Good day,
I had a very long post written but I'm starting fresh because this just doesn't need to be complicated.
A teensy, running compiled code on a freshly installed Windows 10 PC with very limited permissions, that prints ascii strings to the serial port every 20ms, should NOT be causing antivirus to become angry, right? The Teensy hardware itself and the USB port connection should not be causing AV to block access to the serial port, right?
I wrote the code on an engineering PC with Arduino+Teensyduino and uploaded to the device. That worked fine. Now I'm just trying to 'run' the device on another W10 PC that does not have Arduino IDE or Teensyduino installed so it can show the value of a quadrature encoded measurement device. I can add code and detail if needed but I thought this could be answered without as it's more hardware/Windows related.
Thanks in advance!
Thanks in advance!
