Setting T4.x USB device speed to 12 MHz?
How to set the USB dev speed on T4.1 to 12 MHz?
I wanted the connect to T4.1 USB via some connectors, but I only get unknown device on my PC.
I suspect that the waveform gets disturbed too much when passing through non USB type connectors.
For testing I wanted to use 12 MHz speed to see if this is a solution.
Senior Member+
Do you have an old 12MHz Hub? Don't know if that would work..I'm courious.
No,
I have a very tight space (not large enough for a USB connector) so USB data dots are connected to a PCB connector that is connected to a Underwater Bulkhead etc.
All in a water tight pressure housing.
An earlier version used T3.6 with no problem, but T4.1 creates problems:
USB device nor recognized or is recognized, download blocks halfway through; a nightmare
No time to revert to T3.6; need also external memory.
Try uncommenting this line in usb.c
//USB1_PORTSC1 |= USB_PORTSC1_PFSC; // force 12 Mbit/sec
Paul,
My apologies to all for hijacking this thread, but I don't know what else to do. I ordered and received 2ea ILI9341 displays from your store 2 weeks ago, and one of them appears to be DOA. I emailed both you and Robin at 'Paul@pjrc.com' and 'Robin@pjrc.com' a week ago about this but haven't gotten any replies. I also started a topic 'Getting Product Support' in the 'General Discussion' forum category, but no responses there either.
Is there something I'm doing wrong here, or is product support no longer available?
Apologies again,
Frank
Originally Posted by
PaulStoffregen
Try uncommenting
this line in usb.c
Seems to work.
At least Teensy talks to PC using flying wires and can download (the main reason for functionality)
- You may not post replies
- You may not edit your posts
Forum Rules
