Results 1 to 4 of 4
Thread: MIDI NoteOn remains pressed
    Apr 2020
    France
    22
    Hi, I'm making good progress on my HANPAN project but I'm stuck on this. When I change scale it works:
    NoteOn ,ch: 1 , Note: 57, Velocity: 90
    NoteOff ,ch: 1 , Note: 57, Velocity: 0
    NoteOn ,ch: 1 , Note: 55, Velocity: 70
    NoteOff ,ch: 1 , Note: 55, Velocity: 0
    the noteOff is well stored and then it's released. Perfect !
    But when I change octave I have this :
    NoteOn ,ch: 1 , Note: 69, Velocity: 45
    NoteOn ,ch: 1 , Note: 81, Velocity: 45
    NoteOn remains pressed and she plays continuously, NoteOff does not update
    Thanks for your help
    ///////PAD1/////////////////
    void peakDetect1(int voltage) {
      // "static" variables keep their numbers between each run of this function
      static int state;  // 0=idle, 1=looking for peak, 2=ignore aftershocks
      static int peak;   // remember the highest reading
      static elapsedMillis msec; // timer to end states 1 and 2
      switch (state) {
       case 0:
          if (voltage > thresholdMin) {
            Serial.print("begin peak track ");
            Serial.println(voltage);
            peak = voltage;
            msec = 0;
            state = 1;
          return;
        // Peak Tracking state: capture largest reading
        case 1:
          if (voltage > peak) {
            peak = voltage;
          if (msec >= peakTrackMillis) {
            Serial.print("peak = ");
            Serial.println(peak);
            int velocity = map(peak, thresholdMin, 1023, 1, 127);
            if(octave_index == 1)
           usbMIDI.sendNoteOn(scale[scale_index][0]+12, velocity, channel);
           else if(octave_index == -1)
           usbMIDI.sendNoteOn(scale[scale_index][0]-12, velocity, channel);
           else if(octave_index == 2)
           usbMIDI.sendNoteOn(scale[scale_index][0]+24, velocity, channel);
           else if(octave_index == -2)
           usbMIDI.sendNoteOn(scale[scale_index][0]-24, velocity, channel);
           usbMIDI.sendNoteOn(scale[scale_index][0], velocity, channel);
           msec = 0;
           state = 2;
           leds.setColorRGB(0, 255, 0, 0); // Led Color ON RED
           etat1 = 1;
           startTime1 = millis();
          return;
        // Ignore Aftershock state: wait for things to be quiet again.
        default:
            msec = 0; // keep resetting timer if above threshold
          } else if (msec > aftershockMillis) {
            usbMIDI.sendNoteOff(scale[scale_index][0], 0, channel);
            state = 0; // go back to idle when
    Apr 2020
    France
    22
    I guess my problem is from here ?
    void buttonCheck()
      ////// Change Octave //////
      octaveUp.update();
      octaveDown.update();
      //if Button 3 is pressed, increment octave
      if (octaveUp.fallingEdge())
        octave_index++;
        if(octave_index > 2)
        octave_index = 2;
      //if Button 4 is pressed, decrement octave
      if (octaveDown.fallingEdge())
        octave_index--;
        if(octave_index < -2)
        octave_index = -2;
      ////// Chage Scale //////
      button0.update();
      button1.update();
      //if button 0 is pressed, increment the scale being used
      if (button0.fallingEdge())
        scale_index++;
        //check for overflow
        if(scale_index > numOfScales)  //numOfScales variable found in the scales.h file
        scale_index = 0;
      //if button 1 is pressed, decrement the scale being used
      if (button1.fallingEdge())
        scale_index--;
        //check for negative numbers
        if(scale_index < 0)
        scale_index = numOfScales;  //numOfScales variable found in the scales.h file
    Jul 2020
    985
    Your noteOff code doesn't take account of octave_index - it needs to.
    If you want noteOn/noteOff to work across a change of octave you'll need to use a datastructure to keep
    a record of the notes currently in-flight so you can generate the right noteOff's.
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,402
    +1
    It's a bit too much guesswork about your scale and octave system with code fragments (the rule is to post complete code) but I would expect it better to do the octave shift on a variable that is then used in a single note-on and the same variable in the note-off.
    If the octave can change while a note is active you may have problems with stuck notes and you may need to resort to tracking active notes as Mark suggests.
