Results 1 to 5 of 5
Thread: Visualteensy not includes ADC and ADC_util libs
    Mar 2021
    19
    Hello forum, I am newby using Arduino and Teensy boards, I installed Arduino 1.8.13
    (at I installed all at d:\arduino)
    Also Teensyduino: 1.53 installer, included all libraries (ADC also)
    Then using VisualTeensy v0.9.9.2 to create code, but ADC libs not appears, then it opened VScode
    But in my first program, VScode not find ADC.h and ADC_util.h
    I do not found any ADC in d:\arduino\libraries
    HTML Code:
    #include "Arduino.h"
    #include "ADC.h"
    #include "ADC_util.h"
    ADC *adc=new ADC();
      pinMode(LED_BUILTIN,OUTPUT);
      digitalWriteFast(LED_BUILTIN,!digitalReadFast(LED_BUILTIN));
    1,447
    Looks like you didn't tell vsTeensy which libraries you need. Here https://www.youtube.com/watch?v=8oTSou1I3IM a video showing how that works.
    Mar 2021
    19
    I see, I found ADC, but ADC_util is not needed, I removed it and worked fine. I think is not needed the PlatformIO to be installed in the VScode
    1,447
    Yes, ADC_util is part of ADC. PlatformIO is a completely different tool also working with vsCode as editor. You do not need it for VisualTeensy.
    Mar 2021
    19
    Thank you Luni,
    I found the problem. I installed in other computer and appears again. I have seen in the c_cpp_properties.json file it is not found the Included path "lib/ADC/**":
    I see also that the lib\ADC is not in the tree, but it appears at the other computer
    At least, I found it was generated here:
    C:\Users\user_name\source\newProject
    So the problem is solved by opening Visualteensy as administrator
