Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 26 to 50 of 199
Thread: Re-enable bootloader interrupts after a hard fault [Teensy 4.1]
  1. #26
    New York
    7,196
    One more thing. The LED blink is just for testing. It's intended to be removed before 1.54-beta11.
    Finally found the thread that you posted to. Sorry. Anyway with the incorporation of the latest PR, addition details is printed:
    CrashReport ... Hello World
      length: 9
      IPSR: 3
      CFSR: 82
    	(DACCVIOL) Data Access Violation
    	(MMARVALID) Accessed Address: 0x0 (nullptr)
      HTSR: 40000000
    	(FORCED) Forced Hard Fault
      MMFAR: 0
      BFAR: 0
      return address: C4
      XPSR: 61000000
      crc: A57C5478
    test 0
    test 1
    test 2
    test 3
    test 4
    @Paul - I kind of like the quick blinking LED on hardfault.
  2. #27
    14,421
    Odd - got cores from github with latest updates.
    Compiled for T_4.1 - Code below - and I see this when the code starts? NO LED BLINKING.
    T:\tCode\FAULT_HANDLER\CrashReport\CrashReport.ino Jun 20 2021 14:03:51
      length: 1603229661
      IPSR: 8550A1D7
      CFSR: EA331821
    	(IACCVIOL) Instruction Access Violation
    	(UNSTKERR) Bus Fault on unstacking for a return from exception
    	(UNDEFINSTR) Undefined instruction
      HTSR: 981CDC4
      MMFAR: ADBB03C8
      BFAR: 25AF9987
      return address: 192DBE35
      XPSR: CC7C13FD
      crc: 30C95A1C
    Code compiles with no warnings or errors ...
    The code with simple startup and nothing going on ... until user send Serial data ... in fact commenting that out to be sure and it still only coming up with above message?
    #include <crashreport.h>
      while (!Serial && millis() < 4000 );
      Serial.print(CrashReport);
      if ( Serial.available()) {
        //uint32_t *y = 0; y[0] = 5;
  3. #28
    New York
    7,196
      length: 1603229661
      IPSR: 8550A1D7
      CFSR: EA331821
      HTSR: 981CDC4
      MMFAR: ADBB03C8
      BFAR: 25AF9987
      XPSR: CC7C13FD
      crc: 30C95A1C
    @defragster - check your email Work still in progress.
  4. #29
    14,421
    Doing that ... and github ... not finding update for CrashReport.clear()
  5. #30
    New York
    7,196
    Not added added yet. Not that fast in adding stuff.
  6. #31
    14,421
    Misread that as ADDED ... but I never crashed and it is picking up as already crashed and won't clear to run my code - and it isn't blinking - just stalled - does take Auto Upload so not hung ...
  7. #32
    24,452
    NO LED BLINKING.
    Yup. I committed automatic reboot after 8 seconds, which also removed the LED blinking and made some changes to prevent possible nested interrupts. Looks like that commit was pushed to github only minutes before you pulled the latest code.
    https://github.com/PaulStoffregen/co...afba10526b6118
  8. #33
    14,421
    Prior almost 30 mins back I got - latest was just simple stuff - got that too and same result on a T_4.1 after 15 sec Restore:
    T:\tCode\FAULT_HANDLER\CrashReport\CrashReport.ino Jun 20 2021 14:20:20
      length: 1603229661
      IPSR: 8540A1D7
      CFSR: E8331A21
    	(PRECISERR) Data bus error(address in BFAR)
      HTSR: 909CDC4
      MMFAR: ADAB03D8
      BFAR: 25AF9983
      XPSR: CC7C33FD
      crc: 30C91A04
  9. #34
    24,452
    length: 1603229661
    Yup, the code still needs quite a lot of work, like checking the length and crc...
  10. #35
    14,421
    Okay - added more informative code that is working as expected . Still unlcear why there was a fault reported after 15 sec Restore - except perhaps wihtout CRC check it sees a fault everywhere?
      pinMode( LED_BUILTIN, OUTPUT );
      digitalWrite( LED_BUILTIN, 1 );
      //CrashReport.clear();
      delay ( 100 );
      digitalWrite( LED_BUILTIN, 0 );
      delay ( 1000 );
        Serial.println("It's your fault!\n");
        delay ( 50 );
      delay ( 10 );
      delay ( 50 );
    Note(d) : this is now optional >> #include <crashreport.h>
  11. #36
    New York
    7,196
    @PaulStoffregen - @defragster.
    I made some changes to the CrashReport to add clear and to print if crash report is not available but don't like what I did for clear. Really should clear the fault registers but not sure quite how to implement that - should clear on reset but not sure they are. Anyway other issue is that since the latest changes were made the first time the fault occurs the info->len is some huge number but still have a fault when it should be 9. So it throws off my test.
    On first tunring power on after loading the sketch
    D:\Users\Merli\Documents\Arduino\CrashRepot_example\CrashRepot_example.ino Jun 20 2021 20:18:41
    Crash Report not Available
    Hitting the return key shows:
    It's your fault!
    On auto restart after failure you see:
      length: 9
      IPSR: 3
      CFSR: 82
      HTSR: 40000000
      MMFAR: 0
      BFAR: 0
      return address: C4
      XPSR: 61000000
      crc: A55C7678
    and with the return:
    It's your fault!
    EDIT: with the clear function - doesn't clear until you power off and on again.
    The changes I made are in my fork of the repository: https://github.com/mjs513/cores. Basically not really working. Ok off to other things again. To be honest. Think the struct needs to be reinitialized on restart as opposed from the sketch.
  12. #37
    14,421
    Cool - I see your git work.
    Will give it a look ...
  13. #38
    14,421
    @mjs513 - the end of .clear() needs to commit the cache to RAM from cache ... below.
    It would be nice to have the sketch know when a fault happened? - see below ...
    Tested at the end of : size_t CrashReportClass:rintTo(Print& p) const with just these two set to zero and that also stopped the Crash repeat notice. Zero of the rest isn't needed
        info->cfsr = 0;
        info->len = 0;
        arm_dcache_flush_delete(info, sizeof(*info));
    void CrashReportClass::clear()
      struct arm_fault_info_struct *info = (struct arm_fault_info_struct *)0x2027FF80;
      info->len = 0;
      info->ipsr  = 0;
      info->cfsr  = 0;
      info->hfsr  = 0;
      info->mmfar = 0;
      info->bfar  = 0;
      info->ret = 0;
      info->xpsr  = 0;
      //info->crc = 0;
    I get this using code below - of course the .h also needs void changed to bool to match. And I took the "Crash Report not Available" out.
    All was right after upload, then I hit Enter, it showed the Fault, then I did a RESET and the fault was cleared::
    T:\tCode\FAULT_HANDLER\CrashReport\CrashReport.ino Jun 20 2021 22:13:15
     millis() now 1147
    It's your fault!
     millis() now 1075
      length: 9
      IPSR: 3
      CFSR: 82
      HTSR: 40000000
      MMFAR: 0
      BFAR: 0
      return address: C4
      XPSR: 610E0000
      crc: 31E91A1E
    	RECOVERED from Crash !
     millis() now 1056
    Here is the updated sketch - LED a bit less annoying:
      Serial.printf(" millis() now %u\n", millis() );
      if ( CrashReport.clear() ) {
        Serial.print("\n\tRECOVERED from Crash !");
      delay ( 100 );
      delay ( 1000 );
        delay ( 50 );
      delay ( 3 );
      delay ( 40 );
    Here is a possible .clear() version - still no CRC check.
    bool CrashReportClass::clear()
      if( info->len == 9 ) {    //if I add in CRC it gives me headaches
        info->len = 0;
        info->cfsr  = 0;
        return true; // Crash was cleared
        return false; // Crash not present to be cleared
  14. #39
    14,421
    @Paul ... Made three PR's:
    https://github.com/PaulStoffregen/cores/pull/569
    https://github.com/PaulStoffregen/cores/pull/568
    https://github.com/PaulStoffregen/cores/pull/567
    > one is startup.c to pass the crc
    > one is the header for .clear() to return bool
    > one is .cpp class edits to act on valid CRC, .clear() to test CRC and report false with no CRC match and true when crc shows fault and clear the fault and not print anything.
    CRC issue was PJRC's - in startup.c the crc as calculated was not put into the info struct:
    	info->crc = crc;
    Then the complete CRC tested solution is:
    #include <Arduino.h>
    #include <CrashReport.h>
    /* Crash report info stored in the top 128 bytes of OCRAM (at 0x2027FF80)
    struct arm_fault_info_struct {
            uint32_t len;
            uint32_t ipsr;
            uint32_t cfsr;
            uint32_t hfsr;
            uint32_t mmfar;
            uint32_t bfar;
            uint32_t ret;
            uint32_t xpsr;
            uint32_t crc;
    extern unsigned long _ebss;
    size_t CrashReportClass::printTo(Print& p) const
      uint32_t i, crc;
      const uint32_t *pp, *end;
      crc = 0xFFFFFFFF;
      pp = (uint32_t *)info;
      end = pp + (sizeof(*info) / 4 - 1);
      while (pp < end) {
        crc ^= *pp++;
        for (i=0; i < 32; i++) crc = (crc >> 1) ^ (crc & 1)*0xEDB88320;
      if( info->crc == crc ) {
        p.println("CrashReport ... Hello World");
        p.print("  length: ");
        p.println(info->len);
        p.print("  IPSR: ");
        p.println(info->ipsr, HEX);
        uint32_t _CFSR = info->cfsr;
        if (_CFSR > 0) {
          p.print("  CFSR: ");
          p.println(info->cfsr, HEX);
          if ((_CFSR & 0xff) > 0) {
          //Memory Management Faults
          if ((_CFSR & 1) == 1) {
            p.println("\t(IACCVIOL) Instruction Access Violation");
          } else  if (((_CFSR & (0x02)) >> 1) == 1) {
            p.println("\t(DACCVIOL) Data Access Violation");
          } else if (((_CFSR & (0x08)) >> 3) == 1) {
            p.println("\t(MUNSTKERR) MemMange Fault on Unstacking");
          } else if (((_CFSR & (0x10)) >> 4) == 1) {
            p.println("\t(MSTKERR) MemMange Fault on stacking");
          } else if (((_CFSR & (0x20)) >> 5) == 1) {
            p.println("\t(MLSPERR) MemMange Fault on FP Lazy State");
          if (((_CFSR & (0x80)) >> 7) == 1) {
            p.print("\t(MMARVALID) Accessed Address: 0x");
            p.print(info->mmfar, HEX);
            if (info->mmfar < 32) p.print(" (nullptr)");
            if ((info->mmfar >= (uint32_t)&_ebss) && (info->mmfar < (uint32_t)&_ebss + 32))
            p.print(" (Stack problem)\n\tCheck for stack overflows, array bounds, etc.");
            p.println();
          //Bus Fault Status Register BFSR
          if (((_CFSR & 0x100) >> 8) == 1) {
          p.println("\t(IBUSERR) Instruction Bus Error");
          } else  if (((_CFSR & (0x200)) >> 9) == 1) {
          p.println("\t(PRECISERR) Data bus error(address in BFAR)");
          } else if (((_CFSR & (0x400)) >> 10) == 1) {
          p.println("\t(IMPRECISERR) Data bus error but address not related to instruction");
          } else if (((_CFSR & (0x800)) >> 11) == 1) {
          p.println("\t(UNSTKERR) Bus Fault on unstacking for a return from exception");
          } else if (((_CFSR & (0x1000)) >> 12) == 1) {
          p.println("\t(STKERR) Bus Fault on stacking for exception entry");
          } else if (((_CFSR & (0x2000)) >> 13) == 1) {
          p.println("\t(LSPERR) Bus Fault on FP lazy state preservation");
          if (((_CFSR & (0x8000)) >> 15) == 1) {
          p.print("\t(BFARVALID) Accessed Address: 0x");
          p.println(info->bfar, HEX);
          //Usage Fault Status Register UFSR
          if (((_CFSR & 0x10000) >> 16) == 1) {
          p.println("\t(UNDEFINSTR) Undefined instruction");
          } else  if (((_CFSR & (0x20000)) >> 17) == 1) {
          p.println("\t(INVSTATE) Instruction makes illegal use of EPSR)");
          } else if (((_CFSR & (0x40000)) >> 18) == 1) {
          p.println("\t(INVPC) Usage fault: invalid EXC_RETURN");
          } else if (((_CFSR & (0x80000)) >> 19) == 1) {
          p.println("\t(NOCP) No Coprocessor");
          } else if (((_CFSR & (0x1000000)) >> 24) == 1) {
          p.println("\t(UNALIGNED) Unaligned access UsageFault");
          } else if (((_CFSR & (0x2000000)) >> 25) == 1) {
          p.println("\t(DIVBYZERO) Divide by zero");
        uint32_t _HFSR = info->hfsr;
        if (_HFSR > 0) {
          p.print("  HTSR: ");
          p.println(info->hfsr, HEX);
          if (((_HFSR & (0x02)) >> 1) == 1) {
          p.println("\t(VECTTBL) Bus Fault on Vec Table Read");
          } else if (((_HFSR & (0x40000000)) >> 30) == 1) {
           p.println("\t(FORCED) Forced Hard Fault");
          } else if (((_HFSR & (0x80000000)) >> 31) == 31) {
           p.println("\t(DEBUGEVT) Reserved for Debug");
        p.print("  MMFAR: ");
        p.println(info->mmfar, HEX);
        p.print("  BFAR: ");
        p.print("  return address: ");
        p.println(info->ret, HEX);
        p.print("  XPSR: ");
        p.println(info->xpsr, HEX);
        p.print("  crc: ");
        p.println(info->crc, HEX);
        // p.println("Crash Report not Available");
      return 1;
      uint32_t i, crc;
      crc = 0xFFFFFFFF;
      while (pp < end) {
        crc ^= *pp++;
        info->len = 0;
        info->cfsr  = 0;
    CrashReportClass CrashReport;
  15. #40
    14,421
    Updated to test another couple of faults - linked page has other notes on debugging.
    Frank had to enable and handle the divide by zero case? So #4 is ignored.
    // Found a couple of Faults to force here :: https://interrupt.memfault.com/blog/cortex-m-fault-debug
    int illegal_instruction_execution(void) {
      int (*bad_instruction)(void) = (void *)0xE0000000;
      return bad_instruction();
      delay ( 100 );
      delay ( 1000 );
        char cc = Serial.read();
        Serial.println("\nIt's your fault!\n");
        delay ( 50 );
        if ( cc == '0' ) {
          illegal_instruction_execution();
        else if ( cc == '1' ) { // Bad Address Read
          uint32_t ff = *(volatile uint32_t *)0xbadcafe;
          Serial.print(ff);
        else if ( cc == '2' ) { // Coprocessor Fault - turn off FPU
          __asm volatile(
            "ldr r0, =0xE000ED88 \n"
            "mov r1, #0 \n"
            "str r1, [r0] \n"
            "dsb \n"
            "vmov r0, s0 \n"
        else if ( cc == '3' ) { // bad_addr_double_word_write
          volatile uint64_t *buf = (volatile uint64_t *)0x30000000;
          *buf = 0x1122334455667788;
        else if ( cc == '4' ) { // Divide by Zero (not enabled?)
          cc = cc - '4';
          cc /= cc;
        else if ( cc == '5' ) {
        else if ( cc == '6' ) {
        else { // default fault on Serial with no other fault ... from 'Enter'
      delay ( 3 );
      delay ( 40 );
  16. #41
    New York
    7,196
    @defragster
    Good catch on the missing info->crc in startup.c. Completely missed it - should have caught it. Now for the fun part. I copied and pasted your changes in my copy of CrashReport.cpp and .h and used the following sketch.
      delay ( 100 );
      delay ( 1000 );
        delay ( 50 );
      delay ( 10 );
      delay ( 50 );
    Nothing fancy. I loaded it to the T4.1 and on fresh load received:
    First message to SerMon
    D:\Users\Merli\Documents\Arduino\CrashRepot_example\CrashRepot_example.ino Jun 21 2021 05:24:57
    then nothing till I hit return:
    It's your fault!
    but no fault report. On restart since there is a fault present it will print the crash report:
      length: 9
      IPSR: 3
      CFSR: 82
      HTSR: 40000000
      MMFAR: 0
      BFAR: 0
      return address: C4
      XPSR: 61000000
      crc: FB78D819
    So something else is going on as I mentioned first time failure at len > 9 by a lot as I mentioned before. The fixes do clear the issue if you remove the fault and reload.
    A couple of other comments. Don't think you need to test on clear so to print no crash present or recovered. If there is no fault present you don't really want to tell the user he recovered from a crash. That should be done automatically by the crash report as we had it before with the print from the crashreport. Just an extra coding for the user.
    Second. Think you should clear the whole structure not just CFSR and HFSR. Just my 2 cents.
  17. #42
    24,452
    I merged all the pending pull requests, even though the indenting is a little messed up.
    I'm not understanding why clear() is so complicated. What purpose does that serve?
  18. #43
    New York
    7,196
    Don't think it does. This works just as well with @defragsters fix:
      info->len = 0;
      info->ipsr  = 0;
      info->cfsr  = 0;
      info->hfsr  = 0;
      info->mmfar = 0;
      info->bfar  = 0;
      info->ret = 0;
      info->xpsr  = 0;
      info->crc = 0;
    Sure there is an easier way to reset the struct then it would be simpler.
  19. #44
    24,452
    Do you have any other changes pending? I'd like to get everything merged before I make large changes...
  20. #45
    New York
    7,196
    Just submitted a PR changing to the simplified clear and putting the print. Gives another approach I guess - works both ways. As I mentioned - can't figure out why on first fault not dumping the report?
    https://github.com/PaulStoffregen/cores/pull/570
    EDIT: Got really stuck yesterday on the missing CRC and the not using the flush_delete otherwise might have gotten further on the list. Sorry
  21. #46
    New York
    7,196
    @PaulStoffregen
    Was looking SRC_SRSR, but will the resets even trigger the fault handler? or will a reset handler be required?
  22. #47
    24,452
    I'm adding code right now to print messages based on SRC_SRSR....
  23. #48
    New York
    7,196
    Got it - was begining to take a look at it but guess you are back into the thick of it agaim
  24. #49
    9,206
    Hi all, Sorry I have been distracted.
    It will be great to have the ability to find out what happened.
    I keep wondering with this crash report if it feels like every run of your program expects to crash... Sorry I am not clear here...
    Wondering if there should be some bool/boolean that you can ask if it crashed...
    Not sure if it should be operator like:
      if (CrashReport) {
    Or some method...
  25. #50
    24,452
    That's a good point. Added.
    https://github.com/PaulStoffregen/co...5b8606efc53ddd
    The clear() function no longer returns anything. Think of it as "delete".
    Got it - was begining to take a look at it but guess you are back into the thick of it again
    I'm going to take a break, until at least late tonight. Now's the perfect time to pull the latest from github and jump in if you'd like to make changes.
