Senior Member+
@Paul:
Minor edit to LFSIntegrity to HALT on failed myfs.begin() :: github.com/PaulStoffregen/LittleFS/pull/11
Senior Member+
@Paul - Not sure if you want to pick this up soon or not... But there is a new update to: https://github.com/greiman/SdFat-beta
It now supports UTF-8 filenames...
Plus he update the configuration file where it checks first to see if a define is set and only use default if not set:
https://github.com/greiman/SdFat-bet...tConfig.h#L218
The one location in the link is one I wish he defaulted to ON...
Senior Member+
Perhaps we should review the PAD settings for I2C and use very conserative settings.
From my experients they work well, even for higher I2C speeds and may cause less problems.
edit: Perhaps the folks with your I2c tester board can try that?
Or, we could add a general usable function pinMode(pin, const output, speed, strength, slewRate) something like that..
Audio ladder filter (Richard van Hoesel)
Oooh tell me more - I can't find it in the audio design tool, presumably because it's still experimental?
- You may not post replies
- You may not edit your posts
Forum Rules
