Results 1 to 3 of 3
Thread: Pcm1808 teensy 4. integration ..
    Apr 2020
    Guelph Ontario Canada
    116
    I'm okay on the pinout, wiring ..no issues. But in the pjrc audio design tool do we just use the standard I2S input ?
    24,072
    Yup, PCM1808 is really simple. You can use either I2S or I2S2 on Teensy 4.x. Just connect the 4 signals. MCLK is named SCKI on that chip. The other 3 have names the same as Teensy uses.
    PCM1808 has 3 config pins. Connect all of them to GND.
    Be careful with the power pins. PCM1808 needs 3.3V for digital and 5V for analog. If you get them mixed up, it could damage the PCM1808, and before it dies it could send a 5V signal to Teensy, possibly also causing Teensy to be damaged.
    Apr 2020
    116
    Thanks for the reply Paul, greatly appreciated ..Ill keep the 3.3v and 5 v sorted first ..thanks for the heads up..
    K
Tags for this Thread
