Results 1 to 2 of 2
Thread: OTA Flasher4
    OTA Flasher4
    Hey.
    I am trying to make an IoT project where I need to update the firmware over ethernet on Teensy 4.1.
    I did a lot of research on the forum and did read about the program called Flasher4.
    I just have a hard time trying it out since the FAQ is a little bit hard to understand.
    I tried to run the commands as mentioned in the FAQ but nothing happens.
    How can I set it up so it works probably?
    EDIT1:
    I did get it to work! I tried a little more with the test program and i figured out.
    My next question would be how can i set flasher4 to update the firmware over ethernet?
    Jun 2017
    249
    Can you describe your project and how you got it to work?I tried searching for 'Flasher4' and 'OTA', but got no relevant hits.
    TIA,
    Frank
