Results 1 to 9 of 9
Thread: Teensy 4.1 and CAN (with FlexCAN_T4)
    Mar 2021
    5
    Good morning guys
    I have been trying all morning to make a simple CAN communication but there is no way (I have read several threads about it in this forum)
    I write this code:
    #include <FlexCAN_T4.h>
    FlexCAN_T4<CAN2, RX_SIZE_256, TX_SIZE_16> can2;
    CAN_message_t msg;
    can2.begin();
    can2.setBaudRate(250000);
    msg.id = 0x100;
    msg.len = 8;
    msg.flags.extended = 0;
    msg.flags.remote = 0;
    msg.flags.overrun = 0;
    msg.flags.reserved = 0;
    msg.buf[0] = 10;
    msg.buf[1] = 20;
    msg.buf[2] = 0;
    msg.buf[3] = 100;
    msg.buf[4] = 128;
    msg.buf[5] = 64;
    msg.buf[6] = 32;
    msg.buf[7] = 16;
    can2.write(msg);
    if ( can2.read(msg) ) {
    Serial.print("CAN2 ");
    Serial.print("MB: "); Serial.print(msg.mb);
    Serial.print(" ID: 0x"); Serial.print(msg.id, HEX );
    Serial.print(" EXT: "); Serial.print(msg.flags.extended );
    Serial.print(" LEN: "); Serial.print(msg.len);
    Serial.print(" DATA: ");
    for ( uint8_t i = 0; i < 8; i++ ) {
    Serial.print(msg.buf[i]); Serial.print(" ");
    But no send / receive anything. Use a TJA1051T transceiver. Also use a USB/CAN adaptor to check connection, but no receive any message and if send a message Teensy no receive it.
    Any idea?
    Dec 2016
    Montreal, Canada
    3,666
    what pins are you using on teensy? CAN2 uses pins 0 and 1, also confirm first with the fifo interrupt example, it works as is just change the bus to CAN2 in constructor, if that still doesn't work, try to print mailboxStatus() from the loop(), if the transmit mailboxes keep filling up, and not clearing, that means you have a bad connection issue and it's not software end (unless baudrate is wrong)
    Also not a good idea to flood the bus, you're constantly flooding transmits in an endless loop
    Mar 2021
    5
    Yes, use pins 0 and 1. 0 (rx) to Tx on transceiver, and 1 (tx) to Rx on transceiver.
    fifo example not work, but if print mailboxStatus() show:
    FIFO Enabled --> Interrupt Enabled
    FIFO Filters in use: 8
    Remaining Mailboxes: 8
    MB8 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x76D)(Payload: 1 2 3 4 5 6 7 8)
    MB9 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x4BC)(Payload: 1 2 3 4 5 6 7 8)
    MB10 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x489)(Payload: 1 2 3 4 5 6 7 8)
    MB11 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x599)(Payload: 1 2 3 4 5 6 7 8)
    MB12 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x151)(Payload: 1 2 3 4 5 6 7 8)
    MB13 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x5F2)(Payload: 1 2 3 4 5 6 7 8)
    MB14 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x641)(Payload: 1 2 3 4 5 6 7 8)
    MB15 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0xC6)(Payload: 1 2 3 4 5 6 7 8)
    Transceiver is powered by 5V, like as datasheet.
    Dec 2016
    Montreal, Canada
    3,666
    all your transmits are full, theres a connection issue, check your wiring
    Dec 2016
    Montreal, Canada
    3,666
    check your transceiver's operating mode as well as per datasheet. 2 pins are involved. EN should be tied HIGH and S should be tied LOW
    also you should be using the /3 chip model for Teensy, not the /E
    The TJA1051 is available in three versions, distinguished only by the function of pin 5: • The TJA1051T is backwards compatible with the TJA1050 • The TJA1051T/3 and TJA1051TK/3 allow for direct interfacing to microcontrollers with supply voltages down to 3 V • The TJA1051T/E allows the transceiver to be switched to a very low-current Off mode.
    Mar 2021
    5
    Thank for your reply.
    Use TJA1051T/2Z, i will try TJA1051T/3. I will post a new answer when I test with this model.
    Thanks!
    Mar 2021
    5
    Hi guys,
    I am testing with the TJA1051T/3 version (which should work at 3.3v) but I am not getting any satisfactory results.
    The connections are as follows:
    1 - TXD - to pin 1 Teensy
    2 - GND
    3 - 5V
    4 - RXD - to pin 0 Teensy
    5 - NC
    6 - CAN-L
    7 - CAN-H
    8 - GND
    Beetween CAN-L and CAN-H connect a 120ohm resistor, also in can-usb adaptor. Total impedance on bus are 60ohm.
    Any idea?
    Regards
    Dec 2016
    Montreal, Canada
    3,666
    read the blue
Name:	Screenshot_20210309-022559_Adobe Acrobat.jpg
    7.2.2 Internal biasing of TXD, S and EN input pins Pin TXD has an internal pull-up to VIO and pins S and EN (TJA1051T/E) have internal pull-downs to GND. This ensures a safe, defined state in case one or more of these pins is left floating.
    7.3 VIO supply pin There are three versions of the TJA1051 available, only differing in the function of a single pin. Pin 5 is either an enable control input (EN), a VIO supply pin or is not connected. Pin VIO on the TJA1051T/3 and TJA1051TK/3 should be connected to the microcontroller supply voltage (see Figure 6 ). This will adjust the signal levels of pins TXD, RXD and S to the I/O levels of the microcontroller. For versions of the TJA1051 without a VIO pin, the VIO input is internally connected to VCC. This sets the signal levels of pins TXD, RXD and S to levels compatible with 5 V microcontrollers.
    So, with 7.3 section, you must supply 3.3v to Vio pin 5
    Mar 2021
    5
    Sorry! Connect 5 to 3.3v and work OK!!!
    Thanks and sorry for my carelessness.
