries": [
        "Circular_Buffer"
      "projectLibraries": [
        "FNET",
        "SPI",
        "NativeEthernet"
      "board": {
        "name": "Teensy 4.1",
        "options": {
          "USB Type": "Serial",
          "CPU Speed": "600 MHz",
          "Optimize": "Faster",
          "Keyboard Layout": "US English"
c_cpp_properties.json
  "configurations": [
      "name": "VisualTeensy",
      "includePath": [
        "src/**",
        "C:/Program Files (x86)/Arduino/hardware/teensy/avr/cores/teensy4",
        "C:/Users/win10/github/Arduino/libraries/Circular_Buffer/**",
        "lib/FNET/**",
        "lib/SPI/**",
        "lib/NativeEthernet/**"
      "forcedInclude": [],
      "defines": [
        "__IMXRT1062__",
        "TEENSYDUINO=154",
        "ARDUINO_TEENSY41",
        "F_CPU=600000000",
        "USB_SERIAL",
        "LAYOUT_US_ENGLISH",
        "ARDUINO=10813"
      "compilerPath": "C:/PROGRA~2/Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc.exe",
      "intelliSenseMode": "gcc-arm",
      "cppStandard": "gnu++14"
  "version": 4
makefile
# Generated by VisualTeensy (https://github.com/luni64/VisualTeensy)
# Board              Teensy 4.1
# USB Type           Serial
# CPU Speed          600 MHz
# Optimize           Faster
# Keyboard Layout    US English
# 8/6/2021 10:22 PM
SHELL            := cmd.exe
export SHELL
TARGET_NAME      := t41_ntp
BOARD_ID         := TEENSY41
MCU              := imxrt1062
LIBS_SHARED_BASE := C:\Users\win10\github\Arduino\libraries
LIBS_SHARED      := Circular_Buffer
LIBS_LOCAL_BASE  := lib
LIBS_LOCAL       := FNET SPI NativeEthernet
CORE_BASE        := core
GCC_BASE         := C:\PROGRA~2\Arduino\hardware\tools\arm\bin
UPL_PJRC_B       := C:\PROGRA~2\Arduino\hardware\tools
UPL_TYCMD_B      := C:\PROGRA~1\TyTools
# Flags and Defines
FLAGS_CPU   := -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16
FLAGS_OPT   := -O2
FLAGS_COM   := -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD
FLAGS_LSP   :=
FLAGS_CPP   := -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing
FLAGS_C     :=
FLAGS_S     := -x assembler-with-cpp
FLAGS_LD    := -Wl,--print-memory-usage,--gc-sections,--relax,--defsym=__rtc_localtime=$(shell powershell [int](Get-Date -UFormat +%s)[0]) -T$(CORE_BASE)/imxrt1062_t41.ld
LIBS        := -larm_cortexM7lfsp_math -lm -lstdc++
DEFINES     := -D__IMXRT1062__ -DTEENSYDUINO=154 -DARDUINO_TEENSY41 -DARDUINO=10813
DEFINES     += -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH
CPP_FLAGS   := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_CPP)
C_FLAGS     := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_C)
S_FLAGS     := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_S)
LD_FLAGS    := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_LSP) $(FLAGS_LD)
AR_FLAGS    := rcs
NM_FLAGS    := --numeric-sort --defined-only --demangle --print-size
# Colors
COL_CORE    := [38;2;187;206;251m
COL_LIB     := [38;2;206;244;253m
COL_SRC     := [38;2;100;149;237m
COL_LINK    := [38;2;255;255;202m
COL_ERR     := [38;2;255;159;159m
COL_OK      := [38;2;179;255;179m
COL_RESET   := [0m
# Folders and Files
USR_SRC         := src
LIB_SRC         := lib
CORE_SRC        := $(CORE_BASE)
BIN             := .vsteensy/build
USR_BIN         := $(BIN)/src
CORE_BIN        := $(BIN)/core
LIB_BIN         := $(BIN)/lib
CORE_LIB        := $(BIN)/core.a
TARGET_HEX      := $(BIN)/$(TARGET_NAME).hex
TARGET_ELF      := $(BIN)/$(TARGET_NAME).elf
TARGET_LST      := $(BIN)/$(TARGET_NAME).lst
TARGET_SYM      := $(BIN)/$(TARGET_NAME).sym
# BINARIES
CC              := $(GCC_BASE)/arm-none-eabi-gcc
CXX             := $(GCC_BASE)/arm-none-eabi-g++
AR              := $(GCC_BASE)/arm-none-eabi-gcc-ar
NM              := $(GCC_BASE)/arm-none-eabi-gcc-nm
SIZE            := $(GCC_BASE)/arm-none-eabi-size
OBJDUMP         := $(GCC_BASE)/arm-none-eabi-objdump
OBJCOPY         := $(GCC_BASE)/arm-none-eabi-objcopy
UPL_PJRC        := "$(UPL_PJRC_B)/teensy_post_compile" -test -file=$(TARGET_NAME) -path=$(BIN) -tools="$(UPL_PJRC_B)" -board=$(BOARD_ID) -reboot
UPL_TYCMD       := $(UPL_TYCMD_B)/tyCommanderC upload $(TARGET_HEX) --autostart --wait --multi
UPL_CLICMD      := $(UPL_CLICMD_B)/teensy_loader_cli -mmcu=$(MCU) -v $(TARGET_HEX)
UPL_JLINK       := $(UPL_JLINK_B)/jlink -commanderscript .vsteensy/flash.jlink
# Source and Include Files
# Recursively create list of source and object files in USR_SRC and CORE_SRC
# and corresponding subdirectories.
# The function rwildcard is taken from http://stackoverflow.com/a/12959694)
rwildcard =$(wildcard $1$2) $(foreach d,$(wildcard $1*),$(call rwildcard,$d/,$2))
#User Sources -----------------------------------------------------------------
USR_C_FILES     := $(call rwildcard,$(USR_SRC)/,*.c)
USR_CPP_FILES   := $(call rwildcard,$(USR_SRC)/,*.cpp)
USR_S_FILES     := $(call rwildcard,$(USR_SRC)/,*.S)
USR_OBJ         := $(USR_S_FILES:$(USR_SRC)/%.S=$(USR_BIN)/%.o) $(USR_C_FILES:$(USR_SRC)/%.c=$(USR_BIN)/%.o) $(USR_CPP_FILES:$(USR_SRC)/%.cpp=$(USR_BIN)/%.o)
# Core library sources --------------------------------------------------------
CORE_CPP_FILES  := $(call rwildcard,$(CORE_SRC)/,*.cpp)
CORE_C_FILES    := $(call rwildcard,$(CORE_SRC)/,*.c)
CORE_S_FILES    := $(call rwildcard,$(CORE_SRC)/,*.S)
CORE_OBJ        := $(CORE_S_FILES:$(CORE_SRC)/%.S=$(CORE_BIN)/%.o) $(CORE_C_FILES:$(CORE_SRC)/%.c=$(CORE_BIN)/%.o) $(CORE_CPP_FILES:$(CORE_SRC)/%.cpp=$(CORE_BIN)/%.o)
# User library sources (see https://github.com/arduino/arduino/wiki/arduino-ide-1.5:-library-specification)
LIB_DIRS_SHARED := $(foreach d, $(LIBS_SHARED), $(LIBS_SHARED_BASE)/$d/ $(LIBS_SHARED_BASE)/$d/utility/)      # base and /utility
LIB_DIRS_SHARED += $(foreach d, $(LIBS_SHARED), $(LIBS_SHARED_BASE)/$d/src/ $(dir $(call rwildcard,$(LIBS_SHARED_BASE)/$d/src/,*/.)))                          # src and all subdirs of base
LIB_DIRS_LOCAL  := $(foreach d, $(LIBS_LOCAL), $(LIBS_LOCAL_BASE)/$d/ $(LIBS_LOCAL_BASE)/$d/utility/ )        # base and /utility
LIB_DIRS_LOCAL  += $(foreach d, $(LIBS_LOCAL), $(LIBS_LOCAL_BASE)/$d/src/ $(dir $(call rwildcard,$(LIBS_LOCAL_BASE)/$d/src/,*/.)))                          # src and all subdirs of base
LIB_CPP_SHARED  := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.cpp))
LIB_C_SHARED    := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.c))
LIB_S_SHARED    := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.S))
LIB_CPP_LOCAL   := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.cpp))
LIB_C_LOCAL     := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.c))
LIB_S_LOCAL     := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.S))
LIB_OBJ         := $(LIB_CPP_SHARED:$(LIBS_SHARED_BASE)/%.cpp=$(LIB_BIN)/%.o)  $(LIB_CPP_LOCAL:$(LIBS_LOCAL_BASE)/%.cpp=$(LIB_BIN)/%.o)
LIB_OBJ         += $(LIB_C_SHARED:$(LIBS_SHARED_BASE)/%.c=$(LIB_BIN)/%.o)  $(LIB_C_LOCAL:$(LIBS_LOCAL_BASE)/%.c=$(LIB_BIN)/%.o)
LIB_OBJ         += $(LIB_S_SHARED:$(LIBS_SHARED_BASE)/%.S=$(LIB_BIN)/%.o)  $(LIB_S_LOCAL:$(LIBS_LOCAL_BASE)/%.S=$(LIB_BIN)/%.o)
# Includes -------------------------------------------------------------
INCLUDE         := -I./$(USR_SRC) -I$(CORE_SRC)
INCLUDE         += $(foreach d, $(LIB_DIRS_SHARED), -I$d)
INCLUDE         += $(foreach d, $(LIB_DIRS_LOCAL), -I$d)
# Generate directories --------------------------------------------------------
DIRECTORIES     :=  $(sort $(dir $(CORE_OBJ) $(USR_OBJ) $(LIB_OBJ)))
generateDirs    := $(foreach d, $(DIRECTORIES), $(shell if not exist "$d" mkdir "$d"))
#$(info dirs: $(DIRECTORIES))
# Rules:
.PHONY: directories all rebuild upload uploadTy uploadCLI clean cleanUser cleanCore
all:  $(TARGET_LST) $(TARGET_SYM) $(TARGET_HEX)
rebuild: cleanUser all
clean: cleanUser cleanCore cleanLib
	@echo $(COL_OK)cleaning done$(COL_RESET)
upload: all
	@$(UPL_PJRC)
uploadTy: all
	@$(UPL_TYCMD)
uploadCLI: all
	@$(UPL_CLICMD)
uploadJLink: all
	@$(UPL_JLINK)
# Core library ----------------------------------------------------------------
$(CORE_BIN)/%.o: $(CORE_SRC)/%.S
	@echo $(COL_CORE)CORE [ASM] $(notdir $<) $(COL_ERR)
	@"$(CC)" $(S_FLAGS) $(INCLUDE) -o $@ -c $<
$(CORE_BIN)/%.o: $(CORE_SRC)/%.c
	@echo $(COL_CORE)CORE [CC]  $(notdir $<) $(COL_ERR)
	@"$(CC)" $(C_FLAGS) $(INCLUDE) -o $@ -c $<
$(CORE_BIN)/%.o: $(CORE_SRC)/%.cpp
	@echo $(COL_CORE)CORE [CPP] $(notdir $<) $(COL_ERR)
	@"$(CXX)" $(CPP_FLAGS) $(INCLUDE) -o $@ -c $<
$(CORE_LIB) : $(CORE_OBJ)
	@echo $(COL_LINK)CORE [AR] $@ $(COL_ERR)
	@$(AR) $(AR_FLAGS) $@ $^
	@echo $(COL_OK)Teensy core built successfully &&echo.
# Shared Libraries ------------------------------------------------------------
$(LIB_BIN)/%.o: $(LIBS_SHARED_BASE)/%.S
	@echo $(COL_LIB)LIB [ASM] $(notdir $<) $(COL_ERR)
$(LIB_BIN)/%.o: $(LIBS_SHARED_BASE)/%.cpp
	@echo $(COL_LIB)LIB [CPP] $(notdir $<) $(COL_ERR)
	@echo $(COL_LIB)LIB [CC]  $(notdir $<) $(COL_ERR)
# Local Libraries -------------------------------------------------------------
$(LIB_BIN)/%.o: $(LIBS_LOCAL_BASE)/%.S
$(LIB_BIN)/%.o: $(LIBS_LOCAL_BASE)/%.cpp
# Handle user sources ---------------------------------------------------------
$(USR_BIN)/%.o: $(USR_SRC)/%.S
	@echo $(COL_SRC)USER [ASM] $< $(COL_ERR)
	@"$(CC)" $(S_FLAGS) $(INCLUDE) -o "$@" -c $<
$(USR_BIN)/%.o: $(USR_SRC)/%.c
	@echo $(COL_SRC)USER [CC]  $(notdir $<) $(COL_ERR)
	@"$(CC)" $(C_FLAGS) $(INCLUDE) -o "$@" -c $<
$(USR_BIN)/%.o: $(USR_SRC)/%.cpp
	@echo $(COL_SRC)USER [CPP] $(notdir $<) $(COL_ERR)
	@"$(CXX)" $(CPP_FLAGS) $(INCLUDE) -o "$@" -c $<
# Linking ---------------------------------------------------------------------
$(TARGET_ELF): $(CORE_LIB) $(LIB_OBJ) $(USR_OBJ)
	@echo $(COL_LINK)
	@echo [LD]  $@ $(COL_ERR)
	@$(CC) $(LD_FLAGS) -o "$@" $(USR_OBJ) $(LIB_OBJ) $(CORE_LIB) $(LIBS)
	@echo $(COL_OK)User code built and linked to libraries &&echo.
%.lst: %.elf
	@echo [LST] $@
	@$(OBJDUMP) -d -S --demangle --no-show-raw-insn "$<" > "$@"
	@echo $(COL_OK)Sucessfully built project$(COL_RESET) &&echo.
%.sym: %.elf
	@echo [SYM] $@
	@$(NM) $(NM_FLAGS) "$<" > "$@"
%.hex: %.elf
	@echo $(COL_LINK)[HEX] $@
	@$(OBJCOPY) -O ihex -R.eeprom "$<" "$@"
# Cleaning --------------------------------------------------------------------
cleanUser:
	@echo $(COL_LINK)Cleaning user binaries...$(COL_RESET)
	@if exist $(USR_BIN) rd /s/q "$(USR_BIN)"
	@if exist "$(TARGET_LST)" del $(subst /,\,$(TARGET_LST))
cleanCore:
	@echo $(COL_LINK)Cleaning core binaries...$(COL_RESET)
	@if exist $(CORE_BIN) rd /s/q "$(CORE_BIN)"
	@if exist $(CORE_LIB) del  $(subst /,\,$(CORE_LIB))
cleanLib:
	@echo $(COL_LINK)Cleaning user library binaries...$(COL_RESET)
	@if exist $(LIB_BIN) rd /s/q "$(LIB_BIN)"
# compiler generated dependency info ------------------------------------------
-include $(CORE_OBJ:.o=.d)
-include $(USR_OBJ:.o=.d)
-include $(LIB_OBJ:.o=.d)
Had a quick look and found the following: In the FNET library folder: lib\FNET\src\port\cpu\mimxrt there are two files:
  • fnet_mimxrt_serial.cpp
They only differ in their extension. I don't say that this is not allowed but the makefile generator of VisualTeensy seems to stumble over it. Probably both files will generate the same *.o file. A quick workaround is to rename fnet_mimxrt_serial.c to e.g fnet_mimxrt_serialc.c
I'll check if I can fix this later.
Would be interesting, what type of files Arduino IDE generates, if it is compiling and working.
They generate filename.cpp.o, filename.c.o, etc. I always wondered why one would include the extension in the filename for the object files. Now I know :)
I'll fix that in VisualTeensy, shouldn't be a big thing.
