Results 1 to 3 of 3
Thread: teensy4.0 linux18.04 compilation calss vector init
    Hi
    sort presentation :
    class a_classe {
    std::vector<double>  m_A
    and try to this in loop:
    a_classe the_class
    the_class.m_A= {1,2};
    Compile but seemnot afect values to vector m_A
    Another way :
    class a_classe {
    void afunction(){
    works fine but not convenient because definition is hard coded the class can only have an only one instantiation/definition.
    How can do to do it out of class definition?
    Thank's Laurent.
    23,980
    Please show complete programs. Even if the rest of the code is trivial, it is much easier to answer if we can copy the code into Arduino and run on a Teensy without the work of adding (guessing) the missing lines.
    I put this code sample for fun...
    Because when I test it to verify that my post sample doesn't works it is work fine...
    The only difference is is that I putit in a .h .cpp files...
    So I do compare with the original code.
    Sorry for these troubles...
    #include <vector>
    class Un_rst
        public:
        std::vector<double>  m_A;
        double compute();
    double Un_rst::compute()
        for (unsigned i = 0; i <= m_A.size() - 1; i++) {Serial.print("m_A: "); Serial.print(m_A[i],5);} ;
    Un_rst theRst;
      Serial.begin(115200);//USB
       while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
      theRst.m_A={1,2,3};
      theRst.compute();
