#include <SerialFlash.h>
AudioSynthWaveform Osc1a; //xy=55,52.11111068725586
AudioSynthWaveform Osc1b; //xy=55,99.11111450195312
AudioSynthWaveform Osc2a; //xy=56,175
AudioSynthWaveform Osc2b; //xy=57,214
AudioFilterBiquad Osc1bBPFilter; //xy=192,100
AudioFilterBiquad Osc1aBPFilter; //xy=194,52
AudioFilterBiquad Osc2aBPFilter; //xy=197,175
AudioFilterBiquad Osc2bBPFilter; //xy=197,218
AudioEffectEnvelope Osc1aAttack; //xy=349,64
AudioEffectEnvelope Osc1bAttack; //xy=349,100
AudioEffectEnvelope Osc2bAttack; //xy=352,221
AudioEffectEnvelope Osc2aAttack; //xy=354,177
AudioMixer4 Osc1Mix; //xy=488,99
AudioMixer4 Osc2Mix; //xy=491,201
AudioMixer4 MasterL; //xy=741.111083984375,70
AudioMixer4 MasterR; //xy=740.888916015625,135.88888549804688
AudioOutputI2S i2s1; //xy=866,104
AudioConnection patchCord1(Osc1a, Osc1aBPFilter);
AudioConnection patchCord2(Osc1b, Osc1bBPFilter);
AudioConnection patchCord3(Osc2a, Osc2aBPFilter);
AudioConnection patchCord4(Osc2b, Osc2bBPFilter);
AudioConnection patchCord5(Osc1bBPFilter, Osc1bAttack);
AudioConnection patchCord6(Osc1aBPFilter, Osc1aAttack);
AudioConnection patchCord7(Osc2aBPFilter, Osc2aAttack);
AudioConnection patchCord8(Osc2bBPFilter, Osc2bAttack);
AudioConnection patchCord9(Osc1aAttack, 0, Osc1Mix, 0);
AudioConnection patchCord10(Osc1bAttack, 0, Osc1Mix, 1);
AudioConnection patchCord11(Osc2bAttack, 0, Osc2Mix, 1);
AudioConnection patchCord12(Osc2aAttack, 0, Osc2Mix, 0);
AudioConnection patchCord13(Osc1Mix, 0, MasterL, 0);
AudioConnection patchCord14(Osc1Mix, 0, MasterR, 0);
AudioConnection patchCord15(Osc2Mix, 0, MasterL, 1);
AudioConnection patchCord16(Osc2Mix, 0, MasterR, 1);
AudioConnection patchCord17(MasterL, 0, i2s1, 0);
AudioConnection patchCord18(MasterR, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=699.2222290039062,504.4444580078125
#include <MIDI.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
int attackVal;
int decayVal;
int sustainVal;
int releaseVal;
int resoVal;
int cutoffVal;
int osc2FreqVal;
int osc2LevelVal;
int osc3FreqVal;
int osc3LevelVal;
int osc1Shape1Val;
int osc1Shape2Val;
int osc2Shape1Val;
int osc2Shape2Val;
int osc3Shape1Val;
int osc3Shape2Val;
int osc3Octave1Val;
int osc3Octave2Val;
int lfoRateVal;
int lfoDepthVal;
int lfoShape1Val;
int lfoShape2Val;
int lfoDest1Val;
int lfoDest2Val;
int lfoDest3Val;
int volumeVal;
int delayLengthVal;
int delayMixVal;
int reverbMixVal;
//Pin assignments
int attackPin = 21;
int decayPin = 20;
int sustainPin = 17;
int releasePin = 16;
int resoPin = 31;
int cutoffPin = 32;
int osc1ShapePin1 = 1;
int osc1ShapePin2 = 2;
int osc2ShapePin1 = 27;
int osc2ShapePin2 = 28;
int osc3ShapePin1 = 8;
int osc3ShapePin2 = 5;
int osc2FreqPin = A14;
int osc2LevelPin = A18;
int osc3FreqPin = A20;
int osc3LevelPin = A17;
int osc3OctavePin1 = 30;
int osc3OctavePin2 = 29;
int lfoRatePin = A15;
int lfoDepthPin = A19;
int lfoShapePin1 = 3;
int lfoShapePin2 = 4;
int lfoDestPin1 = 25;
int lfoDestPin2 = 24;
int lfoDestPin3 = 26;
int volumePin = A1;
int delayLengthPin = A22;
int delayMixPin = A16;
int reverbMixPin = A21;
int Osc1aTurn = 0;
int Osc1bTurn = 0;
int Osc2aTurn = 0;
int Osc2bTurn = 0;
int Osc1Playing = 0;
int Osc2Playing = 0;
int notePlaying = 0;
float Osc1aVolume = .5;
float Osc1bVolume = .5;
float Osc2Volume = .50;
float Osc1aPitch = 0.220;
float Osc1bPitch = 0.440;
float Osc2aPitch = 0.220;
float Osc2bPitch = 0.440;
int Osc1current_waveform = WAVEFORM_SINE;
int Osc2current_waveform = WAVEFORM_SINE;
int Osc3current_waveform = WAVEFORM_SINE;
pinMode (osc1ShapePin1, INPUT_PULLUP);
pinMode (osc1ShapePin2, INPUT_PULLUP);
pinMode (osc2ShapePin1, INPUT_PULLUP);
pinMode (osc2ShapePin2, INPUT_PULLUP);
pinMode (osc3ShapePin1, INPUT_PULLUP);
pinMode (osc3ShapePin2, INPUT_PULLUP);
pinMode (osc3OctavePin1, INPUT_PULLUP);
pinMode (osc3OctavePin2, INPUT_PULLUP);
pinMode (lfoShapePin1, INPUT_PULLUP);
pinMode (lfoShapePin2, INPUT_PULLUP);
pinMode (lfoDestPin1, INPUT_PULLUP);
pinMode (lfoDestPin2, INPUT_PULLUP);
pinMode (lfoDestPin3, INPUT_PULLUP);
AudioMemory(120);
sgtl5000_1.enable();
sgtl5000_1.volume(0.8);
MIDI.begin(MIDI_CHANNEL_OMNI);
MIDI.setHandleNoteOn(OnNoteOn);
MIDI.setHandleNoteOff(OnNoteOff);
Osc1Mix.gain(0, 0.7);
Osc1Mix.gain(1, 0.7);
Osc2Mix.gain(0, 0.7);
Osc2Mix.gain(1, 0.7);
MasterL.gain(0, 0.7);
MasterL.gain(1, 0.7);
MasterR.gain(0, 0.7);
MasterR.gain(1, 0.7);
Osc1aAttack.release(25);
Osc1bAttack.release(25);
Osc2aAttack.release(25);
Osc2bAttack.release(25);
Osc1aAttack.releaseNoteOn(15);
Osc1bAttack.releaseNoteOn(15);
Osc2aAttack.releaseNoteOn(15);
Osc2bAttack.releaseNoteOn(15);
Osc1aBPFilter.setBandpass(0, Osc1aPitch, 0.6);
Osc1bBPFilter.setBandpass(0, Osc1bPitch, 0.6);
Osc2aBPFilter.setBandpass(0, Osc2aPitch, 0.6);
Osc2bBPFilter.setBandpass(0, Osc2bPitch, 0.6);
getReadings();
MIDI.read();
Osc1a.begin(Osc1aVolume, Osc1aPitch, Osc1current_waveform);
Osc1b.begin(Osc1bVolume, Osc1bPitch, Osc1current_waveform);
Osc2a.begin((Osc2Volume * Osc1aVolume), Osc2aPitch, Osc2current_waveform);
Osc2b.begin((Osc2Volume * Osc1bVolume), Osc2bPitch, Osc2current_waveform);
void OnNoteOn(byte channel, byte note, byte velocity)
Serial.println("Note!");
float hertz = (pow (2.0, ((float)(note-69)/12.0)))*440;
Serial.print("Note: ");
Serial.println(note);
Serial.print("Velocity: ");
Serial.println(velocity);
Serial.print("");
Serial.println("");
if ((Osc1aTurn == 1) && (Osc1Playing == 0)){
Osc1aPitch = hertz;
Osc1aVolume = ((float)velocity/150.00);
Osc1aBPFilter.setBandpass(0, Osc1aPitch, 0.1);
if ((osc1Shape1Val == 0) && (osc1Shape2Val == 1)){
Osc1current_waveform = WAVEFORM_SQUARE;
Serial.println("osc1 square");
Serial.println(digitalRead(osc1ShapePin1));
Serial.println(digitalRead(osc1ShapePin2));
else if (osc1Shape2Val == 0){
Osc1current_waveform = WAVEFORM_SAWTOOTH;
Serial.println("osc1 saw");
else if ((osc1Shape1Val == 1) && (osc1Shape2Val == 1)){
Serial.println("osc1 sine");
Osc1aAttack.noteOn();
Serial.println("Osc1a On");
Serial.print("Osc1a Volume: ");
Serial.println(Osc1aVolume);
Serial.print("Osc1a Frequency: ");
Serial.println(Osc1aPitch);
Osc1Playing = 1;
notePlaying = note;
Osc1aTurn = 0;
else if ((Osc1Playing == 0) && (Osc1aTurn == 0)){
Osc1bPitch = hertz;
Osc1bVolume = ((float)velocity/150.00);
Osc1bBPFilter.setBandpass(0, Osc1bPitch, 0.1);
Osc1bAttack.noteOn();
Serial.println("Osc1b On");
Serial.print("Osc1b Volume: ");
Serial.println(Osc1bVolume);
Serial.print("Osc1b Frequency: ");
Serial.println(Osc1bPitch);
Osc1Playing = 1;
notePlaying = note;
Osc1aTurn = 1;
if ((Osc2aTurn == 1) && (Osc2Playing == 0)){
Osc2aPitch = hertz;
Osc2Volume = ((float)velocity/150.00);
Osc2aBPFilter.setBandpass(0, Osc2aPitch, 0.1);
if (osc2Shape1Val == 0){
Osc2current_waveform = WAVEFORM_SQUARE;
Serial.println("osc2 square");
else if (osc2Shape2Val == 0){
Osc2current_waveform = WAVEFORM_SAWTOOTH;
Serial.println("osc2 saw");
else {
Serial.println("osc2 sine");
Osc2aAttack.noteOn();
Serial.println("Osc2a On");
Serial.print("Osc2a Volume: ");
Serial.println(Osc2Volume);
Serial.print("Osc2a Frequency: ");
Serial.println(Osc2aPitch);
Osc2Playing = 1;
// notePlaying = note;
Osc2aTurn = 0;
else if ((Osc2Playing == 0) && (Osc2aTurn == 0)){
Osc2bPitch = hertz;
Osc2bBPFilter.setBandpass(0, Osc2bPitch, 0.1);
else {
Osc2bAttack.noteOn();
Serial.println("Osc2b On");
Serial.print("Osc2b Volume: ");
Serial.print("Osc2b Frequency: ");
Serial.println(Osc2bPitch);
Osc2Playing = 1;
//notePlaying = note;
Osc2aTurn = 1;
void OnNoteOff(byte channel, byte note, byte velocity)
if (note == notePlaying){
Osc1aAttack.noteOff();
Osc1bAttack.noteOff();
Osc2aAttack.noteOff();
Osc2bAttack.noteOff();
Osc1Playing = 0;
Osc2Playing = 0;
void getReadings(){
attackVal = analogRead(attackPin);
decayVal = analogRead(decayPin);
sustainVal = analogRead(sustainPin);
releaseVal = analogRead(releasePin);
resoVal = analogRead(resoPin);
cutoffVal = analogRead(cutoffPin);
osc1Shape1Val = digitalRead(osc1ShapePin1);
osc1Shape2Val = digitalRead(osc1ShapePin2);
osc2Shape1Val = digitalRead(osc2ShapePin1);
osc2Shape2Val = digitalRead(osc2ShapePin2);
osc3Shape1Val = digitalRead(osc3ShapePin1);
osc3Shape2Val = digitalRead(osc3ShapePin2);
osc3Octave1Val = digitalRead(osc3OctavePin1);
osc3Octave2Val = digitalRead(osc3OctavePin2);
Osc2Volume = (analogRead(osc2LevelPin)/1027.00);
osc3FreqVal = analogRead(osc3FreqPin);
osc3LevelVal = analogRead(osc3LevelPin);
lfoRateVal = analogRead(lfoRatePin);
lfoDepthVal = analogRead(lfoDepthPin);
lfoShape1Val = digitalRead(lfoShapePin1);
lfoShape2Val = digitalRead(lfoShapePin2);
lfoDest1Val = digitalRead(lfoDestPin1);
lfoDest2Val = digitalRead(lfoDestPin2);
lfoDest3Val = digitalRead(lfoDestPin3);
volumeVal = analogRead(volumePin);
delayLengthVal = analogRead(delayLengthPin);
delayMixVal = analogRead(delayMixPin);
reverbMixVal = analogRead(reverbMixPin);
