Results 1 to 5 of 5
Thread: Looking for Teensy USB Joystick Libraries
    Mar 2021
    1
    I'm building some sim racing pedals and I'm working in VS Code with a Teensy 4.1. I'd like to import the joystick library used in this example (https://www.pjrc.com/teensy/td_joystick.html) but I'm having trouble finding the library itself. Could somebody please point me in the right direction?
    Thanks a bunch.
    Chris
    9,019
    The USB Joystick code is built into Teensyduino installs. It is enabled when you choose a USB type that includes Joysticks.
    That is it is in the ...\cores\teensy4\joystick.c (and .h)
    But again this code is not brought in unless the build is such that JOYSTICK_INTERFACE is defined as the header file and the like start off with:
    #if defined(JOYSTICK_INTERFACE)
    And these get typically set in usb_desc.h file depending on stuff passed in to the build and choose the USB type of : Keyboard + mouse + joystick
    The build will go through with: -DUSB_HID
    (from boards.txt)
    If you look in usb_desc.h for the section: #elif defined(USB_HID)
    Line 240 in mine you will see it will define JOYSTICK_INTERFACE plus several other things.
    Note other places need this as well, for example the usb_desc.c which will setup the USB descriptor and the like.
    But how this translates to platform IO? Not sure, I don't typically use it.
    Aug 2018
    Brisbane, Australia
    48
    For PlatformIO, all you need to do is define the desired USB Features in a build flag as described in the the documentation.
    https://docs.platformio.org/en/lates...l#usb-features
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    278
    in platform io the usable flags are:
    USB_HID                  | Keyboard + Mouse + Joystick
    USB_SERIAL_HID           | Serial + Keyboard + Mouse + Joystick
    USB_FLIGHTSIM_JOYSTICK   | Flight Sim Controls + Joystick
