Help needed with pointers and arrays
M4ngu
Hi there, I'm using this code to save and load files from the microSD card, but instead of repeating this 33 times (one for each variable I need to save) would like to do in a loop, using an array
Save:
  String file = "/VAL.DAT";
  if (SD.exists(file.c_str()))
    SD.remove(file.c_str());
  dataFile = SD.open(file.c_str(), FILE_WRITE);
  dataFile.write((uint8_t *)&val, sizeof(val));
  dataFile.close();
Load:
    dataFile = SD.open(file.c_str(), FILE_READ);
    dataFile.read((uint8_t *)&val, sizeof(val));
so I do an array for the names, to use fileName instead of "/VAL.DAT"
const String fileName[] = { "/VAL.DAT", "/PROB.DAT", "/STEPS.DAT" ...etc };
but no idea about how to do an array with the pointers of the variables I need to save & load,
and no idea how the code should be to use that array,
any advice would be much appreciated, thanks
Use C strings?
const char * fileNames[] = { "/....", "/....", ... };
for (int i = 0 ; i < sizeof(fileNames)/sizeof(char*) ; i++)
  const * fileName = fileNames[i] ;
  if (SD.exists(fileName))
    SD.remove(fileName);
  dataFile = SD.open(fileName, FILE_WRITE);
  dataFile.close();
Thanks but the names part is not the problem, as I explain in the OP (maybe not clear enough)
what I need to figure out is how to make an array of pointers for the variables to be saved and loaded from the memory card,
and how those 2 lines should be modified:
//save:
//load:
@M4ngu:
If I am understanding correctly what you are after, here's a short sketch to demonstrate an approach that I believe matches what you are needing. You will create an array containing the addresses of your variables, & you will access "the value stored at those addresses" inside your loop.
unsigned int test00 = 0;
unsigned int test01 = 1;
unsigned int test02 = 2;
unsigned int test03 = 3;
unsigned int test04 = 4;
unsigned int test05 = 5;
unsigned int test06 = 6;
unsigned int test07 = 7;
unsigned int test08 = 8;
unsigned int test09 = 9;
unsigned int *ary1[] = { &test00, &test01, &test02, &test03, &test04, &test05, &test06, &test07, &test08, &test09, };
   Serial.begin(19200);
   // print out the contents of the array of variables
   for (int i = 0; i < 10; i++)
      Serial.print("entry #");
      Serial.print(i);
      Serial.print(" in the array : ");
      Serial.println(*ary1[i]);
   Serial.println("");
   // modify the variables themselves directly
   test00 *= 2;
   test01 *= 2;
   test02 *= 2;
   test03 *= 2;
   test04 *= 2;
   test05 *= 2;
   test06 *= 2;
   test07 *= 2;
   test08 *= 2;
   test09 *= 2;
   // print out the contents of the array of modified variables
      Serial.print(i);
   Serial.println("");
   // simple example that shaows how the variables are accessed indirectly within the array in order to be modified
      *ary1[i] = *ary1[i] * 2;  // could also be written as "*ary1[i] *= 2;", but written out explicitly here for clarity
      Serial.print(i);
Hope this helps . . .
Mark J Culross
KD5RXT
