Hi all! Could use some help here. I would like to read the serial data coming off a teensy 4.0. Issue is that the teensy is powered via a power source that is different than the device being used for the serial monitor tools. I have tried using a usb cable that I have cut the power and ground wire but I can't seem to get any serial monitor data off it. Any other ideas I am all ears. Thank you for your time!
