Results 1 to 2 of 2
Thread: How does AudioSynthWaveformDc work?
    Hi, since there is no envelope to control waveform frequency modulation or filter frequency modulation I tried to use the "DC" output.
    When I press the MIDI keys I want the Serial monitor to show values going up to 1.0 and when I release the keys to show values going down to -1.
    This code, however, does nothing to the values on the Serial monitor when I press and release keys on my MIDI keyboard:
    AudioSynthWaveformDc     pitchEnvelope;
    AudioOutputI2S           i2s1;
      usbMIDI.setHandleNoteOn(OnNoteOn);
      usbMIDI.setHandleNoteOff(OnNoteOff);
    int attackTime=1000;
    int releaseTime=1000;
    void loop(){
      usbMIDI.read();
      Serial.println(pitchEnvelope.read());
    void OnNoteOn(byte channel, byte note, byte velocity){
      pitchEnvelope.amplitude(1,attackTime);
    void OnNoteOff(byte channel, byte note, byte velocity){
      pitchEnvelope.amplitude(-1,releaseTime);
    24,122
    You need AudioMemory() in setup(). See any of the examples in File > Examples > Audio.
    To get a ADSR or AD style control signal, you would feed the DC output through an envelope effect. For only attack-decay triggered by a single event, set the sustain level to zero.
