Results 1 to 2 of 2
Thread: Repurposing the 1/8" jack on the audio shield to be a Line In jack
    Feb 2021
    5
    I'd like to repurpose the 1/8" jack on the audio shield to be a Line In jack.
    Should I be able to simply "cross-wire" the left/right/ground pads adjacent to the headphone jack to the left/right/ground pads on the Line In header?
    Would this be a bad idea?
    Is there a "cleaner" way to do this?
    I wish to minimise line noise. I am okay with cutting some traces if I need to to get the best result.
    Germany
    8,230
    The way is to simply add an extra jack. Whatever you do - never connect the jacks GND to the normal GND. If you really want to go that way, cut all three connections.
