Results 1 to 3 of 3
Thread: Error compiling Teensy4 cores
    Feb 2021
    2
    Hello everyone,
    Currently Im using teensy3 to distribute firmware that uses a third party SDK. The program is written in C and to compile it I use Scons adding the links to core teensy3.
    Now, we want to migrate to teensy4, but when I try to compile the cores, compiler shows this error:
    /opt/arduino/hardware/teensy/avr/cores/teensy4/startup.c:770: undefined reference to `pendablesrvreq_isr'
    /opt/arduino/hardware/teensy/avr/cores/teensy4/startup.c:770: undefined reference to `systick_isr'
    collect2: error: ld returned 1 exit status
    This is the Scons script
        env.Append(CPPPATH=[env['TEENSY4']])
        env.Append(CPPDEFINES=['__IMXRT1062__', 'ARDUINO_TEENSY_MICROMOD', 'USB_SERIAL', 'LAYOUT_US_ENGLISH'])
        env.Append(CPPDEFINES={'F_CPU' : 600000000})
        env.Append(CFLAGS=['-mcpu=cortex-m7',
                           '-mthumb',
    		       '-mfloat-abi=hard',
                           '-mfpu=fpv5-d16',
                           '-ffunction-sections',
                           '-fdata-sections',
                           '-nostdlib', '-Wall','-g', '-O2'])
        env.Append(LINKFLAGS=['-mcpu=cortex-m7',
                              '-mfloat-abi=hard',
                              '-mfpu=fpv5-d16',
                              '-mthumb',
                              '-Wl,--gc-sections',
                              '-T' + os.path.join(env['TEENSY4'], 'imxrt1062.ld')])
        variant_top_dir = env['VARIANT_TOP_DIR']
        env.Append(LIBPATH=[variant_top_dir.Dir(env['RUNTIME_DIR'])])
    And these are the source files that I adding to build
    teensy_sources = [
            'startup.c',
    	'bootdata.c',
    	'digital.c',
    	'analog.c',
            'nonstd.c',
            'pwm.c',
            'rtc.c',
            'delay.c',
    	'clockspeed.c',
    	'tempmon.c',
            'usb.c',
            'usb_serial.c',
            'usb_serial2.c',
            'usb_serial3.c',
            'usb_desc.c',
            'usb_midi.c',
            'usb_mouse.c',
            'usb_touch.c',
            'usb_joystick.c',
            'keylayouts.c',
            'usb_keyboard.c',
            'usb_rawhid.c',
            'usb_mtp.c',
            'usb_seremu.c',
            'debugprintf.c']
    Can anybody help me figure out what's wrong in my script? I'll gladly take any advice or idea or how to troubleshoot this. Thanks for your time.
    8,843
    Sorry I know nothing abot scones or the like, so not sure how much help I will be...
    But one thing stands out is: ARDUINO_TEENSY_MICROMOD
    That is for a non-existent board that is rummer to be coming. You might want to set that instead to : ARDUINO_TEENSY40
    Also grep is your friend:
    systick_isr is in the file EventResponder.cpp
    And I believe the other one is as well...
    Feb 2021
    2
    Hello KurtE,
    Thanks for your answer, I will try and tell you how it goes.
    On the other hand, about EventResponder, I read that I must first compile this class and then link it to the source files in C. But I don't know how to do that.
    So, th problem is that for Teensy3, all source files are in C but for Teensy4 the source files has C and C++ files.
