Results 1 to 2 of 2
Thread: XPT2046_Touchscreen improve sampling accuracy
    Mar 2021
    1
    a few days ago I started to use the XPT2046_Touchscreen lib and it wored out of the box.
    I did some tests and also looked up the datasheet, but I wasn't quite happy with the result. So here I want to provide my changes to improve the measurement at the cost of spending more time on the sampling task.
    What are my changes:
    - doing one dummy sampling bevor x and y sampling to stbilize the system
    - no switching between x ynd y sampling
    - changing the Z evaluation according to the datasheet
    and this could be a part of the lib
    - adding a transformation from touch to display coordinates
    void XPT2046_Touchscreen::update(){
    if (!isrWake) return;
    uint32_t now = millis();
    if (now - msraw < MSEC_THRESHOLD) return;
    int16_t data[6];
    SPI.beginTransaction(SPI_SETTING);
    digitalWrite(csPin, LOW);
    SPI.transfer(0xB1); // Z1
    int16_t z1 = SPI.transfer16(0xC1) >> 3; // Z2
    int16_t z2 = SPI.transfer16(0xd1) >> 3; // X for pressed
    SPI.transfer16(0xd1);
    data[0] = SPI.transfer16(0xd1) >> 3;
    data[1] = SPI.transfer16(0xd1) >> 3; // make 3 x-y measurements
    data[2] = SPI.transfer16(0x91) >> 3;
    SPI.transfer16(0x91);
    data[3] = SPI.transfer16(0x91) >> 3;
    data[4] = SPI.transfer16(0x90) >> 3; // Last Y touch power down
    data[5] = SPI.transfer16(0) >> 3;
    digitalWrite(csPin, HIGH);
    SPI.endTransaction();
    zraw = ((((z2<<2)/z1)-4)*(data[0]>>4))>>7;
    if (zraw > Z_THRESHOLD_INT) {
    if (255 != tirqPin){
    isrWake = false;
    return;
    }else{
    msraw = now; // good read completed, set wait
    //Serial.printf(" z1=%d,z2=%d ", z1, z2);
    xraw = besttwoavg( data[0], data[1], data[2] );
    yraw = besttwoavg( data[3], data[4], data[5] );
    These parameters depent on your hardware, measure three raw point on the screen
    i.e (Xmin,Ymin), (Xmin,Ymax), (Xmax,Yhalf)
    Xdmin= A * Xtmin + B * Ytmin + C
    Xdmin= A * Xtmin + B * Ytmax + C
    Xdmax= A * Xtmax + B * Ythalf + C
    Ydmin= D * Ytmin + E * Xtmin + F
    Ydmax= D * Ytmax + E * Xtmin + F
    Ydhalf= D * Ythalf + E * Xtmax + F
    insert the touch (Xt) and the display (Xd) points, solve the 6 equations and you get the parameters for A-F
    #define PARAM_A 0.205667
    #define PARAM_B 0.000756
    #define PARAM_C -18.659607
    #define PARAM_D 0.12984
    #define PARAM_E -0.001794
    #define PARAM_F -37.410868
    i.e.:
    disp_x_size = 799;
    disp_y_size = 479;
    update();
    int16_t x = (long)((long)(PARAM_A*256*256) * (long)xraw + (long)(PARAM_B*256*256) *(long)yraw + (long)(PARAM_C*256*256))>>16;
    if (x < 0) x=0;
    else if (x>disp_x_size) x=disp_x_size;
    int16_t y = (long)((long)(PARAM_D*256*256) * (long)yraw + (long)(PARAM_E*256*256) *(long)xraw + (long)(PARAM_F*256*256))>>16;
    if (y < 0) y=0;
    else if (y>disp_y_size) y=disp_y_size;
    it is just a proposal, if you like it - use it!
    Andre
    Jul 2020
    905
    A few weeks/months ago there was a thread about someone having trouble with this library, you might
    want to hunt it down and see if you've addressed the issues from that thread, I suspect so.
