choochoo22
I'm basically a neophite although I have at least one project I'm pretty happy with. That project, however, is plagued by write latency issues with the SD card on a Teensy 3.5. I would like to try using sdFat instead of SD to see if that results in any improvement but nothing seems to work.
Actually the Bench example works having made two changes set USE_SDIO to 1 and chipSelect to 254 works:
#define USE_SDIO 1
const uint8_t chipSelect = 254;
Other examples don't work. For instance with the simple ReadWrite example: As-is it fails to initialize the card. If I change "#define SD_CS_PIN SS" to "#define SD_CS_PIN BUILTIN_SDCARD" it is undeclared. If I change it to 254 it runs but fails to initialize the card.
EDIT: Now I'm even more frustrated. After updating to the latest sdFat version 2.0.5 even the edited Bench example mentioned above fails to compile with errors listed below.
Can anyone offer any suggestions on using sdFat with a Teensy 3.5? Examples that work? Or perhaps a reference for the sdFat classes similar to the sd reference? (https://www.arduino.cc/en/reference/SD)
#define USE_SDIO 1
Arduino: 1.8.13 (Windows 10), TD: 1.53, Board: "Teensy 3.5, Serial, 120 MHz, Faster, US English"
Card_Test:39: error: 'SdFatSdioEX' does not name a type
SdFatSdioEX sd;
Card_Test: In function 'void cidDmp()':
Card_Test:63: error: 'sd' was not declared in this scope
if (!sd.card()->readCID(&cid)) {
Card_Test: In function 'void loop()':
Card_Test:117: error: 'sd' was not declared in this scope
if (!sd.begin()) {
Card_Test:127: error: 'sd' was not declared in this scope
cout << F("Type is FAT") << int(sd.vol()->fatType()) << endl;
Multiple libraries were found for "SdFat.h"
Used: C:\Users\Rick\Documents\Arduino\libraries\SdFat
Not used: C:\Users\Rick\Documents\Arduino\libraries\arduino_47876
