I'm running a Teensy 3.2 with CAN transceiver from pins 3(TX) and 4(RX). The below sketch is working fine in adding control for an electric motor on a 500k bus.
I wish to control another piece of equipment on the same 500k bus. I've found the below code which apparently works and I'd like to add it to my sketch above.
I'm a complete novice and willing to learn, but despite studying this for three days, I'm no further forward. Could some help me add this code into my main sketch?
#include <Arduino.h>
#include <FlexCAN.h> //https://github.com/teachop/FlexCAN_Library
#include <Smoothed.h> //https://github.com/MattFryer/Smoothed
/////////// Pin Assignments /////////
const int led = 13;
/////////// Variables //////////////
int rpm;
int mtemp;
int hstemp;
int amps;
int potnom;
int pot;
int run;
int dir = 0;
int brake;
int boost;
int maxBoost;
int pot2;
int fweak;
int minBoost;
int brkNomPedal;
int brkMax;
int baseRegen;
int maxRegen;
int idleThrot;
int slipstart;
int idleRPM;
int idleThrotMax;
int packVolt;
int neg = 4294967295;
float maxSlip;
float minSlip;
float fslip;
float fslipmin;
float ampMin;
float throtRamp;
bool startup;
CAN_message_t msg;
CAN_message_t inMsg;
CAN_filter_t filter;
//////////////Smoothing///////////////
Smoothed <int> idleRamp;
Smoothed <float> fslipRamp;
pinMode(led, OUTPUT);
Can0.begin(500000);
//set filters for standard
for (int i = 0; i < 8; i++)
Can0.setFilter(filter, i);
//set filters for extended
for (int i = 9; i < 13; i++)
digitalWrite(led, HIGH);
Serial.begin(1152000);
idleRamp.begin(SMOOTHED_AVERAGE, 60);
fslipRamp.begin(SMOOTHED_AVERAGE, 60);
while (Can0.available())
Can0.read(inMsg);
decodeCAN();
parameterMap();
boostMap();
//idleThrottle();
//regenStuff();
void decodeCAN() {
if (inMsg.id == 0x135) {
if ((((inMsg.buf[3] << 8) + inMsg.buf[2])) <= 2000) {
amps = (((inMsg.buf[3] << 8) + inMsg.buf[2]) * 1.83);
else if ((((inMsg.buf[3] << 8) + inMsg.buf[2])) >= 3000) {
amps = (((((inMsg.buf[3] << 8) + inMsg.buf[2]) - 65535) * 1.83) * -1);
rpm = (((inMsg.buf[1] << 8) + inMsg.buf[0]));
if ((inMsg.buf[4]) > 0) {
mtemp = (inMsg.buf[4]); //motor temp C
if ((inMsg.buf[5]) > 0) {
hstemp = (inMsg.buf[5]); //heatsink temp C
if ((((inMsg.buf[7] << 8)) + inMsg.buf[6]) <= 2000) {
potnom = (((inMsg.buf[7] << 8)) + inMsg.buf[6]);
else if ((((inMsg.buf[7] << 8)) + inMsg.buf[6]) >= 2000) {
potnom = ((((inMsg.buf[7] << 8)) + inMsg.buf[6]) - 65535);
else if (inMsg.id == 79) {
dir = (inMsg.buf[0]);
brake = (inMsg.buf[1]); //din brake
else if (inMsg.id == 0x136) {
run = (inMsg.buf[0]); //opmode
packVolt = ((inMsg.buf[2] << 8) + inMsg.buf[1]); //UDC
else if (inMsg.id == 0x113) {
pot = ((inMsg.buf[1] << 8) + inMsg.buf[0]);
pot2 = ((inMsg.buf[3] << 8) + inMsg.buf[2]);
void parameterMap() {
//boost
maxBoost = 1720;
minBoost = 1720;
//fweak
if (pot > 1800 && pot < 3200) {
fweak = map(pot, 1800, 3200, 400, 258);
else if (pot >= 3200) {
fweak = 258;
else {
fweak = 400;
canSet(1, fweak);
//fslipmin
fslipmin = 2.3;
canSet(4, fslipmin);
//fslipmax
maxSlip = (3.08 * 32);
if (pot >= 2800) {
minSlip = map(pot, 2800, 4095, (fslipmin * 32), maxSlip);
else { minSlip = (fslipmin * 32); }
if (rpm <= 4500) {
fslip = map(rpm, 0, 4200, minSlip, maxSlip);
else { fslip = maxSlip; }
//fslipRamp.add(fslip);
canSet(5, fslip / 32);
// throtramp
if (pot < 1500) {
throtRamp = .45;
else if (pot >= 1500 && pot < 3000) {
throtRamp = map(pot, 1500, 3700, 1, 25);
else {
throtRamp = 25;
canSet(49, throtRamp);
//slipstart
slipstart = 32;
canSet(52, slipstart);
//ampmin
ampMin = 1.1;
canSet(51, ampMin);
void boostMap() //sets boost lower for startup without OC trip, ramps higher with throttle for increased power
if (pot > 3700) {
boost = map(pot, 3700, 4095, minBoost, maxBoost);
canSet(0, boost);
else {
boost = minBoost;
canSet(0, boost);
void regenStuff() {
// This method allows both pedal off regen in combination with variable pot2 value. Previously was not able to achieve this with recent firmware.
baseRegen = 0; //base throttle off regen value
maxRegen = 90; //maximum full brake pressure regen value
//brakenompedal
/*if (rpm <= 2000) {
brkNomPedal = map(rpm, 0, 2000, ((neg - (1 * 32)) / 32), ((neg - (baseRegen * 32))) / 32); //reduces pedal regen with speed below 2,000 rpm.
if (pot2 > 3700) {
brkNomPedal = ((neg - (maxRegen * 32)) / 32); //sets POT2 value for maximum regen
else {
brkNomPedal = map(pot2, 600, 3700, ((neg - (baseRegen * 32)) / 32), ((neg - (maxRegen * 32))) / 32); //maps brake pedal regen between base and max
canSet(53, brkNomPedal);
//brakemax
brkMax = ((neg - (baseRegen * 32)) / 32);
canSet(56, brkMax);
void idleThrottle() {
if (run == 0) {
canSet(64, 1); // Sets idlemode to brakeoff when inverter is not in opmode "run"
else {
canSet(64, 0); //Sets idlemode to alwayson when inverter is in "run"
idleRamp.add(pot2);
idleThrot = map(idleRamp.get(), 600, 1020, idleThrotMax, 0);
canSet(63, idleThrot);
idleThrotMax = 15;
idleRPM = 1750;
canSet(62, idleRPM);
void canSet(int index, float value) {
int val = (value * 32); //scale value * 32 to make STM32 happy
int byte1;
int byte2;
int byte3;
int byte4;
byte1 = val & 0xFF; //bitshifting
byte2 = (val >> 8) & 0xFF;
byte3 = (val >> 16) & 0xFF;
byte4 = (val >> 24) & 0xFF;
msg.id = 0x601; //set parameter ID
msg.len = 8;
msg.buf[0] = 0x40;
msg.buf[1] = 0x00;
msg.buf[2] = 0x20;
msg.buf[3] = index; //index value of parameter, boost = 0
msg.buf[4] = byte1;
msg.buf[5] = byte2;
msg.buf[6] = byte3;
msg.buf[7] = byte4;
Can0.write(msg);
void debug() {
Serial.print("Pot val:");
Serial.println(pot);
Serial.print("Fslip:");
Serial.println(fslip/32);
Serial.print("Fweak:");
Serial.println(fweak);
Serial.println("");
Serial.println("");
Serial.println("");
#include <mcp_can.h>
const int SPI_CS_PIN = 9;
MCP_CAN CAN(SPI_CS_PIN);
int counter = 0;
const unsigned char voltage_03_8[2] = {0xA0, 0xAF};
// Initialize CAN Bus Shield, set baudrate [/h1]
500k
while (CAN_OK != CAN.begin(CAN_500KBPS))
Serial.println("CAN BUS Shield init - FAILED.");
Serial.println("Retrying...");
Serial.println("CAN BUS Shield init - OK.");
// SENDING CAN MESSAGES - DC 2 DC converter
CAN.sendMsgBuf(0x1D4, 0, 2, voltage_03_8);
// RECEIVING CAN MESSAGES
if(counter == 10 && (CAN_MSGAVAIL == CAN.checkReceive())) {
unsigned char len = 0;
unsigned char buf[8];
unsigned long canId = 0;
CAN.readMsgBuf(&len, buf);
canId = CAN.getCanId();
if(canId == 0x1D6) {
double lv_output_voltage = (double)buf[2];
lv_output_voltage = lv_output_voltage / 12.7;
int temp1 = (int)buf[3];
temp1 = temp1 - 40;
int temp2 = (int)buf[4];
temp2 = temp2 - 40;
int lv_output_current = (int)buf[5];
Serial.print("ID; Serial.print(canId); Serial.print("] - ");
Serial.print("Volts Serial.print(lv_output_voltage); Serial.print(" : ");
Serial.print("Temp1 Serial.print(temp1); Serial.print(" : ");
Serial.print("Temp2 Serial.print(temp2); Serial.print(" : ");
Serial.print("Apms Serial.print(lv_output_current);
counter = 0;
} // End if block - counter && can received.
counter++;
