Well this is my first attempt at modifying this code. I know it won't work but I wanted to see if I could get somebody to steer me in the right direction. I commented out all the analog stuff and just tried to put in a few things to see if anything is close. What I really don't understand is where the code tells the driver to go in either direction. If anybody could point that out I'd appreciate it, or anything else that would help.
#include <AccelStepper.h> // accelstepper library
AccelStepper stepper(1, 8, 9); // direction Digital 9 (CCW), pulses Digital 8 (CLK)
#define button 4
#define button 5
//Pins
//const byte Analog_X_pin = A1; // x-axis readings
const byte enablePin = 7;
const byte button 4
const byte button 5
//Variables
//int Analog_X = 0; //x-axis value
//int Analog_X_AVG = 0; //x-axis value average
//PINS
//pinMode(Analog_X_pin, INPUT);
// pinMode(Analog_X_pin, INPUT);
pinMode(enablePin, OUTPUT);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4 INPUT_PULLUP); //button 1
pinMode(5 INPUT_PULLUP); //button 2
InitialValues(); // averaging the values of analog pin 0 (value from potmeter)
// Stepper parameters
// setting up some default values for maximum speed and maximum acceleration
stepper.setMaxSpeed(2000); //SPEED = Steps / second
stepper.setAcceleration(1000); //ACCELERATION = Steps /(second)^2
stepper.setSpeed(1000);
if (digitalRead(SW1) && digitalRead(SW2)) digitalWrite(motorOn, LOW);
digitalWrite(motorOn, HIGH);
ReadLimits();
stepper.runSpeed(); //step the motor (this will step the motor by 1 step at each loop indefinitely)
void ReadLimits()
if( digitalRead(2)==LOW && stepper.speed()>0 )//read input, assuming they have pull-up resistors.
stepper.setSpeed(0);
if( digitalRead(3)==LOW && stepper.speed()<0 )//read input, assuming they have pull-up resistors.
void digitalRead(4) {
if (pin 4 HIGH) {
digitalWrite(enablePin, HIGH); // enable the driver
stepper.setSpeed(2000));
digitalWrite(enablePin, LOW); // disable the driver
if (pin 5 HIGH) {
void ReadAnalog() {
if (abs(Analog_X-Analog_X_AVG) > 50) {
stepper.setSpeed(5*(Analog_X-Analog_X_AVG));
// Reading the potentiometer in the joystick:
Analog_X = analogRead(Analog_X_pin);
// if the value is 25 "value away" from the average (midpoint), we allow the update of the speed
// This is a sort of a filter for the inaccuracy of the reading
stepper.setSpeed(5 * (Analog_X-Analog_X_AVG));
void InitialValues() {
//Set the values to zero before averaging
float tempX = 0;
// read the analog 50x, then calculate an average.
// they will be the reference values
for (int i = 0; i<50; i++) {
//tempX += analogRead(Analog_X_pin);
delay(10); //allowing a little time between two readings
//Analog_X_AVG = tempX/50;
//Serial.print("AVG_X: ");
//Serial.println(Analog_X_AVG);
Serial.println("Calibration finished");
