I have been working with a Teensy 3.2 connected to a ILI9341 TFT/Touch display from Paul's store, and I am having a problem debouncing the touch screen. I have a very simple sketch that takes a stylus touch point, maps it to an appropriate display coordinate, and draws a small filled circle at the mapped point. For each point I print out the program time in milliSec, the raw (touch screen) coordinates and the mapped display coordinates. I also have some 'debounce' code to prevent multiple touch detections from a single stylus tap. The debounce code works perfectly, UNLESS I tap on the lower left hand corner of the screen, where I get 10-15 touch detections even with the debounce code present. Here's the sketch:
Created: 2/15/2021 4:16:52 PM
Author: FRANKNEWXPS15\Frank
// Includes
#include <XPT2046_Touchscreen.h>
#include <ILI9341_t3n.h>
#include "ili9341_t3n_font_Arial.h"
// This is calibration data for the raw touch data to the screen coordinates
// Warning, These are approximate values
#define TS_MINX 600
#define TS_MINY 600
#define TS_MAXX 3758
#define TS_MAXY 3612
#define SCREEN_ORIENTATION_1
//02/16/21 change from using #defines to variables, so can
// update via calibration.
uint16_t ts_minx = TS_MINX;
uint16_t ts_maxx = TS_MAXX;
uint16_t ts_miny = TS_MINY;
uint16_t ts_maxy = TS_MAXY;
// Settings and objects
//02/15/21 pin assignments from https://www.pjrc.com/store/display_ili9341_touch.html
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 7
#define TFT_SCK 13
#define TFT_MISO 12
#define TFT_MOSI 11
#define TOUCH_CS 8
XPT2046_Touchscreen ts(TOUCH_CS);
ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO);
// Size of the color selection boxes and the paintbrush size
#define MAX_DISPLAY_X 240
#define MAX_DISPLAY_Y 320
#define NUMBOXES 7
//#define BOXSIZE MAX_DISPLAY_X / NUMBOXES
#define BOXSIZE 34
#define PENRADIUS 3
int oldcolor, currentcolor;
int BoxColorArray[] = { ILI9341_RED, ILI9341_YELLOW, ILI9341_GREEN, ILI9341_CYAN,
ILI9341_BLUE, ILI9341_MAGENTA, ILI9341_WHITE, ILI9341_ORANGE, ILI9341_GREENYELLOW, ILI9341_PINK };
// Setup
void setup(void)
while (!Serial && (millis() <= 3000))
tft.begin();
tft.setRotation(1);
// by default use SPI
if (!ts.begin()) {
Serial.println("Couldn't start touchscreen controller");
while (1);
Serial.println("Touchscreen started");
// See if there's any touch data for us
// You can also wait for a touch
if (!ts.touched())
return;
// Retrieve a point
TS_Point p = ts.getPoint();
Serial.printf("%lu: Raw P(%d,%d) maps to ", millis(), p.x, p.y);
// Scale from ~0->4000 to tft.width using the calibration #'s
#ifdef SCREEN_ORIENTATION_1
p.x = map(p.x, TS_MAXX, TS_MINX, 0, tft.width());
p.y = map(p.y, TS_MAXY, TS_MINY, 0, tft.height());
#else
uint16_t px = map(p.y, TS_MINY, TS_MAXY, 0, tft.width());
p.y = map(p.x, TS_MAXX, TS_MINX, 0, tft.height());
p.x = px;
Serial.printf(" (%d,%d): ", p.x, p.y);
Serial.printf("drawing circle at (%d,%d)\n", p.x, p.y);
tft.fillCircle(p.x, p.y, PENRADIUS, ILI9341_RED);
//touch screen debounce
while (ts.touched())
p = ts.getPoint();
delay(10);
And a photo of the setup, showing some of the dots from the program
And here's some of the printed output, showing individual stylus presses and then a run of touch detections spaced about 10 mSec apart, all with the same approximate coordinates; these were generated from just one stylus touch in the lower left hand corner (corner closest to the Teensy and farthest away from the prototype board)
Opening port
Port open
19651: Raw P(3766,3562) maps to (0,3): drawing circle at (0,3)
29334: Raw P(708,3459) maps to (309,12): drawing circle at (309,12)
38322: Raw P(3813,362) maps to (-5,258): drawing circle at (-5,258)
38333: Raw P(3825,307) maps to (-6,263): drawing circle at (-6,263)
38343: Raw P(3844,307) maps to (-8,263): drawing circle at (-8,263)
38354: Raw P(3840,305) maps to (-8,263): drawing circle at (-8,263)
38364: Raw P(3840,305) maps to (-8,263): drawing circle at (-8,263)
38375: Raw P(3862,317) maps to (-10,262): drawing circle at (-10,262)
38385: Raw P(3861,301) maps to (-10,263): drawing circle at (-10,263)
38395: Raw P(3845,292) maps to (-8,264): drawing circle at (-8,264)
Any ideas why this is happening?
TIA,
Frank
