Results 1 to 3 of 3
Thread: Can't get the "guitar" example to output to USB?
    Feb 2021
    5
    Stumped on this one.
    Took the "Guitar" example and lightly edited it for USB audio output:
    $ diff /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/examples/Synthesis/Guitar/Guitar.ino Documents/Arduino/GuitarUSB/GuitarUSB.ino
    19c19
    < AudioOutputI2S           i2s1;
    > AudioOutputUSB           usb1;
    27,28c27,28
    < AudioConnection          patchCord8(mixer2, 0, i2s1, 0);
    < AudioConnection          patchCord9(mixer2, 0, i2s1, 1);
    > AudioConnection          patchCord8(mixer2, 0, usb1, 0);
    > AudioConnection          patchCord9(mixer2, 0, usb1, 1);
    140,142d139
    It doesn't output any audio at all.
    Here's the complete code:
    #include "chords.h"
    // Special thanks to Matthew Rahtz - http://amid.fish/karplus-strong/
    AudioSynthKarplusStrong  string1;
    AudioSynthKarplusStrong  string2;
    AudioSynthKarplusStrong  string3;
    AudioSynthKarplusStrong  string4;
    AudioSynthKarplusStrong  string5;
    AudioSynthKarplusStrong  string6;
    AudioMixer4              mixer1;
    AudioMixer4              mixer2;
    AudioConnection          patchCord1(string1, 0, mixer1, 0);
    AudioConnection          patchCord2(string2, 0, mixer1, 1);
    AudioConnection          patchCord3(string3, 0, mixer1, 2);
    AudioConnection          patchCord4(string4, 0, mixer1, 3);
    AudioConnection          patchCord5(mixer1, 0, mixer2, 0);
    AudioConnection          patchCord6(string5, 0, mixer2, 1);
    AudioConnection          patchCord7(string6, 0, mixer2, 2);
    AudioControlSGTL5000     sgtl5000_1;
    const int finger_delay = 5;
    const int hand_delay = 220;
    int chordnum=0;
      AudioMemory(15);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.6);
      mixer1.gain(0, 0.15);
      mixer1.gain(1, 0.15);
      mixer1.gain(2, 0.15);
      mixer1.gain(3, 0.15);
      mixer2.gain(1, 0.15);
      mixer2.gain(2, 0.15);
      delay(700);
    void strum_up(const float *chord, float velocity);
    void strum_dn(const float *chord, float velocity);
      const float *chord;
      // each time through the loop, play a different chord
      if (chordnum == 0) {
        chord = Cmajor;
        Serial.println("C major");
        chordnum = 1;
      } else if (chordnum == 1) {
        chord = Gmajor;
        Serial.println("G major");
        chordnum = 2;
      } else if (chordnum == 2) {
        chord = Aminor;
        Serial.println("A minor");
        chordnum = 3;
        chord = Eminor;
        Serial.println("E minor");
        chordnum = 0;
      // then strum the 6 string several times
      strum_up(chord, 1.0);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      strum_dn(chord, 0.8);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      strum_dn(chord, 0.7);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      Serial.print("Max CPU Usage = ");
      Serial.print(AudioProcessorUsageMax(), 1);
      Serial.println("%");
      if (chord[0] > 20.0) string1.noteOn(chord[0], velocity);
      delay(finger_delay);
      if (chord[1] > 20.0) string2.noteOn(chord[1], velocity);
      if (chord[2] > 20.0) string3.noteOn(chord[2], velocity);
      if (chord[3] > 20.0) string4.noteOn(chord[3], velocity);
      if (chord[4] > 20.0) string5.noteOn(chord[4], velocity);
      if (chord[5] > 20.0) string6.noteOn(chord[5], velocity);
      if (chord[5] > 20.0) string1.noteOn(chord[5], velocity);
      if (chord[4] > 20.0) string2.noteOn(chord[4], velocity);
      if (chord[3] > 20.0) string3.noteOn(chord[3], velocity);
      if (chord[2] > 20.0) string4.noteOn(chord[2], velocity);
      if (chord[1] > 20.0) string5.noteOn(chord[1], velocity);
      if (chord[0] > 20.0) string6.noteOn(chord[0], velocity);
    Any ideas? The "Guitar" sketch works, and I've been able to get other sketches to output audio via USB audio...
    This is running on a Teensy 4.0 with a Rev D audio shield (https://www.pjrc.com/store/teensy3_audio.html).
    Germany
    8,230
    The help in the Auio Library GUI says:
    USB input & output does not cause the Teensy Audio Library to update. At least one non-USB input or output object must be present for the entire library to update properly.
    Then, you want to remove the SGTL500 Control.
    Feb 2021
    5
    Aha! Thank you! It works now.
