Results 1 to 4 of 4
Thread: i2c_t3
    Dec 2020
    11
    i2c_t3
    I wanted to use i2c_t3 in a project but was having problems. So I tried one the the examples from github and get the same errors:
    #include <Arduino.h>
    #include <i2c_t3.h>
    // Function prototypes
    void print_scan_status(uint8_t target, uint8_t all);
    uint8_t found, target, all;
        pinMode(LED_BUILTIN,OUTPUT);    // LED
        pinMode(12,INPUT_PULLUP);       // pull pin 12 low to show ACK only results
        pinMode(11,INPUT_PULLUP);       // pull pin 11 low for a more verbose result (shows both ACK and NACK)
        // Setup for Master mode, pins 18/19, external pullups, 400kHz, 10ms default timeout
        Wire.begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_EXT, 400000);
        Wire.setDefaultTimeout(10000); // 10ms
        // Scan I2C addresses
        if(digitalRead(12) == LOW || digitalRead(11) == LOW)
            all = (digitalRead(11) == LOW);
            found = 0;
            Serial.print("---------------------------------------------------\n");
            Serial.print("Starting scan...\n");
            digitalWrite(LED_BUILTIN,HIGH); // LED on
            for(target = 1; target <= 0x7F; target++) // sweep addr, skip general call
                Wire.beginTransmission(target);       // slave addr
                Wire.endTransmission();               // no data, just addr
                print_scan_status(target, all);
            digitalWrite(LED_BUILTIN,LOW); // LED off
            if(!found) Serial.print("No devices found.\n");
            delay(500); // delay to space out tests
    // print scan status
        switch(Wire.status())
        case I2C_WAITING:
            Serial.printf("Addr: 0x%02X ACK\n", target);
            found = 1;
        case I2C_ADDR_NAK:
            if(all) Serial.printf("Addr: 0x%02X\n", target);
        default:
    Errors:
    > Executing task in folder I2C Testing: platformio run <
    Processing teensy41 (platform: teensy; board: teensy41; framework: arduino)
    Verbose mode can be enabled via `-v, --verbose` option
    CONFIGURATION: https://docs.platformio.org/page/boa.../teensy41.html
    PLATFORM: Teensy (4.11.1) > Teensy 4.1
    HARDWARE: IMXRT1062 600MHz, 512KB RAM, 7.75MB Flash
    DEBUG: Current (jlink) External (jlink)
    PACKAGES:
    - framework-arduinoteensy 1.153.0 (1.53)
    - toolchain-gccarmnoneeabi 1.50401.190816 (5.4.1)
    LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
    LDF Modes: Finder ~ chain, Compatibility ~ soft
    Found 89 compatible libraries
    Scanning dependencies...
    Dependency Graph
    |-- <i2c_t3>
    Building in release mode
    Compiling .pio/build/teensy41/src/main.cpp.o
    Compiling .pio/build/teensy41/lib4cf/i2c_t3/i2c_t3.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/AudioStream.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/Blink.cc.o
    Compiling .pio/build/teensy41/FrameworkArduino/DMAChannel.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/EventResponder.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/HardwareSerial.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/HardwareSerial1.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/HardwareSerial2.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/HardwareSerial3.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/HardwareSerial4.cpp.o
    Compiling .pio/build/teensy41/FrameworkArduino/HardwareSerial5.cpp.o
    src/main.cpp: In function 'void setup()':
    src/main.cpp:16:5: error: 'Wire' was not declared in this scope
    src/main.cpp:16:16: error: 'I2C_MASTER' was not declared in this scope
    src/main.cpp:16:34: error: 'I2C_PINS_18_19' was not declared in this scope
    src/main.cpp:16:50: error: 'I2C_PULLUP_EXT' was not declared in this scope
    src/main.cpp: In function 'void loop()':
    src/main.cpp:36:13: error: 'Wire' was not declared in this scope
    src/main.cpp: In function 'void print_scan_status(uint8_t, uint8_t)':
    src/main.cpp:53:12: error: 'Wire' was not declared in this scope
    src/main.cpp:55:10: error: 'I2C_WAITING' was not declared in this scope
    case I2C_WAITING:
    src/main.cpp:59:10: error: 'I2C_ADDR_NAK' was not declared in this scope
    case I2C_ADDR_NAK:
    Archiving .pio/build/teensy41/lib4cf/libi2c_t3.a
    *** [.pio/build/teensy41/src/main.cpp.o] Error 1
    Indexing .pio/build/teensy41/lib4cf/libi2c_t3.a
    ================================================== == [FAILED] Took 0.66 seconds ================================================== ==
    The terminal process "platformio 'run'" terminated with exit code: 1.
    Terminal will be reused by tasks, press any key to close it.
    platformio.ini
    [env:teensy41]
    platform = teensy
    board = teensy41
    framework = arduino
    monitor_speed = 115200
    monitor_port = /dev/ttyACM0
    i2c_t3 is being compiled for reasons I don't understand errors related to i2c_t3 occur.
    Thanks for the help
    Germany
    8,230
    This library does not support Teensy 4.x
    (would be nice to have an errormessage there...)
    Dec 2020
    11
    Thanks,
    I should have read the thread on i2c_t3.
    Any interest in Teensy 4.x support?
    Any one working on it?
    I'm just starting to use I2C, would like to understand how to use the I2C 1 and 2 on the Teensy 4.x.
    Time for research
    4,014
    I don't know about i2c_t3, but you can use all three I2C ports with the official Wire.h package. Just use Wire1 or Wire2 instead of Wire.
