Hi, im working on a project with Teensy 3.6 and im using Micro Sound Recorder (Walter Zimmer one). I've modified part of the code based on snooze library because MSR is programmed to wake up from deep sleep with RTC interruption. But it generates system reset and I don't want this.
After a k66 datasheet lecture I've concluded that I should use LLS over VLLS for the normal recovery method, but im not sure.
I've modified the MSR to use LLS instead of VLLS but when it puts to deep sleep, never wakes up.
void rtcSetup(void)
SIM_SCGC6 |= SIM_SCGC6_RTC;// enable RTC clock
RTC_CR |= RTC_CR_OSCE;// enable RTC
void rtcSetAlarm(uint32_t nsec)
{ // set alarm nsec seconds in the future
RTC_TAR = RTC_TSR + nsec;
RTC_IER |= RTC_IER_TAIE_MASK;
/********************LLWU**********************************/
#define LLWU_ME_WUME5_MASK 0x20u
#define LLWU_F3_MWUF5_MASK 0x20u
#define LLWU_MF5_MWUF5_MASK 0x20u
static void llwuISR(void)
#if defined(HAS_KINETIS_LLWU_32CH)
LLWU_MF5 |= LLWU_MF5_MWUF5_MASK; // clear source in LLWU Flag register
#else
LLWU_F3 |= LLWU_F3_MWUF5_MASK; // clear source in LLWU Flag register
RTC_IER = 0;// clear RTC interrupts
static void llwuSetup(void)
attachInterruptVector( IRQ_LLWU, llwuISR );
NVIC_SET_PRIORITY( IRQ_LLWU, 2*16 );
NVIC_CLEAR_PENDING( IRQ_LLWU );
NVIC_ENABLE_IRQ( IRQ_LLWU );
LLWU_PE1 = 0;
LLWU_PE2 = 0;
LLWU_PE3 = 0;
LLWU_PE4 = 0;
LLWU_PE5 = 0;
LLWU_PE6 = 0;
LLWU_PE7 = 0;
LLWU_PE8 = 0;
LLWU_ME = LLWU_ME_WUME5_MASK; //rtc alarm
SIM_SOPT1CFG |= SIM_SOPT1CFG_USSWE;
SIM_SOPT1 |= SIM_SOPT1_USBSSTBY;
PORTA_PCR0 = PORT_PCR_MUX(0);
PORTA_PCR1 = PORT_PCR_MUX(0);
PORTA_PCR2 = PORT_PCR_MUX(0);
PORTA_PCR3 = PORT_PCR_MUX(0);
PORTB_PCR2 = PORT_PCR_MUX(0);
PORTB_PCR3 = PORT_PCR_MUX(0);
/********************* go to deep sleep *********************/
#define SMC_PMPROT_AVLLS_MASK 0x2u
#define SMC_PMCTRL_STOPM_MASK 0x7u
#define SCB_SCR_SLEEPDEEP_MASK 0x4u
#define SMC_PMPROT_ALLS_MASK 0x4u
// see SMC section (e.g. p 339 of K66)
#define VLLS3 0x3 // RAM retained I/O states held
#define VLLS2 0x2 // RAM partially retained
#define VLLS1 0x1 // I/O states held
#define VLLS0 0x0 // all stop
#define VLLS_MODE VLLS0
static void gotoSleep(void)
// /* Make sure clock monitor is off so we don't get spurious reset */
MCG_C6 &= ~MCG_C6_CME0;
// if K66 is running in highspeed mode (>120 MHz) reduce speed
// is defined in kinetis.h and mk20dx128c
#if defined(HAS_KINETIS_HSRUN) && (F_CPU > 120000000)
kinetis_hsrun_disable( );
/* Write to PMPROT to allow all possible power modes */
//SMC_PMPROT = SMC_PMPROT_AVLLS_MASK;
//SMC_PMPROT = SMC_PMPROT_ALLS_MASK;
/* Set the STOPM field to 0b100 for VLLSx mode */
SMC_PMCTRL &= ~SMC_PMCTRL_STOPM_MASK;
//SMC_PMCTRL |= SMC_PMCTRL_STOPM(0x4); // VLLSx
SMC_PMCTRL |= SMC_PMCTRL_STOPM(0x3); // LLSx
//SMC_VLLSCTRL = SMC_VLLSCTRL_VLLSM(VLLS_MODE);
/*wait for write to complete to SMC before stopping core */
(void) SMC_PMCTRL;
SYST_CSR &= ~SYST_CSR_TICKINT; // disable systick timer interrupt
SCB_SCR |= SCB_SCR_SLEEPDEEP_MASK; // Set the SLEEPDEEP bit to enable deep sleep mode (STOP)
asm volatile( "wfi" ); // WFI instruction will start entry into STOP mode
// will never return, but wake-up results in call to ResetHandler() in mk20dx128.c
// Clear the SLEEPDEEP bit
//SCB_SCR = 0;
// renable systick timer interrupt
//SYST_CSR |= SYST_CSR_TICKINT;
void setWakeupCallandSleep(uint32_t nsec)
{ // set alarm to nsec secods in future and go to hibernate
rtcSetup();
llwuSetup();
rtcSetAlarm(nsec);
yield();
#if DO_DEBUG>0
Serial.println(nsec);
pinMode(13,OUTPUT); digitalWriteFast(13,HIGH); delay(1000); digitalWriteFast(13,LOW);
gotoSleep();
