Results 1 to 11 of 11
Thread: CRLF/Enter Command
    Mar 2021
    6
    CRLF/Enter Command
    Hello All. I would like to ask the brain trust here a question concerning the feasibility of a possible fix to a problem I'm
    having with a project. First off, I know basically nothing about the Teensy and program development, and I'm working with proprietary
    software. I have built a Robust Packet modem that after boot up, when it receives valid NMEA GPS data, it transmits a position reports at predetermined
    intervals. The problem I'm having is, it will not start beaconing unless I connect to the Teensy(4.1) with a terminal program, and kick it in the head with a CRLF/Enter command. after that, it functions correctly. Would it be possible to integrate another teensy programmed to provide the main teensy a CRLF/Enter x seconds after power is applied? My goal is to take the computer out of the loop. Thanks in advance.
    Ron
    4,017
    Many times this is because you have code in Setup that does:
    void setup ()
      // wait for things to stabilize
      while (!Serial)
      // other stuff
    Change this code to include a timeout such as:
    void setup ()
      // Wait at most 3 seconds for things to stabilize
      while (!Serial && (millis () < 3000)
      // other stuff
    Mar 2021
    6
    Thanks MichaelMeissner for the quick response, but unfortunately, I don't have access to the original code. Wish I did though. Thanks again.
    Ron
    23,999
    Quote Originally Posted by Guardrail View Post
    Yes, this should be possible. You'll need another Teensy with USB host. Teensy 3.6 and 4.1 have USB host on an easy-to-use 5 pins where you can solder pins which mate with this cable.
    https://www.pjrc.com/store/cable_usb_host_t36.html
    Teensy 4.0 also has USB host, but only as 2 tiny pads on the bottom side.
    To accomplish this, you would use the USBHost_t36 library. You'll need to create 1 instead of the serial "bigbuffer" driver, since 480 Mbit/sec communication used by Teensy 4.1 in device mode requires the large buffers.
    Your code in loop() should be fairly simple. You'll just use the boolean test on the driver instance to detect when Teensy has connected to the host port. Then maybe a short delay, open the device and send the 2 bytes, and wait for the boolean test to show when the device is unplugged.
    Mar 2021
    6
    Thanks Paul. Now it looks like I have some work to do. Thanks again.
    Mar 2021
    6
    Before I abandon this project due to lack of knowledge, I figured I'd try one more post. I attempted to follow Paul's advice(within my capability) with the USBHost_t36 library,
    and USB host cable. I compiled the USBHost_t36.H file with the following:
    delay(10000);
    usb_serial_putchar('\r');
    usb_serial_putchar('\n');
    while (true);
    It sends the desired carriage return and line feed to my terminal program(Putty) via the micro usb port, but no luck on the host cable. I assume its a serial port address issue. I also tried:
    while (!Serial && (millis () < 3000))
    delay(10000);
    Serial.write(0x0B);
    Serial.write(0x0A);
    Serial.write("\r");
    Serial.write("\n");
    Serial.write("\015");
    Serial.write("\012");
    while (true);
    This will send the three carriage returns and line feeds to my terminal program. Assuming that since the one Teensy could send the desired data to my terminal program via the micro usb port, It could send it to the teensy running the modem program via it's Micro usb port. This doesn't work, and I don't know if its a formatting/protocol issue(not emulating Putty's serial protocol), or if its just no possible to communicate via micro usb ports. Thanks
    1,574
    It probably won't make a difference but this
    Serial.write(0x0B);
    should be
    Serial.write(0x0D);
    Pete
    Jul 2020
    918
    0x0B is cntrl-K, aka vertical tab, which is likely to confuse most software I reckon!
    Mar 2021
    6
    Thanks Pete, but I tried those also.
    1,574
    I tested usb host serial on a T4.1 connected to a T3.6.
    First, load this receiving program into the T3.6.
    // Works on a T3.6 which receives CR/LF from the
    // USB host port on a T4.1
    // The LED blinks to indicate reception of
    // the two characters
    void setup(void)
      while(!Serial && (millis() < 5000));
      pinMode(LED_BUILTIN,OUTPUT);
    void loop(void)
      if(Serial.available() >= 1) {
        char c = Serial.read();
        if(c == '\n') {
          digitalWrite(LED_BUILTIN,1);
        if(c == '\r') {
          digitalWrite(LED_BUILTIN,0);
    Then connect the T3.6 to the T4.1 host and load this sending code into the T4.1
    // This works on a T4.1 sending CR/LF to a T3.6
    // via the USB host port on the T4.1
    // The LED blinks to indicate transmisison of
    #include <USBHost_t36.h>
    USBHost myusb;
    USBSerial userial(myusb);
    void setup(void)
      delay(10000);
      myusb.begin();
      pinMode(LED_BUILTIN, OUTPUT);
    void loop(void)
      myusb.Task();
      userial.write('\r');
      delay(200);
      userial.write('\n');
    The T4.1 flashes its LED when CR/LF is sent and the T3.6 should flash its LED when it receives CR/LF.
    Pete
    Mar 2021
    6
    Thanks Pete, I’ll give this a try.
