Many TLAs: MTP MSC FS SD SDFat LittleFS UsbMSCFat to work with each other 8)
@KurtE
Saw what you meant so made I change. Now after formatting in windows the FAT32 volume:
msc # Partition Table
	part,boot,bgnCHS[3],type,endCHS[3],start,length
FAT16:	1,0,0x20,0x21,0x0,0xE,0x13,0x28,0xEB,2048,3774464
FAT32:	2,0,0x13,0x29,0xEB,0xC,0x1B,0x8D,0xCE,3776512,7759872
exFAT:	3,0,0x1B,0x8E,0xCE,0x7,0xFE,0xFF,0xFF,11536384,109608960
pt_#0:	4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
PFsVolume::begin USBmscInterface(20002a54, 1)
PFsVolume::begin(20002a54, 1)
Partition 0 valid:1
PFsVolume::begin USBmscInterface(20002a54, 2)
PFsVolume::begin(20002a54, 2)
Partition 1 valid:1
PFsVolume::begin USBmscInterface(20002a54, 3)
PFsVolume::begin(20002a54, 3)
Partition 2 valid:1
PFsVolume::begin USBmscInterface(20002a54, 4)
PFsVolume::begin(20002a54, 4)
Partition 3 valid:0
0:>> Fat16: Volume name:(FAT16)###PFsVolume::freeClusterCount: FT:16
    m_sectorsPerCluster:64
    m_sectorsPerClusterShift:6
    m_rootDirEntryCount:512
    m_sectorsPerFat:231
    m_dataStartSector:2544
    m_fatStartSector:2050
    m_rootDirStart:2512
    m_bytesPerSector:512
 Partition Total Size:1932263424 Used:98304 time us: 14873
    Free Clusters: API: 58965 by CB:58965 time us: 14742
    Free Clusters: Info: 4294967295 time us: 0
1:>> Fat32: Volume name:(FAT32)###PFsVolume::freeClusterCount: FT:32
    m_sectorsPerCluster:8
    m_sectorsPerClusterShift:3
    m_rootDirEntryCount:0
   [COLOR="#FF0000"] m_sectorsPerFat:7563[/COLOR]
    m_dataStartSector:3792896
    m_fatStartSector:3777770
    [COLOR="#FF0000"]m_rootDirStart:2[/COLOR]
 Partition Total Size:3964665856 Used:16384 time us: 472998
    Free Clusters: API: 967932 by CB:967932 time us: 472992
    Free Clusters: Info: 967932 time us: 1118
2:>> ExFat: Volume name:(exFAT1) Partition Total Size:56116641792 Used:786432 time us: 39376
    Free Clusters: API: 428130 by CB:0 time us: 1
done...
and after formatting with MSCFormatter sketch:
FAT32:	2,0,0x28,0x69,0xD4,0xB,0xFE,0xFF,0xFF,3776512,7759872
Partition 0 valid:1
Partition 1 valid:1
Partition 2 valid:1
Partition 3 valid:0
    m_sectorsPerFat:231
    m_rootDirStart:2512
[/COLOR]    m_dataStartSector:3792896
[COLOR="#FF0000"]    m_rootDirStart:2
[/COLOR]    m_bytesPerSector:512
 Partition Total Size:3964665856 Used:32768 time us: 59373
    Free Clusters: API: 120991 by CB:120991 time us: 59367
    Free Clusters: Info: 4294967295 time us: 1118
    Free Clusters: API: 428130 by CB:0 time us: 0
done...
formatting looked like this:
Initialize USB drive...UsbBase::mscBegin called 200045a0 1 1
    After usbDriveBegin
USB drive 1 is present.
Partition 1 valid:1
1
Volume name:(FAT32)
PFsFatFormatter::format................
Sector Count: 7759872, Sectors/MB: 2048
Partition Capacity (MB): 3789
Fat Type: 32
    m_dataStart:3792896
    m_relativeSectors:3776512
    m_sectorsPerFat: 7563
 MAKEFAT32
    m_sectorCount: 7759872
    m_dataStart: 3792896
    m_sectorsPerCluster: 64
    nc: 61984
    m_fatSize: 7563
m_fatSize: 7563
partType: 11, fatStart: 3777770, totalSectors: 7759872
Writing FAT ................................
free clusters after format: 967932
free clusters after begin on partVol: 120991
Format Done
Better?
Part 2
Basically I added this to the format function:
 	m_fatSize = partVol.getFatVol()->sectorsPerFat();
and commented out the calculating m_fatSize in makeFat32.
@mjs513 I think that helped out a lot... Also my fix to do the reinitialize the portVol is also fixing the issues with
other corruptions including the setting the volume label.
As before that it was relying on using cached data which is no longer valid.
Would you like to do a PR back to me with your changes?
Note: some of the same changes probably needed in the Ex version as well!.
@KurtE
Have to reset up my repository - just been downloading your changes. Will do the PR - doing some chores right now.
As for exFAT - there are other issues. Right now I am pulling directly from existing partVol values to set up the partition. But when I do 2 exFAT volumes getting FS not found or Overlaping of the sectors. Still trying to sort that out. Worked my way down through about half of whats needed (right now at // Write cluster three, upcase table). Lots of reading. Not as easy as FAT
@mjs513 - I finally had time to download the latest VolumeName_SD branch of your UsbMscFat. Tried out MSCFormatter.ino and noticed the following.
Cards up to 2 GiB (GiB = 2^30 bytes) will be formated FAT16.
Cards larger than 2 GiB and up to 32 GiB will be formatted
FAT32. Cards larger than 32 GiB will be formatted exFAT.
Waiting up to 5 seconds for USB drive 1
Initialize USB drive...UsbBase::mscBegin called 20003c60 1 1
    After usbDriveBegin
PFsVolume::begin USBmscInterface(2000211c, 1)
PFsVolume::begin(2000211c, 1)
exFAT:	1,0,0x20,0x21,0x0,0x7,0xFE,0xFF,0xFF,2048,30216192
pt_#0:	2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
pt_#0:	3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
Partition 0 valid:1
PFsVolume::begin USBmscInterface(2000211c, 2)
PFsVolume::begin(2000211c, 2)
Partition 1 valid:0
PFsVolume::begin USBmscInterface(2000211c, 3)
PFsVolume::begin(2000211c, 3)
Partition 2 valid:0
PFsVolume::begin USBmscInterface(2000211c, 4)
PFsVolume::begin(2000211c, 4)
Partition 3 valid:0
0:>> ExFat: Volume name:(EXFATP1) Partition Total Size:15468724224 Used:131072 time us: 45249
    Free Clusters: API: 472064 by CB:0 time us: 0
done...
Enter 0, 1 , 2, or 3 for Partition or Enter to Bypass
    After usbDriveBegin
Partition 0 valid:1
ExFatFormatter - WIP
0
    m_relativeSectors:2048
    m_clusterHeapStartSector: 5888
    m_fatLength: 3712
    m_fatStartSector: 2176
    m_fatType: 64
    m_clusterCount: 472068
    m_totalSectors: 30216192
    m_bytesPerSector: 512
    [COLOR="#FF0000"]m_bytesPerCluster: 512[/COLOR]
    m_rootDirectoryCluster: 5
    m_bytesPerSectorShift: 9
Press any key to run again
In PFsExFatFormatter.cpp I did this modification:
  #if defined(DBG_PRINT)
	Serial.printf("    m_sectorsPerCluster:%u\n", partVol.sectorsPerCluster());
	Serial.printf("    m_sectorsPerClusterShift:%u\n", partVol.getExFatVol()->sectorsPerClusterShift());
	Serial.printf("    m_relativeSectors:%u\n", getLe32(pt->relativeSectors));
	Serial.printf("    m_clusterHeapStartSector: %u\n", partVol.getExFatVol()->clusterHeapStartSector() );
	Serial.printf("    m_fatLength: %u\n", partVol.getExFatVol()->fatLength());
	Serial.printf("    m_fatStartSector: %u\n", partVol.fatStartSector());
	Serial.printf("    m_fatType: %d\n", partVol.fatType());
	Serial.printf("    m_clusterCount: %u\n", partVol.clusterCount());
	Serial.printf("    m_totalSectors: %u\n", sectorCount);
	Serial.printf("    m_bytesPerSector: %u\n", partVol.getExFatVol()->bytesPerSector());
	[COLOR="#FF0000"]Serial.printf("    m_bytesPerCluster: %u\n", partVol.getExFatVol()->bytesPerCluster());[/COLOR]
//	Serial.printf("    m_bytesPerCluster: %u\n", partVol.getExFatVol()->bytesPerSector());
	Serial.printf("    m_rootDirectoryCluster: %u\n", partVol.getExFatVol()->rootDirectoryCluster());
	Serial.printf("    m_bytesPerSectorShift: %u\n", partVol.getExFatVol()->bytesPerSectorShift());
Then it returned this:
    After usbDriveBegin
Partition 0 valid:1
Partition 1 valid:0
Partition 2 valid:0
Partition 3 valid:0
done...
    After usbDriveBegin
Partition 0 valid:1
0
    m_fatLength: 3712
    m_fatType: 64
    [COLOR="#FF0000"]m_bytesPerCluster: 32768[/COLOR]
I am wondering if this might have thrown you off in your calculations or was just a typo. Should have more time to work with ExFat this weekend.
@mjs513 will have more answers for this part. I have not spent much time looking into the ExFat stuff. Spent the last couple of days helping track down a few issues with Fat. Like why volume name was not preserved and the Fat32 stuff had issue where the data did not match... I think they are both working better now.
Hopefully the two of you will soon have it all figured out... Hurts my head :D . So I will probably spend some more time trying to get some more MTP stuff figured out
@wwatson
Just caught that one a little while ago as well - just a typo as the actual assignment is in:
sectorsPerCluster = partVol.sectorsPerCluster();
Right now when I try to format 2 separate exFAT partitions I keep getting FS not recognized. Rethinking a few things as I do more reading and getting better understanding of what SDFAT does.
@KurtE - exFAT giving me a headache as well. Glad at least FAT looks like its working.
@KurtE - A quick question. Was MTP with Linux ever proven to to work with anything else except the SDIO drive? I am using Paul's breakout board with the memory board and the SPI audio board with an SD card and one USB thumb stick no HUB. T4.1. Have updated to your latest MTP code. What I am getting is 9 different devices in Linux. But Only the SDIO card is recognized and shows the directory in the file manager. Upon startup I get 8 warning popups that say:
"Error: initializing camera -53 could not claim the USB device." There are eight of these error messages.The only device that shows up is 'gphoto2://%5Busb%3A001,005%5D/store_00000001' and that is the native SDIO port on the T4.1.
Can copy files back and forth and delete but with error messages. I/O errors even though them seem to complete. If I remove the SDIO SD card nothing shows a directory (the other 8 devices). It seems that only the SDIO device is recognized.
I have probably missed something in the MTP thread.
@wwatson
Again with Linux using MSCFormatter.ino I was getting an error stating that the ExFat 'partition was out side of disk' whatever that means. Maybe formatting parameters I don't know at this time. But now, with Linux I have created two partitions one ExFat and one FAT32 and then two partitions after testing that are ExFat. I cannot get it to fail... I can copy files to and from the thumb drive without error. The only thing that changes is the volume name disappears. I have powered down and up, uploaded the sketch and tried a reset. It still is working????
I downloaded your latest UsbMscFat library and am using that. I think it is time to check out a Linux formatted ExFat layout and an MSCFormatted drive layout.
It's late. time for.......
@wwatson
Ran into similar issue - if i created 2 exFAT partitions on a thumb drive and the reformated with MSCFormatter WinExplorer wouldn't read it but MTP would? Has to be something off with the layout as you said and where things are going that Windows doesn't like and I just can't figure it out.
I've looked at with WinHex and using its exFAT templates it looks like it should work. WinHex keeps telling bad parameter/can not find FS?
Right now I've been staring at it and reading specs that think I am getting my self confused. Maybe with your fresh pair of eyes you can see it.
@wwatson and @mjs513 - reworked a thumb drive to have two exfat partitions. Then as you mentioned I used the MSCFormatter and MTP could read it. But windows could not read the second one.
Another interesting point, I then plugged it into my Ubuntu 20.04 machine and it could read it. dmesg does not give any information about issues. It simply says two messages:
[EXFAT] trying to mount...
followed by two messages:
[EXFAT] mounted successfully
Interesting stuff on the website: https://www.diskpart.com/windows-10/exfat-drive-not-recognized-windows-10-4125.html
ExFAT, is also compatible with Windows and Mac. Compared with FAT32, exFAT doesn’t have the limitations of FAT32. Thus, many users would prefer the exFAT file system to compatible with both Windows and Mac.
However, like the Scenario said, Windows can’t normally read Mac-formatted drives. If you formatted your drive in exFAT with Apple’s HFS Plus, the exFAT drive cannot be read by Windows in default even though the exFAT file system is compatible with both Mac and Windows. In fact, some manufacturers sell “Mac drives” pre-formatted with this Mac-only file system.
Of course they are trying to sell their own utility. Wonder what the issue is?
@KurtE - @wwatson
Have no idea what's going on either. Anyway right now if I format both ~32mb exfat partitions it seems to be now working on the first partition but failing on the second exfat partition. If I going into winhex the windows formatted 2nd partition MBR looks like this:
and after formatting with MSCFormatter:
Looks the same to me. Have to be missing something.
EDIT: Heres the dump from MSC FOrmatter:
Initialize USB drive...UsbBase::mscBegin called 200045e0 1 1
    After usbDriveBegin
PFsVolume::begin USBmscInterface(20002a9c, 1)
PFsVolume::begin(20002a9c, 1)
exFAT:	1,0,0x20,0x21,0x0,0x7,0xFE,0xFF,0xFF,2048,117270528
exFAT:	2,0,0xFE,0xFF,0xFF,0x7,0xFE,0xFF,0xFF,117272576,124751872
Partition 0 valid:1
PFsVolume::begin USBmscInterface(20002a9c, 2)
PFsVolume::begin(20002a9c, 2)
Partition 1 valid:1
PFsVolume::begin USBmscInterface(20002a9c, 3)
PFsVolume::begin(20002a9c, 3)
Partition 2 valid:0
PFsVolume::begin USBmscInterface(20002a9c, 4)
PFsVolume::begin(20002a9c, 4)
Partition 3 valid:0
0:>> ExFat: Volume name:(t2) Partition Total Size:60039364608 Used:786432 time us: 43502
    Free Clusters: API: 458058 by CB:0 time us: 0
1:>> ExFat: Volume name:(t1) Partition Total Size:63869812736 Used:786432 time us: 46128
    Free Clusters: API: 487282 by CB:0 time us: 0
done...
    After usbDriveBegin
Partition 0 valid:1
0
    m_sectorsPerCluster:256
    m_sectorsPerClusterShift:8
    m_clusterHeapStartSector: 8192
    m_fatLength: 3584
    m_fatStartSector: 4096
    m_fatType: 64
    m_clusterCount: 458064
    m_totalSectors: 117270528
    m_bytesPerCluster: 131072
    m_rootDirectoryCluster: 4
VS: 27
sectorsPerClusterShift: 8,
 sectorsPerCluster: 256,
 fatLength 3584
fatOffset: 2048,
 partitionOffset: 2048
clusterHeapOffset: 6144,
 clusterCount: 458064,
 volumeLength 117270528
cluster 2 bitmap: 8192
Up case table: 8448
    m_totalSectors:117270528
Writing Partition Boot Sector
pbs->bpb.volumeSerialNumber: 117270528
	Writing Sector: 0
Write eight Extended Boot Sectors
	Writing Sector: 1
Write OEM Parameter Sector and reserved sector
	Writing Sector: 9
Write Boot CheckSum Sector
	Writing Sector: 11
Writing exFAT 	Writing Sector: 2048, ns: 3579
Write cluster two, bitmap
	Writing Sector: 6144
(Original) bitmapSize: 57258, ns: 112
Writing upcase table
	Writing Sector: 6400
Writing root
	Writing 1st Sector of root: 6656
Format done
    After usbDriveBegin
Partition 0 valid:1
Partition 1 valid:1
Partition 2 valid:0
Partition 3 valid:0
0:>> ExFat:  Partition Total Size:60039364608 Used:44433408 time us: 43504
    Free Clusters: API: 457725 by CB:0 time us: 0
done...
    After usbDriveBegin
Partition 1 valid:1
1
    m_relativeSectors:117272576
    m_clusterHeapStartSector: 117278720
    m_fatLength: 3840
    m_fatStartSector: 117274624
    m_fatType: 64
    m_clusterCount: 487288
    m_totalSectors: 124751872
VS: 27
 fatLength 3840
fatOffset: 2048,
 partitionOffset: 117272576
 clusterCount: 487288,
 volumeLength 124751872
cluster 2 bitmap: 117278720
Up case table: 117278976
    m_totalSectors:124751872
pbs->bpb.volumeSerialNumber: 124751872
	Writing Sector: 0
	Writing Sector: 1
	Writing Sector: 9
	Writing Sector: 11
Writing exFAT 	Writing Sector: 2048, ns: 3807
(Original) bitmapSize: 60911, ns: 119
Writing root
Format done
Good morning. For the heck of it I hacked up the sketch that after it reads in and prints out all of the partitions, it then loops through again and prints out the main debug information that the
ExFormatter prints out... Again I have not looked at the data yet...
But here is a run, where I had first formatted the two partitions on windows so should have been readable and then format 0 and then format 1...
Not much differences in output between the passes: Here is with most of the other data edited out:
*************** Fresh formatted by windows *******************************
exFAT:	1,0,0x20,0x21,0x0,0x7,0xFE,0xFF,0xFF,2048,8192000
exFAT:	2,0,0xE,0x51,0xFE,0x7,0xFE,0xFF,0xD2,8194048,7534592
    Part:1
    m_clusterHeapStartSector: 3200
    m_fatLength: 1024
    m_fatType: 64
    m_clusterCount: 127982
    m_totalSectors: 8192000
    Part:2
    m_relativeSectors:8194048
    m_clusterHeapStartSector: 8195200
    m_fatLength: 960
    m_fatStartSector: 8194176
    m_fatType: 64
    m_clusterCount: 117710
    m_totalSectors: 7534592
*************** (after 0 entered to format)  *******************************
    Part:1
    m_fatLength: 1024
    m_fatType: 64
    Part:2
    m_fatLength: 960
    m_fatType: 64
*************** (after 1 entered to format)  *******************************
exFAT:	2,0,0x20,0x21,0x0,0x7,0xFE,0xFF,0xFF,8194048,7534592
    Part:1
    m_fatLength: 1024
    m_fatType: 64
    Part:2
    m_fatLength: 960
    m_fatType: 64
done...
The only thing I noticed in the differences was in the MBR:
changed to:
Morning as well
So concentrated and figuring out what's going that I am forgetting what day it is :)
Any yeah that is to me expected. SDFat has it hardcoded into the formatting code:
  pt->beginCHS[0] = 0x20;
  pt->beginCHS[1] = 0x21;
  pt->beginCHS[2] = 0;
  pt->type = 7;
  pt->endCHS[0] = 0XFE;
  pt->endCHS[1] = 0XFF;
  pt->endCHS[2] = 0XFF;
Don't think it makes much of a difference but could be wrong.
Maybe, but I may try it as if you look at the FatFormatter it has the option on
bool PFsFatFormatter::writeMbr() {
  memset(m_secBuf, 0, BYTES_PER_SECTOR);
  MbrSector_t* mbr = reinterpret_cast<MbrSector_t*>(m_secBuf);
  MbrPart_t *pt = &mbr->part[m_part];
  if (!m_dev->readSector(0, m_secBuf)) {
	writeMsg("Didn't read MBR Sector !!!\n");
	return false;
[COLOR="#B22222"]#if USE_LBA_TO_CHS[/COLOR]
  lbaToMbrChs(pt->beginCHS, m_capacityMB, m_relativeSectors);
  lbaToMbrChs(pt->endCHS, m_capacityMB,
              m_relativeSectors + m_totalSectors -1);
#else  // USE_LBA_TO_CHS
  pt->beginCHS[0] = 1;
  pt->beginCHS[1] = 1;
#endif  // USE_LBA_TO_CHS
  pt->type = m_partType;
  setLe32(pt->relativeSectors, m_relativeSectors);
  setLe32(pt->totalSectors, m_totalSectors);
  setLe16(mbr->signature, MBR_SIGNATURE);
  return m_dev->writeSector(0, m_secBuf);
So I may try that in ex... as well it is different ... And who knows could be lucky :D
I did a quick and dirty:
Where if our relative sectors and total don't change then don't update those fields:
  uint32_t cur_rel_sectors = getLe32(pt->relativeSectors);
  uint32_t cur_tot_sectors = getLe32(pt->totalSectors);
  if ((cur_rel_sectors != partitionOffset) || (cur_tot_sectors != volumeLength)) {
Ran it, looks like the MBR is now the same... Windows Still does not like it :eek:
Didn't think it would make a difference but it was worth a try. :) now off to another house project for a bit :(
And now something completely different :D
As I mentioned after you formatted the exFat, my Ubuntu machine did not appear to have problems with it.
So then started wondering about wonder about the 24 sector BPB as mentioned in https://events.static.linuxfound.org/images/stories/pdf/lceu11_munegowda_s.pdf
Where there is backup version... Wondering if maybe they are different and/or for example we may not look at it, but windows maybe does...
So I hacked up the sketch yet some more, to allow me to type in D0
To dump the 0 Fat ...
And I read in and print out those 24 sectors. I also read them in 12 sector chunks and used a different dump for second have where it compares the sector to the "primary one" and if a byte is different it shows
with a preceding *
So here is a run right after I reformatted the drives on Windows:
Initialize USB drive...UsbBase::mscBegin called 20004120 1 1
    After usbDriveBegin
PFsVolume::begin USBmscInterface(200025e4, 1)
PFsVolume::begin(200025e4, 1)
PFsVolume::begin USBmscInterface(200025e4, 2)
PFsVolume::begin(200025e4, 2)
Partition 1 valid:1
Sector 0(8194048)
EB 76 90 45 58 46 41 54 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 :.v.EXFAT   .....................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 :................................
00 08 7D 00 00 00 00 00 00 F8 72 00 00 00 00 00 80 00 00 00 C0 03 00 00 80 04 00 00 CE CB 01 00 :..}.......r.....................
04 00 00 00 05 35 DC 90 00 01 00 00 09 06 01 80 00 00 00 00 00 00 00 00 33 C9 8E D1 8E C1 8E D9 :.....5..................3.......
BC D0 7B BD 00 7C 88 16 6F 7C B4 41 BB AA 55 CD 13 72 69 81 FB 55 AA 75 63 F6 C1 01 74 5E FE 06 :..{..|..o|.A..U..ri..U.uc...t^..
02 7C 66 50 B0 65 E8 A6 00 66 58 66 B8 01 00 00 00 8A 0E 6D 7C 66 D3 E0 66 89 46 E8 66 B8 01 00 :.|fP.e...fXf.......m|f..f.F.f...
00 00 8A 0E 6C 7C 66 D3 E0 66 89 46 D8 66 A1 40 7C 66 40 BB 00 7E B9 01 00 66 50 E8 41 00 66 58 :....l|f..f.F.f.@|f@..~...fP.A.fX
66 40 BB 00 80 B9 01 00 E8 34 00 66 50 B0 78 E8 5D 00 66 58 E9 09 01 A0 FC 7D EB 05 A0 FB 7D EB :f@.......4.fP.x.].fX.....}....}.
00 B4 7D 8B F0 AC 98 40 74 0C 48 74 0E B4 0E BB 07 00 CD 10 EB EF A0 FD 7D EB E6 CD 16 CD 19 66 :..}....@t.Ht............}......f
60 66 6A 00 66 50 06 53 66 68 10 00 01 00 B4 42 B2 80 8A 16 6F 7C 8B F4 CD 13 66 58 66 58 66 58 :`fj.fP.Sfh.....B....o|....fXfXfX
66 58 66 61 72 B1 03 5E D8 66 40 49 75 D1 C3 66 60 B4 0E BB 07 00 B9 01 00 CD 10 66 61 C3 42 00 :fXfar..^.f@Iu..f`..........fa.B.
4F 00 4F 00 54 00 4D 00 47 00 52 00 0D 0A 52 65 6D 6F 76 65 20 64 69 73 6B 73 20 6F 72 20 6F 74 :O.O.T.M.G.R...Remove disks or ot
68 65 72 20 6D 65 64 69 61 2E FF 0D 0A 44 69 73 6B 20 65 72 72 6F 72 FF 0D 0A 50 72 65 73 73 20 :her media....Disk error...Press
61 6E 79 20 6B 65 79 20 74 6F 20 72 65 73 74 61 72 74 0D 0A 00 00 00 00 00 00 00 00 00 00 FF FF :any key to restart..............
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF :................................
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 6C 8B 98 55 AA :...........................l..U.
Sector 1(8194049)
66 50 B0 46 E8 48 FF 66 58 66 A1 40 7C 66 03 06 58 7C 66 89 46 FC 66 C7 46 F8 FF FF FF FF 66 A1 :fP.F.H.fXf.@|f..X|f.F.f.F.....f.
60 7C 66 83 F8 02 0F 82 D2 FE 66 3D F8 FF FF 0F 0F 83 C8 FE C6 46 EF 01 66 50 66 83 E8 02 66 8B :`|f.......f=.........F..fPf...f.
5E E8 66 8B CB 66 8B F3 66 F7 E3 66 03 46 FC 66 50 66 BB 00 82 00 00 66 8B FB 66 B9 01 00 00 00 :^.f..f..f..f.F.fPf.....f..f.....
E8 BC FE 80 3D 00 0F 84 0D 01 80 7E EF 01 0F 84 13 00 80 7E EF 02 0F 84 23 00 80 7E EF 03 0F 84 :....=......~.......~....#..~....
8B 00 E9 F2 00 80 3D 85 0F 85 C0 00 8B 45 04 25 10 00 0F 85 B6 00 C6 46 EF 02 E9 AF 00 80 3D C0 :......=......E.%.......F......=.
0F 85 A4 00 66 8B 45 14 66 89 46 F0 66 53 66 8B 45 18 66 8B 5E D8 66 4B 66 03 C3 66 F7 D3 66 23 :....f.E.f.F.fSf.E.f.^.fKf..f..f#
C3 66 89 46 E4 66 5B 66 C7 46 E0 00 00 00 00 8A 45 01 88 46 DC 24 02 0F 84 25 00 66 B8 01 00 00 :.f.F.f[f.F......E..F.$...%.f....
00 8A 0E 6D 7C 02 0E 6C 7C 66 D3 E0 66 48 66 53 66 8B 5D 18 66 03 C3 66 5B 66 D3 E8 66 89 46 E0 :...m|..l|f..fHfSf.].f..f[f..f.F.
8A 45 03 3C 07 75 41 C6 46 EF 03 EB 3F 80 3D C1 75 36 66 50 66 53 66 57 83 C7 02 BB 07 00 8B 05 :.E.<.uA.F...?.=.u6fPfSfW........
25 DF FF 89 05 83 C7 02 4B 75 F3 66 5F 66 5B 66 58 66 57 83 C7 02 B9 07 00 66 56 BE 5E 7D F3 A7 :%.......Ku.f_f[fXfW......fV.^}..
66 5E 66 5F 0F 84 B8 00 C6 46 EF 01 66 83 C7 20 66 3B FB 0F 82 0C FF 66 58 66 40 4E 0F 85 EF FE :f^f_.....F..f.. f;.....fXf@N....
66 58 66 52 66 53 66 33 D2 66 33 DB E8 3D 01 66 5B 66 5A 0F 82 C1 FE 83 C4 04 E9 7F FD 00 20 00 :fXfRfSf3.f3..=.f[fZ........... .
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA :..............................U.
Sector 2(8194050)
66 50 B0 41 E8 48 FD 66 58 83 C4 04 8B 76 F2 8B 7E F0 8B C6 66 C1 E0 10 8B C7 66 83 F8 02 0F 82 :fP.A.H.fX....v..~...f.....f.....
DA FC 66 83 F8 F8 0F 83 D2 FC 66 50 66 83 E8 02 66 8B 4E E8 66 F7 E1 66 03 46 FC 66 51 66 B9 01 :..f.......fPf...f.N.f..f.F.fQf..
00 00 00 BB 00 00 06 8E 06 7D 7F E8 D1 FC 07 C1 EB 04 01 1E 7D 7F 66 8B 4E E4 66 2B 4E D8 66 89 :.........}..........}.f.N.f+N.f.
4E E4 66 83 F9 00 0F 84 24 00 66 59 66 49 75 CB 66 58 66 53 66 52 8A 5E DC 66 8B 56 E0 E8 2C 00 :N.f.....$.fYfIu.fXfSfR.^.f.V..,.
66 89 56 E0 66 5A 66 5B 0F 83 02 00 EB 9C 50 B0 54 E8 BB FC 58 8B 46 D8 A3 0B 7C 66 A1 40 7C 66 :f.V.fZf[......P.T...X.F...|f.@|f
A3 1C 7C 8A 16 6F 7C EA 00 00 00 20 F6 C3 02 0F 85 0C 00 E8 23 00 26 66 8B 01 66 83 F8 F8 C3 66 :..|..o|.... ........#.&f..f....f
83 FA 00 0F 84 06 00 66 40 66 4A F9 C3 66 B8 F8 FF FF FF 66 83 F8 F8 F8 C3 66 52 BF 00 82 66 33 :.......f@fJ..f.....f.....fR...f3
D2 66 53 66 8B 5E D8 66 C1 EB 02 66 F7 F3 66 5B 66 3B 46 F8 74 41 66 89 46 F8 66 03 06 40 7C 66 :.fSf.^.f...f..f[f;F.tAf.F.f..@|f
03 06 50 7C 66 0F B7 1E 6A 7C 83 E3 01 74 1C 8A 1E 6E 7C 80 FB 02 0F 87 E2 FB 66 52 66 8B C8 66 :..P|f...j|...t...n|.......fRf..f
A1 54 7C 66 F7 E3 66 03 C1 66 5A 66 52 8B DF B9 01 00 E8 EA FB 66 5A 66 C1 E2 02 8B DA 66 5A C3 :.T|f..f..fZfR........fZf.....fZ.
Sector 3(8194051)
Sector 4(8194052)
Sector 5(8194053)
DB 1D F1 48 D2 00 BC A0 5D E7 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 :...H....].......................
Sector 6(8194054)
A4 3C 20 20 04 00 00 00 F0 3C 20 20 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 :.<  .....<  ....................
Sector 7(8194055)
Sector 8(8194056)
Sector 9(8194057)
Sector 10(8194058)
Sector 11(8194059)
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7B 48 EF 08 7B 48 EF 08 :........................{H..{H..
7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 :{H..{H..{H..{H..{H..{H..{H..{H..
Sector 12(8194060)
*00*00*00*00*00*00*00*00*00*00*00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00:................................
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00:................................
 00 08 7D 00 00 00 00 00 00 F8 72 00 00 00 00 00 80 00 00 00 C0 03 00 00 80 04 00 00 CE CB 01 00:..}.......r.....................
 04 00 00 00 05 35 DC 90 00 01 00 00 09 06 01 80 00 00 00 00 00 00 00 00 33 C9 8E D1 8E C1 8E D9:.....5..................3.......
 BC D0 7B BD 00 7C 88 16 6F 7C B4 41 BB AA 55 CD 13 72 69 81 FB 55 AA 75 63 F6 C1 01 74 5E FE 06:..{..|..o|.A..U..ri..U.uc...t^..
 02 7C 66 50 B0 65 E8 A6 00 66 58 66 B8 01 00 00 00 8A 0E 6D 7C 66 D3 E0 66 89 46 E8 66 B8 01 00:.|fP.e...fXf.......m|f..f.F.f...
 00 00 8A 0E 6C 7C 66 D3 E0 66 89 46 D8 66 A1 40 7C 66 40 BB 00 7E B9 01 00 66 50 E8 41 00 66 58:....l|f..f.F.f.@|f@..~...fP.A.fX
 66 40 BB 00 80 B9 01 00 E8 34 00 66 50 B0 78 E8 5D 00 66 58 E9 09 01 A0 FC 7D EB 05 A0 FB 7D EB:f@.......4.fP.x.].fX.....}....}.
 00 B4 7D 8B F0 AC 98 40 74 0C 48 74 0E B4 0E BB 07 00 CD 10 EB EF A0 FD 7D EB E6 CD 16 CD 19 66:..}....@t.Ht............}......f
 60 66 6A 00 66 50 06 53 66 68 10 00 01 00 B4 42 B2 80 8A 16 6F 7C 8B F4 CD 13 66 58 66 58 66 58:`fj.fP.Sfh.....B....o|....fXfXfX
 66 58 66 61 72 B1 03 5E D8 66 40 49 75 D1 C3 66 60 B4 0E BB 07 00 B9 01 00 CD 10 66 61 C3 42 00:fXfar..^.f@Iu..f`..........fa.B.
 4F 00 4F 00 54 00 4D 00 47 00 52 00 0D 0A 52 65 6D 6F 76 65 20 64 69 73 6B 73 20 6F 72 20 6F 74:O.O.T.M.G.R...Remove disks or ot
 68 65 72 20 6D 65 64 69 61 2E FF 0D 0A 44 69 73 6B 20 65 72 72 6F 72 FF 0D 0A 50 72 65 73 73 20:her media....Disk error...Press
 61 6E 79 20 6B 65 79 20 74 6F 20 72 65 73 74 61 72 74 0D 0A 00 00 00 00 00 00 00 00 00 00 FF FF:any key to restart..............
 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF:................................
 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 6C 8B 98 55 AA:...........................l..U.
Sector 13(8194061)
*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 46 F8 FF FF FF FF 66 A1:........................F.....f.
 60 7C 66 83 F8 02 0F 82 D2 FE 66 3D F8 FF FF 0F 0F 83 C8 FE C6 46 EF 01 66 50 66 83 E8 02 66 8B:`|f.......f=.........F..fPf...f.
 5E E8 66 8B CB 66 8B F3 66 F7 E3 66 03 46 FC 66 50 66 BB 00 82 00 00 66 8B FB 66 B9 01 00 00 00:^.f..f..f..f.F.fPf.....f..f.....
 E8 BC FE 80 3D 00 0F 84 0D 01 80 7E EF 01 0F 84 13 00 80 7E EF 02 0F 84 23 00 80 7E EF 03 0F 84:....=......~.......~....#..~....
 8B 00 E9 F2 00 80 3D 85 0F 85 C0 00 8B 45 04 25 10 00 0F 85 B6 00 C6 46 EF 02 E9 AF 00 80 3D C0:......=......E.%.......F......=.
 0F 85 A4 00 66 8B 45 14 66 89 46 F0 66 53 66 8B 45 18 66 8B 5E D8 66 4B 66 03 C3 66 F7 D3 66 23:....f.E.f.F.fSf.E.f.^.fKf..f..f#
 C3 66 89 46 E4 66 5B 66 C7 46 E0 00 00 00 00 8A 45 01 88 46 DC 24 02 0F 84 25 00 66 B8 01 00 00:.f.F.f[f.F......E..F.$...%.f....
 00 8A 0E 6D 7C 02 0E 6C 7C 66 D3 E0 66 48 66 53 66 8B 5D 18 66 03 C3 66 5B 66 D3 E8 66 89 46 E0:...m|..l|f..fHfSf.].f..f[f..f.F.
 8A 45 03 3C 07 75 41 C6 46 EF 03 EB 3F 80 3D C1 75 36 66 50 66 53 66 57 83 C7 02 BB 07 00 8B 05:.E.<.uA.F...?.=.u6fPfSfW........
 25 DF FF 89 05 83 C7 02 4B 75 F3 66 5F 66 5B 66 58 66 57 83 C7 02 B9 07 00 66 56 BE 5E 7D F3 A7:%.......Ku.f_f[fXfW......fV.^}..
 66 5E 66 5F 0F 84 B8 00 C6 46 EF 01 66 83 C7 20 66 3B FB 0F 82 0C FF 66 58 66 40 4E 0F 85 EF FE:f^f_.....F..f.. f;.....fXf@N....
 66 58 66 52 66 53 66 33 D2 66 33 DB E8 3D 01 66 5B 66 5A 0F 82 C1 FE 83 C4 04 E9 7F FD 00 20 00:fXfRfSf3.f3..=.f[fZ........... .
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA:..............................U.
Sector 14(8194062)
*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 8B C7 66 83 F8 02 0F 82:..........................f.....
 DA FC 66 83 F8 F8 0F 83 D2 FC 66 50 66 83 E8 02 66 8B 4E E8 66 F7 E1 66 03 46 FC 66 51 66 B9 01:..f.......fPf...f.N.f..f.F.fQf..
 00 00 00 BB 00 00 06 8E 06 7D 7F E8 D1 FC 07 C1 EB 04 01 1E 7D 7F 66 8B 4E E4 66 2B 4E D8 66 89:.........}..........}.f.N.f+N.f.
 4E E4 66 83 F9 00 0F 84 24 00 66 59 66 49 75 CB 66 58 66 53 66 52 8A 5E DC 66 8B 56 E0 E8 2C 00:N.f.....$.fYfIu.fXfSfR.^.f.V..,.
 66 89 56 E0 66 5A 66 5B 0F 83 02 00 EB 9C 50 B0 54 E8 BB FC 58 8B 46 D8 A3 0B 7C 66 A1 40 7C 66:f.V.fZf[......P.T...X.F...|f.@|f
 A3 1C 7C 8A 16 6F 7C EA 00 00 00 20 F6 C3 02 0F 85 0C 00 E8 23 00 26 66 8B 01 66 83 F8 F8 C3 66:..|..o|.... ........#.&f..f....f
 83 FA 00 0F 84 06 00 66 40 66 4A F9 C3 66 B8 F8 FF FF FF 66 83 F8 F8 F8 C3 66 52 BF 00 82 66 33:.......f@fJ..f.....f.....fR...f3
 D2 66 53 66 8B 5E D8 66 C1 EB 02 66 F7 F3 66 5B 66 3B 46 F8 74 41 66 89 46 F8 66 03 06 40 7C 66:.fSf.^.f...f..f[f;F.tAf.F.f..@|f
 03 06 50 7C 66 0F B7 1E 6A 7C 83 E3 01 74 1C 8A 1E 6E 7C 80 FB 02 0F 87 E2 FB 66 52 66 8B C8 66:..P|f...j|...t...n|.......fRf..f
 A1 54 7C 66 F7 E3 66 03 C1 66 5A 66 52 8B DF B9 01 00 E8 EA FB 66 5A 66 C1 E2 02 8B DA 66 5A C3:.T|f..f..fZfR........fZf.....fZ.
Sector 15(8194063)
Sector 16(8194064)
Sector 17(8194065)
*31*10*00*60*00 00*00*00*00*00*00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00:1..`............................
Sector 18(8194066)
*00*00*00*00*00 00 00 00*00*00*00*00*00 00 00 00 00 00 00 00*00 00 00 00 00 00 00 00 00 00 00 00:................................
Sector 19(8194067)
Sector 20(8194068)
Sector 21(8194069)
Sector 22(8194070)
Sector 23(8194071)
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7B 48 EF 08 7B 48 EF 08:........................{H..{H..
 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08:{H..{H..{H..{H..{H..{H..{H..{H..
 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08 7B 48 EF 08*00*00*00*00*00*00*00*00:{H..{H..{H..{H..{H..{H..........
You will notice that several of these sectors change at the beginning?
Now to do format and try dumping again....
Sector 0(8194048)
Sector 1(8194049)
Sector 2(8194050)
Sector 3(8194051)
Sector 4(8194052)
Sector 5(8194053)
Sector 6(8194054)
Sector 7(8194055)
Sector 8(8194056)
Sector 9(8194057)
Sector 10(8194058)
Sector 11(8194059)
Sector 12(8194060)
Sector 13(8194061)
Sector 14(8194062)
Sector 15(8194063)
Sector 16(8194064)
Sector 17(8194065)
Sector 18(8194066)
Sector 19(8194067)
Sector 20(8194068)
Sector 21(8194069)
Sector 22(8194070)
Sector 23(8194071)
Again they look different still but not sure by what yet...
May extend this and again try on partition 0, and read all of them in before the format and then compare them after the format and see what differences there may be...
@mjs513 @KurtE I finally found a a good disk editor for Linux that is comparable to WinHex. (Active@ Disk Editor).
Just have to learn how to use it properly. I already noticed it that will follow offsets and sector references.
@KurtE That can come in real handy for finding diffs in formatting.
Again I hacked the sketch. and in this run I typed:
d01
Which dumped the 24 sectors for partitions 0 and 1 (actually 1 2)...
This was just after I removed it from windows and did a format.
I then hit enter again to run again and this time typed: 01
Which refomatted both partitions.
But with this formatting, I first read in the 24 sectors, then ran the format, and then read in the 24 sectors comparing to what was there before the format and printed the differences...
Not sure how useful, but my guess is some of the other areas are what is keeping windows from being happy:
exFAT:	1,0,0x20,0x21,0x0,0x7,0xE,0x50,0xFE,2048,8192000
Partition 0 valid:1
Sector 0(2048)
00 08 00 00 00 00 00 00 00 00 7D 00 00 00 00 00 80 00 00 00 00 04 00 00 80 04 00 00 EE F3 01 00 :..........}.....................
04 00 00 00 E4 5E ED 52 00 01 00 00 09 06 01 80 00 00 00 00 00 00 00 00 33 C9 8E D1 8E C1 8E D9 :.....^.R................3.......
Sector 1(2049)
Sector 2(2050)
Sector 3(2051)
Sector 4(2052)
Sector 5(2053)
Sector 6(2054)
Sector 7(2055)
Sector 8(2056)
Sector 9(2057) and 10 all zeros
Sector 11(2059)
AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A :.n.J.n.J.n.J.n.J.n.J.n.J.n.J.n.J
Sector 12(2060)
 EB 76 90 45 58 46 41 54 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00:.v.EXFAT   .....................
 00 08 00 00 00 00 00 00 00 00 7D 00 00 00 00 00 80 00 00 00 00 04 00 00 80 04 00 00 EE F3 01 00:..........}.....................
 04 00 00 00 E4 5E ED 52 00 01 00 00 09 06 01 80 00 00 00 00 00 00 00 00 33 C9 8E D1 8E C1 8E D9:.....^.R................3.......
Sector 13(2061)
 66 50 B0 46 E8 48 FF 66 58 66 A1 40 7C 66 03 06 58 7C 66 89 46 FC 66 C7 46 F8 FF FF FF FF 66 A1:fP.F.H.fXf.@|f..X|f.F.f.F.....f.
Sector 14(2062)
 66 50 B0 41 E8 48 FD 66 58 83 C4 04 8B 76 F2 8B 7E F0 8B C6 66 C1 E0 10 8B C7 66 83 F8 02 0F 82:fP.A.H.fX....v..~...f.....f.....
Sector 15(2063)
16-22 duplicates of 15
Sector 23(2071)
 AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A:.n.J.n.J.n.J.n.J.n.J.n.J.n.J.n.J
 AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A AA 6E D2 4A*00*00*00*00*00*00*00*00:.n.J.n.J.n.J.n.J.n.J.n.J........
    After usbDriveBegin
Partition 1 valid:1
Sector 0(8194048)
Sector 1(8194049)
Sector 2(8194050)
Sector 3(8194051)
Sectors 4 - 8 duplicates of 5
Sector 9(8194057)
Sector 10(8194058)
Sector 11(8194059)
Sector 12(8194060)
Sector 13(8194061)
Sector 14(8194062)
Sector 15(8194063)
Sector 16(8194064) - 20 dups of 15
Sector 21(8194069)
Sector 22(8194070)
Sector 23(8194071)
Dumps of formats:
Part 0
Sector 0(2048)
 04 00 00 00*00*00*7D*00 00 01 00 00 09 06 01 80 00 00 00 00 00 00 00 00*F4*F4*F4*F4*F4*F4*F4*F4:......}.........................
*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4:................................
*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4 F4*F4*F4*F4*F4*F4*F4*F4*F4:................................
*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4*F4 55 AA:..............................U.
Sector 1(2049)
*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00:................................
*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 00*00 00 00*00*00*00*00*00*00 00 00 00:................................
*00*00*00*00*00 00*00*00*00*00*00*00*00*00*00*00*00 00*00*00*00*00*00*00*00 00*00*00*00*00*00*00:................................
*00 00*00*00 00*00*00*00*00*00*00 00*00*00*00*00*00 00*00*00*00 00*00*00*00*00*00*00 00*00*00*00:................................
*00*00*00 00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00:................................
*00*00*00*00*00*00*00*00*00*00*00 00 00 00 00*00*00*00*00*00*00*00*00*00*00*00 00*00*00*00 00 00:................................
*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 00*00*00:................................
*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 00*00*00*00*00*00*00*00:................................
*00*00*00*00*00*00*00 00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00:................................
*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 00*00 00:................................
Sector 2(2050)
 00 00 00*00 00 00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00:................................
*00*00*00*00*00 00*00*00*00 00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 00:................................
*00*00*00*00*00*00*00*00*00*00*00 00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00:................................
*00*00*00*00*00*00*00*00 00 00 00*00*00*00*00*00*00*00 00*00*00 00*00*00*00*00*00*00*00*00*00*00:................................
*00*00 00*00*00*00 00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 00*00*00*00:................................
*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00 00*00*00*00*00*00*00*00*00*00*00*00*00*00*00:................................
Sector 3(2051)
Sector 4(2052) - 8 no change duplicates
Sector 9(2057)
Sector 10(2058)
Sector 11(2059)
*01*8C*3A*29*01*8C*3A*29*01*8C*3A*29*01*8C*3A*29*01*8C*3A*29*01*8C*3A*29*01*8C*3A*29*01*8C*3A*29:..:)..:)..:)..:)..:)..:)..:)..:)
Sector 12(2060)
Sector 13(2061)
Sector 14(2062)
Sector 15(2063)
16-20 no change same values.
Sector 21(2069)
Sector 22(2070)
Sector 23(2071)
Part 1
Sector 0(8194048)
 00 08*7D 00 00 00 00 00 00*F8*72 00 00 00 00 00 80 00 00 00*C0*03 00 00 80 04 00 00*CE*CB 01 00:..}.......r.....................
 04 00 00 00*00*F8*72*00 00 01 00 00 09 06 01 80 00 00 00 00 00 00 00 00*F4*F4*F4*F4*F4*F4*F4*F4:......r.........................
Sector 1(8194049)
Sector 2(8194050)
Sector 3(8194051)
Sector 4(8194052)
Sector 5(8194053)
Sector 6(8194054)
Sector 7(8194055)
Sector 8(8194056)
Sector 9(8194057)
Sector 10(8194058)
Sector 11(8194059)
*DB*0E*2D*31*DB*0E*2D*31*DB*0E*2D*31*DB*0E*2D*31*DB*0E*2D*31*DB*0E*2D*31*DB*0E*2D*31*DB*0E*2D*31:..-1..-1..-1..-1..-1..-1..-1..-1
Sector 12(8194060)
Sector 13(8194061)
Sector 14(8194062)
Sector 15(8194063)
Sector 16(8194064)
Sector 17(8194065)
Sector 18(8194066)
Sector 19(8194067)
Sector 20(8194068)
Sector 21(8194069)
Sector 22(8194070)
Sector 23(8194071)
  • MSCFormatter-210320a.zip
@KurtE - @wwatson
Nice work - good tool to check if you don't have something like WinHex. Anyway back to what you are showing.
A couple of key sectors for reference;
  • Sector 0 -> MBR - BOOT SECTOR. The 0xF4 is fill per the official SDFormatter according to library.
  • Sector 11 -> Checksum (should be different than windows since its based on slightly different pbs values.
  • Sector 12 start a duplicate of sectors 0-12.
Here is a handy breakout of the MBR:
Using WinHex there were no differences between MBR;s after reformatting. Have to check more sectors of the VBR but I kept looking and didn't see anything. Also checked the up-case table and root directory and it looked ok.
Anyway formatting part 0 worked for me but part 1 did not work for me. This is the WinHex dump of part 0. The only difference is the partition offset. Wonder if there is some thing else needs to get set.
Mike, did you get the WinHex specialist edition, in order to work with EXFat?
My look at their website you need to go up to that level to work with it?
So far not seeing many clues on why Linux is OK with it but Windows is not.
Note: sometimes I get the first partition to work and not the second, and other times second and not first...
Note: I hacked in to the end of the Format a call to sync...
 writeMsg(pr, "Format done\r\n");
[COLOR="#FF0000"]  m_dev->syncDevice();[/COLOR]
  return true;
You might try it and see if it helps.
Also wondering about some variable getting reused.
Have you tried, format both partitions on windows (eject)
Then go to Teensy and only format the second partition,
and then try plugging it back into PC...
Mine worked.
But I also tried reformat both on WIndows, eject
Go to Teensy:
Format 1
Format 0
Take back to PC and Drive 1 ok Drive 0 not...
So again some reuse of somethign...
:D :D :D I Think maybe I found it... :D :D :D
Try adding:
bool PFsExFatFormatter::format(PFsVolume &partVol, uint8_t* secBuf, print_t* pr) {
#if !PRINT_FORMAT_PROGRESS
(void)pr;
#endif  //  !PRINT_FORMAT_PROGRESS
[COLOR="#FF0000"]  checksum = 0;[/COLOR]
It was defined in the class = 0;
So worked for first partition you tried it on.
But nothing reset it.....
  return true;
Mine worked.
Go to Teensy:
Format 1
Format 0
Got the WinHex Personnel edition but was able to download some of their exFAT templates: https://www.x-ways.net/winhex/templates/. The boot sector ones are coming in real handy. Then using some of the references I posted as well to understand - well at least try to understand.
Yes I have. Drive 1 formats on Teensy and is able to be read by Windows. Drive 0 formats on Teensy but fails on Windows. And if you only format partition 1 it formats without an issue.
