Page 20 of 20 FirstFirst ... 10 18 19 20
Results 476 to 477 of 477
Thread: Many TLAs: MTP MSC FS SD SDFat LittleFS UsbMSCFat to work with each other 8)
  1. #476
    New York
    6,958
    Morning all. Downloaded your updated version and ran it on the TMM.
    1. No problem recognizing the hub with the SSD and thumb drive attached.
    MTP_test
    SDIO Storage 0 254 sdio failed or missing
    SD Storage 1 10 sd1 failed or missing
    sd_addFilesystem: 0 20009140 PROGM 200032bc 20009140
    Program Storage 0 PROGM 983040 8192
    Initializing USB MSC drives...
    USB Drive Inserted
    UsbBase::mscBegin called 20007640 1 1
        After usbDriveBegin
    msc # Partition Table
    	part,boot,bgnCHS[3],type,endCHS[3],start,length
    exFAT:	1,0,0x20,0x21,0x0,0x7,0xFE,0xFF,0xFF,2048,204800000
    FAT32:	2,0,0xFE,0xFF,0xFF,0xC,0xFE,0xFF,0xFF,204802048,29634560
    pt_#0:	3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
    pt_#0:	4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
      Try Partiton:1 on MSC Index:0
    UsbBase::mscBegin called 20007640 0 1
        After usbDriveBegin
        ** SUCCEEDED **
    >> USB partition 1 volume ID: New Volume
    sd_addFilesystem: 1 20009208 MSC0-New Volume 200032b4 0
      Try Partiton:2 on MSC Index:1
    UsbBase::mscBegin called 20007640 0 2
        After usbDriveBegin
        ** SUCCEEDED **
    >> USB partition 2 volume ID: NEW VOLUME
    sd_addFilesystem: 2 200096c0 MSC0-NEW VOLUME 200032b4 1
      Try Partiton:3 on MSC Index:2
    UsbBase::mscBegin called 20007640 0 3
        After usbDriveBegin
      Try Partiton:4 on MSC Index:2
    UsbBase::mscBegin called 20007640 0 4
        After usbDriveBegin
    USB Drive Inserted
    UsbBase::mscBegin called 20007f40 1 1
        After usbDriveBegin
    exFAT:	1,0,0x20,0x21,0x0,0x7,0xFE,0xFF,0xFF,2048,121145343
    pt_#0:	2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
      Try Partiton:1 on MSC Index:2
    UsbBase::mscBegin called 20007f40 0 1
        After usbDriveBegin
        ** SUCCEEDED **
    sd_addFilesystem: 3 20009b78 MSC1-1 200032b4 2
      Try Partiton:2 on MSC Index:3
    UsbBase::mscBegin called 20007f40 0 2
        After usbDriveBegin
      Try Partiton:3 on MSC Index:3
    UsbBase::mscBegin called 20007f40 0 3
        After usbDriveBegin
      Try Partiton:4 on MSC Index:3
    UsbBase::mscBegin called 20007f40 0 4
        After usbDriveBegin
    sd_addFilesystem: 4 20004758 sdio 200032c8 0
    **** dir of sd[0] ****
    Setup done
    2. Copied the T4_1 directory to the SSD 2nd volume successfully. Output shows that it read the datetime string but modified dates don't show in WinExp for the SSD:
    }}}}}}}}} MSCMTPCB::usedSizeCB called 200045b0 2 1
    MSCMTPCB::usedSizeCB called for Fat32
    RESP:2001(RSP:OK)l: 24 T:1a : 30001 ffffffff 6
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1b : 6 dc02 (FORMAT)
    RESP:2001(RSP:OK)l: 20 T:1b : 6 dc02
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1c : 6 dc01 (STORAGE_ID)
    RESP:2001(RSP:OK)l: 20 T:1c : 6 dc01
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1d : 6 dc07 (OBJECT NAME)
    RESP:2001(RSP:OK)l: 20 T:1d : 6 dc07
    CMD: 9802(GET_OBJECT_PROP_DESC)l: 20 T:1e : dc0b 3001 (PARENT)
    RESP:2001(RSP:OK)l: 20 T:1e : dc0b 3001
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1f : 6 dc0b (PARENT)
    RESP:2001(RSP:OK)l: 20 T:1f : 6 dc0b
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:20 : 6 dc41 (PERSISTENT_UID)
    RESP:2001(RSP:OK)l: 20 T:20 : 6 dc41
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:21 : 6 dc44 (NAME)
    RESP:2001(RSP:OK)l: 20 T:21 : 6 dc44
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:22 : 6 dc03 (PROTECTION)
    RESP:2001(RSP:OK)l: 20 T:22 : 6 dc03
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:23 : 6 dc04 (SIZE)
    RESP:2001(RSP:OK)l: 20 T:23 : 6 dc04
    CMD: 1008(GET_OBJECT_INFO)l: 16 T:24 : 6
    RESP:2001(RSP:OK)l: 16 T:24 : 6
    CMD: 1007(GET_OBJECT_HANDLES)l: 24 T:25 : 30001 0 6
    RESP:2001(RSP:OK)l: 24 T:25 : 30001 0 6
    CMD: 100c(SEND_OBJECT_INFO)l: 20 T:26 : 30001 6
    DATA:100c(SEND_OBJECT_INFO)l: 164 T:26 : 0 3000 e2e75 3000 0
    SendObjectInfo: 196609 6 20005400: 0 3000 0 e2e75 3000 0 0 0 0 0 0 0 0 0 0 : AN12253.pdf
    Read DateTime string: 20210407T081045.0
    >> date: 5287 2021 4 7
    >> time: 4156 8 10 45
    Created: 5287 4156
    Read DateTime string: 20210209T232116.0
    >> date: 5249 2021 2 9
    >> time: baa8 23 21 16
    Modified: 5249 baa8
    RESP:2001(RSP:OK)l: 24 T:26 : 30001 6 7
    CMD: 100d(SEND_OBJECT)l: 12 T:27
    MTPD::SendObject: len:929397
     # USB Packets: 1815 total: 11 avg ms: 0 max: 1
     # Write: 114 total:76 avg ms: 0 max: 1
    >>>Total Time: 106699
    RESP:2001(RSP:OK)l: 12 T:27
    CMD: 9802(GET_OBJECT_PROP_DESC)l: 20 T:28 : dc44 3000 (NAME)
    RESP:2001(RSP:OK)l: 20 T:28 : dc44 3000
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:29 : 7 dc02 (FORMAT)
    RESP:2001(RSP:OK)l: 20 T:29 : 7 dc02
    CMD: 9802(GET_OBJECT_PROP_DESC)l: 20 T:2a : dc01 3000 (STORAGE_ID)
    RESP:2001(RSP:OK)l: 20 T:2a : dc01 3000
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:2b : 7 dc01 (STORAGE_ID)
    RESP:2001(RSP:OK)l: 20 T:2b : 7 dc01
    CMD: 9802(GET_OBJECT_PROP_DESC)l: 20 T:2c : dc07 3000 (OBJECT NAME)
    RESP:2001(RSP:OK)l: 20 T:2c : dc07 3000
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:2d : 7 dc07 (OBJECT NAME)
    RESP:2001(RSP:OK)l: 20 T:2d : 7 dc07
    CMD: 9802(GET_OBJECT_PROP_DESC)l: 20 T:2e : dc0b 3000 (PARENT)
    RESP:2001(RSP:OK)l: 20 T:2e : dc0b 3000
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:2f : 7 dc0b (PARENT)
    RESP:2001(RSP:OK)l: 20 T:2f : 7 dc0b
    CMD: 9802(GET_OBJECT_PROP_DESC)l: 20 T:30 : dc41 3000 (PERSISTENT_UID)
    RESP:2001(RSP:OK)l: 20 T:30 : dc41 3000
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:31 : 7 dc41 (PERSISTENT_UID)
    RESP:2001(RSP:OK)l: 20 T:31 : 7 dc41
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:32 : 7 dc44 (NAME)
    RESP:2001(RSP:OK)l: 20 T:32 : 7 dc44
    CMD: 9802(GET_OBJECT_PROP_DESC)l: 20 T:33 : dc03 3000 (PROTECTION)
    RESP:2001(RSP:OK)l: 20 T:33 : dc03 3000
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:34 : 7 dc03 (PROTECTION)
    RESP:2001(RSP:OK)l: 20 T:34 : 7 dc03
    CMD: 9802(GET_OBJECT_PROP_DESC)l: 20 T:35 : dc04 3000 (SIZE)
    RESP:2001(RSP:OK)l: 20 T:35 : dc04 3000
    CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:36 : 7 dc04 (SIZE)
    RESP:2001(RSP:OK)l: 20 T:36 : 7 dc04
    CMD: 1008(GET_OBJECT_INFO)l: 16 T:37 : 7
    RESP:2001(RSP:OK)l: 16 T:37 : 7
    CMD: 100c(SEND_OBJECT_INFO)l: 20 T:38 : 30001 6
    DATA:100c(SEND_OBJECT_INFO)l: 172 T:38 : 0 3000 11a470 3000 0
    SendObjectInfo: 196609 6 20005400: 0 3000 0 11a470 3000 0 0 0 0 0 0 0 0 0 0 : aoyue-8032a.pdf
    Read DateTime string: 20210407T081046.0
    >> date: 5287 2021 4 7
    >> time: 4157 8 10 46
    Created: 5287 4157
    Read DateTime string: 20181103T091507.0
    >> date: 4d63 2018 11 3
    >> time: 49e3 9 15 7
    Modified: 4d63 49e3
    3. Deleted the directory that was just created - turned TMM off and the back on and the directory was gone.
    Unfortunately didn't have the SD Card attached have to do that next.
  2. #477
    Senior Member wwatson's Avatar
    Aug 2017
    426
    @All - I have been working on an upper level IF to @Kurte's and @mjs513's hard work on UsbMscFat.
    I wanted to:
    1) Find and initialize all available Mass Storage devices connected to the Teensy.
    2) Create an index to those devices using a logical device number and use a static index variable as the current default device which can be changed with a change drive method.
    3) Store information about the current device in a struct array to be used with other methods:
    typedef struct {
    	char		name[32];        // Volume name as a logical drive name.
    	uint8_t		driveNumber = 0; // Physical drive number.
    	uint8_t		ldNumber = 0;    // Logical drive number.
    	bool		valid = false;   // If true device is connected and mounted.
    	uint8_t		driveType;       // USB, SDHC or SDHX
    	uint8_t		fatType = 0;     // FAT32 or ExFat
    	char            currentPath[256];    // Current default path spec.
    } deviceDecriptorEntry_t;
    4) Process relative path specs such as '../' to create an absolute path spec.
    5) Process wildcards.
    6) Process mounting and un-mounting of devices.
    So far I have change drive and change directory functions that are working with 1,2,3,4 and 5. I spent a lot of time on the Internet hunting down examples of processing wildcards and converting relative path spec to absolute path specs. There were a couple of them that I am modeling after:
    https://stackoverflow.com/questions/...lute-path-in-c
    and:
    https://github.com/sparkfun/OpenLog
    This last link has a function called 'lsPrint()' that calls 'lsPrintNext() that calls a function that processes wildcards.
    I guess what I am saying is I don't want to put a whole lot of useless effort into this if it is not something that would be useful at this time
    Here is a sample output for what I have so far:
    mscFSTesting
    Waiting up to 5 seconds for a USB drives
    Initialize USB drive 0...
    Initialize USB drive 1...
    Initialize USB drive 2...
    Initialize SDIO SD card...
    Initialize SPI SD card...
    Logical Drive Information For Attached Drives
    Physical Drive #: 0 | Logical Drive #: 0 | Volume Label:  16GEXFATP1 | valid: 1 | Drive Type: USB
    Physical Drive #: 0 | Logical Drive #: 1 | Volume Label:  16GEXFATP2 | valid: 1 | Drive Type: USB
    Physical Drive #: 1 | Logical Drive #: 2 | Volume Label:   128GFAT32 | valid: 1 | Drive Type: USB
    Physical Drive #: 2 | Logical Drive #: 3 | Volume Label:    32GEXFAT | valid: 1 | Drive Type: USB
    Physical Drive #:10 | Logical Drive #: 4 | Volume Label:  32GSDEXFAT | valid: 1 | Drive Type: SDHC/SDXC
    Physical Drive #:11 | Logical Drive #: 5 | Volume Label:  TEENSY8GSD | valid: 1 | Drive Type: SDHC/SDXC
    Changed To Logical Drive: 2 (128GFAT32)
    parsePathSpec(const char *pathSpec) returns:
    depth = 1
    pathSpec = /
    pathOut = /
    Changed Logial Drive/Directory To: 128GFAT32/
    Directory Listing for Logical Drive 2: 128GFAT32/
    Arduino/
    A_00001.dat        32768000
    depth = 3
    pathSpec = /ChRt/src/teensy4/../arm
    pathOut = /ChRt/src/arm
    Changed Logial Drive/Directory To: 32GSDEXFAT/ChRt/src/arm
    Directory Listing for Logical Drive 4: 32GSDEXFAT/ChRt/src/arm/
    chcore.h        6993
    chcore_timer.h        3737
    chcore_v6m.c        5349
    chcore_v6m.h        14491
    chcore_v7m.c        6448
    chcore_v7m.h        22460
    chcoreasm_v6m.S        4908
    chcoreasm_v7m.S        5453
    chtypes.h        3208
    cmparams.h        504
    mpu.h        9587
    Directory Listing for Logical Drive 4: 32GSDEXFAT/ChRt/src/arm/*.h
    chcore.h        6993
    chcore_timer.h        3737
    chcore_v6m.h        14491
    chcore_v7m.h        22460
    chtypes.h        3208
    cmparams.h        504
    mpu.h        9587
    Directory Listing for Logical Drive 4: 32GSDEXFAT/ChRt/src/arm/*_???.*
    chcore_v6m.c        5349
    chcore_v6m.h        14491
    chcore_v7m.c        6448
    chcore_v7m.h        22460
    done...
    It's still a lot of fun playing with this stuff
