Results 1 to 7 of 7
Thread: Teency RTC manually set time issue
    I need to manually set the RTC on the Teency 3.6 as it is going to my used by non-tekies.
    the .h file had this:
    //void setTime(int hr,int min,int sec,int day, int month, int yr);
    so I did this in the setup:
    setTime(3,22,46,1,2,23);
    hourFormat12();
    it does not retain the manually set time.
    the code:
    * TimeRTC.pde
    * example code illustrating Time library with Real Time Clock.
    #include <TimeLib.h>
    //int led = 13;
    // pinMode(led, OUTPUT);
    // set the Time library to use Teensy 3.0's RTC to keep time
    while (!Serial); // Wait for Arduino Serial Monitor to open
    //if (timeStatus()!= timeSet) {digitalWrite(led, HIGH);//fail
    //delay(500);
    // digitalWrite(led, LOW);
    // else {digitalWrite(led, HIGH);//pass
    // delay(500);
    // delay(500);
    // digitalWrite(led, HIGH);}
    //********************************I wouls think that I only need the next line to manualy set the time:
    // h m s
    hourFormat12(); // the hour now in 12 hour format
    // if (Serial.available()) {
    // time_t t = processSyncMessage();
    // if (t != 0) {
    // Teensy3Clock.set(t); // set the RTC
    // setTime(t);
    digitalClockDisplay();
    void digitalClockDisplay() {
    // digital clock display of the time
    Serial.print(" h: "); Serial.print(hour());
    Serial.print(" M: "); Serial.print(minute());
    Serial.print(" S: "); Serial.print(second());
    // printDigits(minute());
    // printDigits(second());
    Serial.print(" ");
    // Serial.print(day());
    // Serial.print(" ");
    // Serial.print(month());
    // Serial.print(year());
    time_t getTeensy3Time()
    return Teensy3Clock.get();
    /* code to process time sync messages from the serial port
    #define TIME_HEADER "T" // Header tag for serial time sync message
    unsigned long processSyncMessage() {
    unsigned long pctime = 0L;
    const unsigned long DEFAULT_TIME = 1357041600; // Jan 1 2013
    if(Serial.find(TIME_HEADER)) {
    pctime = Serial.parseInt();
    return pctime;
    if( pctime < DEFAULT_TIME) { // check the value is a valid time (greater than Jan 1 2013)
    pctime = 0L; // return 0 to indicate that the time is not valid
    return pctime;
    void printDigits(int digits){
    // utility function for digital clock display: prints preceding colon and leading 0
    Serial.print(":");
    if(digits < 10)
    Serial.print('0');
    Serial.print(digits);
    Aug 2018
    Brisbane, Australia
    54
    You need to call Teensy3Clock.set() somewhere to update the RTC
    C is not my native language, I am more of a LabView guy.
    I am pulling this stuff from the TimLib.h and guessing as to how to work this to no avail.
    'int min' redeclared as different kind of symbol
    I also don't underdant what's going on here:
    if (t != 0) {
    setTime(t);
    like this line: time_t t = processSyncMessage(); time_t is red but the following t is not and t in part of this line: Teensy3Clock.set(t); // set the RTC.
    so this is a SWAG of how to make a one shot program that I will blend into other programs once I get the manual time setting program to work.
    I will have time setting buttons on the back of the clocks.
    int THour=3 ;
    int TMinute=10;
    int TSecond=22;
    // from the timeLib.h
    hourFormat12(); // this is in the TimeLib but not red, why?
    // Teensy3Clock.set(); // no matching function for call to 'teensy3_clock_class::set(int, int, int, int, int, int)'
    // no matching function for call to 'teensy3_clock_class::set()'
    setTime(THour,TMinute,TSecond,1,2,23);
    // code to process time sync messages from the serial port
    return pctime;
    return pctime;
Name:	Real Code a.jpg
Name:	Real Code b.jpg
    Aug 2018
    Brisbane, Australia
    54
    Also note that the Arduino timelib has no concept of timezone so you need to make allowances in your code. As a rule I ALWAYS set the RTC to UTC time and apply the appropriate adjustment for timezone when getting / setting the RTC
    the time is 12:01Click image for larger version.
Name:	Binary Clock.jpg
    Aug 2018
    Brisbane, Australia
    54
    Here is a simple piece of code to set the RTC to 05:30:00 on 05 Mar 2021. Provided the RTC battery is connected, that time will be maintained even while the teensy is not powered.
    	tmElements_t tmElements;
    	// write new time values to rt clock
    	tmElements.Second = 0;
    	tmElements.Minute = 30
    	tmElements.Hour = 5;
    // not needed		tmElements.Wday;	// day of week, sunday is day 1
    	tmElements.Day = 5
    	tmElements.Month = 3
    	tmElements.Year = CalendarYrToTm(2021);		// offset from 1970;
    	Teensy3Clock.set(makeTime(tmElements));
    To retrieve the time from the RTC to use it in your code, simply call
    	// read it back and set the software clock
    	const time_t rtcTime = Teensy3Clock.get();
    	setTime(rtcTime);
    this clock is going to my parents (in there 80's ) so i wasn't thinking of Time zones. here is the full code. Thanks for your help, no way I could figure that out, want even close to what I was seeing in the documents.
    int SetMinBtn=1;
    int SetHourBtn=0;
    int Second=0;
    int IncMinutes=0;// set minutes button
    int IncHours=1; // set hours button
    int HourVal=0; ///hour();
    int MinVal =0; //minute();
    int SecVal =0; //second();
    int i;
    int j;
    pinMode(SetMinBtn, INPUT_PULLUP);//
    pinMode(SetHourBtn, INPUT_PULLUP);//
    i = digitalRead(SetMinBtn);
    j = digitalRead(SetHourBtn);
    if(i==0||j==0)
    MinVal =minute();
    HourVal=hour();
    if(i==0) {MinVal++; if(MinVal>59) {MinVal=0;} }
    if( j==0) {HourVal++; if(HourVal>12){HourVal=1;} }
    tmElements.Second=0;
    tmElements.Minute=MinVal;
    tmElements.Hour=HourVal;
    tmElements.Day=0;
    tmElements.Month=0;
    tmElements.Year=CalendarYrToTm(2021);
    setTime(rtcTime);
    Serial.print("hours:");Serial.print(hour());
    Serial.print(" minutes:");Serial.print(minute());
    Serial.print(" Seconds:");Serial.println(second());
    return pctime;
    return pctime;
