EPROM Emulator
Hmm.. the link works for me when I click on it...
Here is the full URL: github.com/MicroCoreLabs/Projects/tree/master/EPROM_Emulator
won't the data be lost when the 4.1 resets? shouldn't persistance be part of eeprom emulation as well? perhaps have the data stored in intervals to flash or SD
Ah.. It probably wasn't clear, but I am storing the values in the the array declaration in the code. I did not want to include copyrighted BIOS code when I uploaded it to GitHub, so I cleared the values I was using...
So, it would be something like this:
int8_t memory_array[65536] = { 0x11, 0x22, 0x33.... }; // Populate with up to 64K values
The source is small so I'll enclose it below:
//  File Name   :  ROM_Emulator
//  Used on     :
//  Author      :  Ted Fried, MicroCore Labs
//  Creation    :  3/20/2021
//   Description:
//  27Cxxx EPROM Emulator. When Teensy 4.0 run at 816Mhz the address to
// data access time is less than 200ns.
// Modification History:
// Revision 1 3/20/2021
// Initial revision
// Copyright (c) 2021 Ted Fried
// Permission is hereby granted, free of charge, to any person obtaining a copy
// of this software and associated documentation files (the "Software"), to deal
// in the Software without restriction, including without limitation the rights
// to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
// copies of the Software, and to permit persons to whom the Software is
// furnished to do so, subject to the following conditions:
// The above copyright notice and this permission notice shall be included in all
// copies or substantial portions of the Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
// IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
// FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
// AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
// LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
// OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
// SOFTWARE.
#include <stdint.h>
// Teensy 4.0 pin assignments
#define PIN_DATA0          10
#define PIN_DATA1          11
#define PIN_DATA2          12
#define PIN_DATA3          13
#define PIN_DATA4          14
#define PIN_DATA5          15
#define PIN_DATA6          16
#define PIN_DATA7          17
#define PIN_ADDR0          18
#define PIN_ADDR1          19
#define PIN_ADDR2          20
#define PIN_ADDR3          9
#define PIN_ADDR4          7
#define PIN_ADDR5          5
#define PIN_ADDR6          22
#define PIN_ADDR7          4
#define PIN_ADDR8          23
#define PIN_ADDR9          21
#define PIN_ADDR10         8
#define PIN_ADDR11         6
#define PIN_ADDR12         2
#define PIN_ADDR13         3
#define PIN_ADDR14         1
#define PIN_ADDR15         0
uint8_t   memory_array[65536];
// Setup Teensy 4.0 IO's
  pinMode(PIN_DATA0,   OUTPUT);
  pinMode(PIN_DATA1,   OUTPUT);
  pinMode(PIN_DATA2,   OUTPUT);
  pinMode(PIN_DATA3,   OUTPUT);
  pinMode(PIN_DATA4,   OUTPUT);
  pinMode(PIN_DATA5,   OUTPUT);
  pinMode(PIN_DATA6,   OUTPUT);
  pinMode(PIN_DATA7,   OUTPUT);
  pinMode(PIN_ADDR0,   INPUT);
  pinMode(PIN_ADDR1,   INPUT);
  pinMode(PIN_ADDR2,   INPUT);
  pinMode(PIN_ADDR3,   INPUT);
  pinMode(PIN_ADDR4,   INPUT);
  pinMode(PIN_ADDR5,   INPUT);
  pinMode(PIN_ADDR6,   INPUT);
  pinMode(PIN_ADDR7,   INPUT);
  pinMode(PIN_ADDR8,   INPUT);
  pinMode(PIN_ADDR9,   INPUT);
  pinMode(PIN_ADDR10,  INPUT);
  pinMode(PIN_ADDR11,  INPUT);
  pinMode(PIN_ADDR12,  INPUT);
  pinMode(PIN_ADDR13,  INPUT);
  pinMode(PIN_ADDR14,  INPUT);
  pinMode(PIN_ADDR15,  INPUT);
// Main loop
  register uint8_t   data_out;
  register uint16_t  address;
  register uint32_t  GPIO6_data=0;
  register uint32_t  GPIO7_data=0;
  register uint32_t  GPIO9_data=0;
  GPIO6_data = GPIO6_DR;
  GPIO7_data = GPIO7_DR;
  GPIO9_data = GPIO9_DR;
  address   =   ( (GPIO6_data&0x00020000) >> 17 ) |   // A0  Teensy 4.0 PIN_18  GPIO6_DR[17]
                ( (GPIO6_data&0x00010000) >> 15 ) |   // A1  Teensy 4.0 PIN_19  GPIO6_DR[16]
                ( (GPIO6_data&0x04000000) >> 24 ) |   // A2  Teensy 4.0 PIN_20  GPIO6_DR[26]
                ( (GPIO7_data&0x00000800) >> 8  ) |   // A3  Teensy 4.0 PIN_9   GPIO7_DR[11]
                ( (GPIO7_data&0x00020000) >> 13 ) |   // A4  Teensy 4.0 PIN_7   GPIO7_DR[17]
                ( (GPIO9_data&0x00000100) >> 3  ) |   // A5  Teensy 4.0 PIN_5   GPIO9_DR[8]
                ( (GPIO6_data&0x01000000) >> 18 ) |   // A6  Teensy 4.0 PIN_22  GPIO6_DR[24]
                ( (GPIO9_data&0x00000040) << 1  ) |   // A7  Teensy 4.0 PIN_4   GPIO9_DR[6]
                ( (GPIO6_data&0x02000000) >> 17 ) |   // A8  Teensy 4.0 PIN_23  GPIO6_DR[25]
                ( (GPIO6_data&0x08000000) >> 18 ) |   // A9  Teensy 4.0 PIN_21  GPIO6_DR[27]
                ( (GPIO7_data&0x00010000) >> 6  ) |   // A10 Teensy 4.0 PIN_8   GPIO7_DR[16]
                ( (GPIO7_data&0x00000400) << 1  ) |   // A11 Teensy 4.0 PIN_6   GPIO7_DR[10]
                ( (GPIO9_data&0x00000010) << 8  ) |   // A12 Teensy 4.0 PIN_2   GPIO9_DR[4]
                ( (GPIO9_data&0x00000020) << 8  ) |   // A13 Teensy 4.0 PIN_3   GPIO9_DR[5]
                ( (GPIO6_data&0x00000004) << 12 ) |   // A14 Teensy 4.0 PIN_1   GPIO6_DR[2]
                ( (GPIO6_data&0x00000008) << 12 ) ;   // A15 Teensy 4.0 PIN_0   GPIO6_DR[3]
  address = (0x7FFF & address);  // PCjr has 32KB ROM
  data_out  = memory_array[address];
  GPIO6_DR  =((data_out & 0x80)<<15) | ((data_out & 0x40)<<17) |              ((data_out & 0x30)<<14) ;       // D[7:4]
  GPIO7_DR  = (data_out & 0x08)      | ((data_out & 0x02)<<1 ) | ((data_out & 0x04)>>1) |  (data_out & 0x01); // D[3:0]
