Results 1 to 4 of 4
Thread: Teensy 3.3v SPI to 5v digital pot - write only. Do I need to worry about voltage?
    Mar 2021
    5
    I'm a new electronics hobbyist learning the basics. I'm controlling a 5v MCP42100 digital potentiometer from a Teensy 4.1 via SPI.
    My Teensy 4.1 is 3.3v and not 5v tolerant. I have to run the MCP42100 at 5v.
    What do I need to worry about if the SPI connection is write-only, using just CS, MOSI and SCK?
    In what cases is not being 5v tolerant a problem?
    5v connected to a pin in input mode is the main example I read about.
    What about 5v connected to an output pin set low?
    anything else?
    Thank you for any insight you can give me.
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    533
    Hi Andy,
    Only in case a peripheral wants to drive a signal higher than 3V3 to the Teensy.
    For your application, CS, MOSI and SCK are all outputted by the Teensy at 3V3 max so no problem in that respect.
    You need to worry about the MCP42100 not being able to correctly recognize a HIGH signal from the Teensy, since the minimum VIH of the MCP42100 is 0.7*VDD [=3.5V]:
    Probably 3V3 from the Teensy will be recognized as a HIGH by the MCP42100, but it's not guaranteed. So it's strongly recommended to use a level-shifter in your application to avoid potential problems.
    Hope this helps.
    Regards,
    Paul
    Mar 2021
    5
    Hi Andy,
    Hi Paul, thank you for this info, it's very helpful.
    I have a couple more questions about the 5v intolerance and ground. I attached a drawing to illustrate.
    The Device has buttons. Normally they are closed by connecting a line to ground. I am doing it on the Teensy by connecting the line to an output pin. Setting the output low grounds the line and "presses the button". Putting it high causes the button to be released. Is this OK as far as 5v tolerance goes? Would the question be, does the 5v Device recognize 3v3 as "not grounded"?
    As for ground - is it all the same if it is in the same circuit? For instance, if device 2 had another ground pin, would that be the same as the first device's ground, even though device 1 is 5v and Device 2 is 3v3? I'm talking about low current signaling, not for running a high current device.
    Apr 2015
    Netherlands
    533
    This strongly suggests that the button input pins on the 5V Device are pulled up to 5V and that an external button [or a Teensy pin in your case] pulls that line low. Problem is that this 5V pullup voltage will kill your Teensy.
    Best way to check whether the button input pins on the 5V Device are indeed pulled up to 5V, is to separately power the 5V Device and check the voltage on the open button pin with a DVM [with everything, including Teensy, disconnected].
    Can you share more info on the circuitry of the 5V Device?
    Yes, in your application it is the same.
    Regards,
    Paul
