Results 1 to 11 of 11
Thread: Teensy 4.1 deep sleep and watchdog
    Mar 2021
    3
    I'm using a Teensy 4.1 with a watchdog timer set.
    WDT_T4<WDT1> wdt;
    I also need to have the Teensy sleep for extended periods so I'm using deepSleep from the Snooze library. The watchdog timer is causing the device to reset when it is put to sleep. Is there a way to disable the watchdog after it has been configured?
    Allan
    Dec 2016
    Montreal, Canada
    3,697
    try setting
    config.lp_suspend = 1;
    (it's already implemented in the library)
    Cheltenham, UK
    186
    Snooze has not been implemented for Teensy 4.1. Also I believe that for Teensy 4.0 wake from deep-sleep is via a Teensy Reset.
    Mar 2021
    3
    Quote Originally Posted by BriComp View Post
    Snooze::deepSleep() seems to be working fine for me. It looks like you must include an instance of SnoozeUSBSerial in the SnoozeBlock but otherwise it appears to work as expected (I'm using the 4_0 version from the hal). I couldn't get hibernate() to work - it seems to hibernate but not wake up - haven't had time to investigate.
    Mar 2021
    3
    That doesn't seem to work. I've tried to make a minimum example, once started I use a serial input to trigger the sleep. With the watchdog removed the sleep works fine. With the watchdog in place the sleep is interrupted and the device resets.
    #include <Watchdog_t4.h>
    #include <Snooze.h>
    WDT_T4<WDT1> wdt;
    SnoozeUSBSerial usb;
    SnoozeAlarm  alarm;
    SnoozeBlock config_teensy40(usb, alarm);
      WDT_timings_t config;
      wdt.begin(config);
      alarm.setRtcTimer(0, 10, 0);// hour, min, sec
      Serial.begin(57600);
      pinMode(LED_BUILTIN, OUTPUT);
      delay(5000);
      Serial.println("Start");
      wdt.feed();
      Serial.println("Start loop..");
      int who = 0;
      // Sleep when serial input received..
      if (Serial.available())
        who = Snooze.deepSleep(config_teensy40);
      // Just so we can see something happening..
      for (int i = 0; i < 4; ++i) {
        delay(200);
        delay(200);
    Dec 2016
    Montreal, Canada
    3,697
    the suspend function enables it on watchdog register but i think the deepsleep has to stop the clock it uses as well. I am not sure what clocks deepsleep turns off, or if the wdt one is still active (aka not suspended)
    Senior Member duff's Avatar
    Las Vegas
    1,027
    Most likely Snooze is turning off the enables for the watchdog clock. Watchdog is not something I took into account when writing the T4 sleep code. I'm sure there are other things that are getting in the way with these two libraries.
    Also the system clocks that get activated in sleep modes are not ones that ever get used in non sleep code, those might not be usable for the watchdog.
    Cheltenham, UK
    186
    Did you have any luck trying to find out why Teensy 4.0 freezes using Snooze and EEPROM.put?
    Dec 2016
    Montreal, Canada
    3,697
    I think the alarm is resetting the T4.0, I am using the timer and it is working correctly with the latest commit to WDT_T4:
    https://github.com/tonton81/WDT_T4
    Teensy 4.0/4.1 is same processor, so it'll work on both.
    With the code below, Teensy sees the millis() counter incrementing on a timer wakeup correctly. Using the alarm wakeup version, in about 40 seconds irregardless of alarm value set, Teensy does a complete reset.
    The watchdog config.timeout is set to 1 second, and does not interfere or cause resets with the 5 second timer wakeup
    #include <Snooze.h>
    WDT_T4<WDT1> wdt;
    SnoozeTimer     timer;
    //SnoozeAlarm  alarm;
    SnoozeBlock config_teensy40(usb, timer);
      config.timeout = 1;
      wdt.begin(config);
      //  alarm.setRtcTimer(0, 10, 0);// hour, min, sec
      timer.setTimer(5);// seconds
      delay(2000);
      wdt.feed();
      Serial.println(millis());
      int who = 0;
      if (Serial.available()) {
        Serial.println(who);
      digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
      delay(200);
    EDIT, I'll come back to this tonight don't bother, I broke something :P
    Dec 2016
    Montreal, Canada
    3,697
    Ok, I had to rush out to work today which is why I said I'll be on this later. I reverted the changes and fixed the library, watchdog is firing at 1second timeout resets if i dont feed it now so thats good, and the 5 second deep sleep does not affect the watchdog, no resets occur and 5 seconds later teensy wakes up to continue printing the millis() counter
    Try the repo again with the sketch above. Let me know
    Dec 2016
    Montreal, Canada
    3,697
    The alarm one is working as well! I set the alarm for 10 seconds:
    #include <Snooze.h>
    WDT_T4<WDT1> wdt;
    SnoozeTimer     timer;
    SnoozeAlarm  alarm;
    //SnoozeBlock config_teensy40(usb, timer);
      config.timeout = 1;
      wdt.begin(config);
      alarm.setRtcTimer(0, 0, 10);// hour, min, sec
      //  delay(2000);
      wdt.feed();
      int who = 0;
      delay(200);
