Results 1 to 12 of 12
Thread: SPI, DMA, EventResponder?
    In the SPI code https://github.com/PaulStoffregen/SP...r/SPI.cpp#L766 one can find an SPI transfer function that takes an EventResponderRef as one of its argument.
    Is there any documentation about this feature? I found this thread https://forum.pjrc.com/threads/60289...l=1#post234623 where it is said that this is "experimental".
    Does this work with any SPI port on a teensy 3.6 or only on the first one? Does this have something to do with the FIFO capability of the first SPI port?
    Background: I want to drive 40 OLED display with a teensy 3.6. To achieve reasonable update rates, my plan is to hook 20 displays each to a separate SPI port such that I can compute the new display content while the transfer of another happens.
    9,219
    Sorry there is not much documentation on the EventResponder.
    Other than the stuff up on the thread and examples I have put up on different areas.
    It should work on any SPI port on the T3.6, it did the last time I tried it. It was more problematic with T3.5.
    The only caveat with DMA. Many times it appears to work better if what you are DMA into or out of is aligned on a 32 byte boundary. (Although maybe more with T4...)
    Thanks for your reply!!
    I will test it and report here.
    I was looking in more detail into the EventResponder class and its relation to SPI.
    For what I want to achieve, I would simply need an async transfer function and then a blocking "waitForFinished" function.
    With the current EventResponder API this seems unnecessarily complex to implement.
    As far as I can tell, there is already a state variable in the SPI class "_dma_state" which could be exposed in order to check if a transfer is ongoing or is completed.
    Any opinions?
    What about this function waitForEvent here: https://github.com/PaulStoffregen/co...sponder.h#L173
    9,219
    For what it is worth, here is one of the test programs I was using when I did some of the development and testing of SPI using Async...
    #include <EventResponder.h>
    #define CS_PIN 10
    volatile bool event_happened = false;
    EventResponder event;
    static const uint8_t buffer[] = "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ";
    void asyncEventResponder(EventResponderRef event_responder)
      digitalWriteFast(CS_PIN, HIGH);
      event_happened = true;
      //Serial.println("Event happened");
      pinMode(CS_PIN, OUTPUT);
      while (!Serial && millis() < 4000) ;  // wait for Serial port
      SPI.begin();
      Serial.println("SPI Test program");
      Serial1.begin(2000000);
      Serial2.begin(2000000);
      Serial3.begin(2000000);
      extern const uint8_t _serialEvent_default;
      extern const uint8_t _serialEvent1_default;
      extern const uint8_t _serialEvent2_default;
      extern const uint8_t _serialEvent3_default;
      Serial.printf("Default serialEvent? %d %d %d %d\n", _serialEvent_default,
                    _serialEvent1_default, _serialEvent2_default, _serialEvent3_default);
    #if defined(__IMXRT1062__)
      Serial4.begin(2000000);
      Serial5.begin(2000000);
      Serial6.begin(2000000);
      Serial7.begin(2000000);
      //Serial8.begin(2000000);
      extern const uint8_t _serialEvent4_default;
      extern const uint8_t _serialEvent5_default;
      extern const uint8_t _serialEvent6_default;
      extern const uint8_t _serialEvent7_default;
      //  extern const uint8_t _serialEvent8_default;
      Serial.printf("    %d %d %d %d\n", _serialEvent4_default,
                    _serialEvent5_default, _serialEvent6_default, _serialEvent7_default);
    void TimeYieldCalls(const char *sz) {
      yield();
      Serial.print(sz); Serial.flush();
      elapsedMicros em = 0;
      for (uint32_t i = 0; i < 1000; i++) yield();
      uint32_t elapsed = em;
      Serial.print(": ");
      Serial.println(elapsed, DEC);
      Serial.flush();
      while (Serial.read() != -1) ; // Make sure queue is empty.
      Serial.println("Press any key to run test");
      while (!Serial.available()) ; // will loop until it receives something
      while (Serial.read() != -1) ; // loop until queue is empty
      Serial.printf("start test yield_active_check_flags %x\n", yield_active_check_flags);
      Serial.printf("  systick ISR: %x\n", (uint32_t) _VectorsRam[15]);
      TimeYieldCalls("Start");
      // First try with immediate call.
      event.attachImmediate(&asyncEventResponder);
      Serial.printf("Test Immediate: %x %x\n", yield_active_check_flags, (uint32_t) _VectorsRam[15]);
      event.clearEvent();
      digitalWriteFast(CS_PIN, LOW);
      SPI.beginTransaction(SPISettings(2000000, MSBFIRST, SPI_MODE0));
      SPI.transfer(buffer, NULL, sizeof(buffer), event);
      while (!event_happened) ;
      SPI.endTransaction();
      TimeYieldCalls("After Immediate");
      // Use yield .
      event.detach();
      event.attach(&asyncEventResponder);
      Serial.printf("Test yield: %x %x\n", yield_active_check_flags, (uint32_t) _VectorsRam[15]);
      event.clearEvent();
      TimeYieldCalls("After yield");
      // Use Interrupt .
      event.detach();
      event.attachInterrupt(&asyncEventResponder);
      Serial.printf("Test Interrupt: %x %x\n", yield_active_check_flags, (uint32_t) _VectorsRam[15]);
      event.clearEvent();
      TimeYieldCalls("After Interrupt");
      Serial2.write(buffer, sizeof(buffer));
      delay(5000);
    void XserialEvent1() {
      int ch;
      while ((ch = Serial1.read()) != -1) Serial.write(ch);
    void XserialEvent() {
      Serial.write(Serial.read());
    void serialEventUSB1() {
      while (SerialUSB1.available())
        Serial.write(SerialUSB1.read());
    void serialEventUSB2() {
      while (SerialUSB2.available())
        Serial.write(SerialUSB2.read());
    Here is another test program, where I will try to mark up some of the interesting things on how I often use this:
    #define SPIT SPI1
    #define DBGSerial Serial
    #define CS_PIN 0
    #define SMALL_TRANSFER_SIZE 128
    #define BUFFER_SIZE 0x12000l   // More than 64K
    //uint8_t buffer[BUFFER_SIZE];
    uint8_t *buffer;  // lets malloc it...
    //uint8_t rxBuffer[SMALL_TRANSFER_SIZE];
    DMAMEM uint8_t rxBuffer[BUFFER_SIZE];
    //uint8_t *rxBuffer;
    uint8_t *foo_bar = nullptr;
    uint8_t static_buffer[16];
      // debug pins
      uint8_t stack_buffer[10];
    //  pinMode(0, OUTPUT);
    //  pinMode(1, OUTPUT);
    //  digitalWrite(0, LOW);
    //  digitalWrite(1, LOW);
      extern unsigned long _heap_start;
      extern unsigned long _heap_end;
      DBGSerial.begin(115200);
      DBGSerial.println("SPI Test program");
      SPIT.begin();
      buffer = (uint8_t *)malloc(BUFFER_SIZE);
      //rxBuffer = (uint8_t *)malloc(BUFFER_SIZE);
      DBGSerial.print("Buffer: ");
      DBGSerial.print((uint32_t)buffer, HEX);
      DBGSerial.print(" RX Buffer: ");
      DBGSerial.print((uint32_t)rxBuffer, HEX);
      DBGSerial.print(" ");
      DBGSerial.println(BUFFER_SIZE, DEC);
      DBGSerial.printf("Static buffer: %x, Stack Buffer: %x\n", (uint32_t)static_buffer, (uint32_t)stack_buffer);
      DBGSerial.printf("Heap Start: %x, Heap End: %x\n", (uint32_t)&_heap_start, (uint32_t)&_heap_end);
    int nn = 0;
    //  while (DBGSerial.read() != -1) ; // Make sure queue is empty.
    //  DBGSerial.println("Press any key to run test");
      //while (!DBGSerial.available()) ; // will loop until it receives something
    //  while (DBGSerial.read() != -1) ; // loop until queue is empty
      DBGSerial.println("Ready to start tests");
      SPIT.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
      DBGSerial.println("After Begin Transaction");
      // Transfer Sync
      for (uint32_t i = 0; i < BUFFER_SIZE; i++) buffer[i] = i & 0xff;
      for (uint32_t i = 0; i < BUFFER_SIZE; i++)  rxBuffer[i] = 0x5a;
      DBGSerial.println("Transfer Small"); //DBGSerial.flush();
      SPIT.transfer(buffer, rxBuffer, SMALL_TRANSFER_SIZE);
      DBGSerial.println("*** Completed ***"); DBGSerial.flush();
      dumpBuffer(buffer, SMALL_TRANSFER_SIZE);
      DBGSerial.println();
      dumpBuffer(rxBuffer, SMALL_TRANSFER_SIZE);
      validateTXBuffer(0);
      delay(5);
      DBGSerial.println("write Small"); DBGSerial.flush();
      SPIT.transfer(buffer, NULL, SMALL_TRANSFER_SIZE);
      delay(5);
      DBGSerial.println("read Small"); DBGSerial.flush();
      SPIT.transfer(NULL, rxBuffer, SMALL_TRANSFER_SIZE);
      delay(5);
      SPIT.beginTransaction(SPISettings(2000000, MSBFIRST, SPI_MODE0));
      for (uint32_t i = 0; i < BUFFER_SIZE; i++)buffer[i] = i / 1024;
      DBGSerial.println("Transfer Full"); DBGSerial.flush();
      SPIT.transfer(buffer, rxBuffer, BUFFER_SIZE);
      validateTXBuffer(1);
      delay(5);
      for (uint32_t i = 0; i < BUFFER_SIZE; i++) buffer[i] = i / 1024;
      DBGSerial.println("write full"); DBGSerial.flush();
      SPIT.transfer(buffer, NULL, BUFFER_SIZE);
      delay(5);
      DBGSerial.println("read full"); DBGSerial.flush();
      SPIT.transfer(NULL, buffer, BUFFER_SIZE);
      delay(5);
      // Transfer Async
      for (uint32_t i = 0; i < 5; i++) {
        delay(1);
        delay(1);
      DBGSerial.println("Async write Small"); DBGSerial.flush();
      SPIT.transfer(buffer, NULL, SMALL_TRANSFER_SIZE, event);
      DBGSerial.println("After write call, waiting for event");
      delay(5);
      DBGSerial.println("Async Transfer Small"); DBGSerial.flush();
      SPIT.transfer(buffer, rxBuffer, SMALL_TRANSFER_SIZE, event);
      DBGSerial.println("After Transfer call, waiting for event");
      delay(5);
      DBGSerial.println("Async read Small"); DBGSerial.flush();
      SPIT.setTransferWriteFill(0x42);
      SPIT.transfer(NULL, rxBuffer, SMALL_TRANSFER_SIZE, event);
      //arm_dcache_delete(rxBuffer, SMALL_TRANSFER_SIZE);
      delay(5);
      DBGSerial.println("Async Transfer Full"); DBGSerial.flush();
      SPIT.transfer(buffer, rxBuffer, BUFFER_SIZE, event);
      dumpBuffer(rxBuffer, 512);
      delay(5);
      DBGSerial.println("Async write full"); DBGSerial.flush();
      SPIT.transfer(buffer, NULL, BUFFER_SIZE, event);
      delay(5);
      DBGSerial.println("Async read full"); DBGSerial.flush();
      SPIT.transfer(NULL, rxBuffer, BUFFER_SIZE, event);
      delay(5);
      DBGSerial.println("Tests completed");
      SPIT.endTransaction();
    void dumpBuffer(uint8_t *pb, int cb) {
      uint8_t i = 0;
      while (cb) {
        DBGSerial.print(*pb++, HEX);
        cb--;
        i++;
        if (i == 16) {
          i = 0;
    void validateTXBuffer(uint8_t test)
      uint8_t error_count = 0;
      for (int i = 0; i < BUFFER_SIZE; i++) {
        if (((test == 0) && (buffer[i] != (i & 0xff)))
            || ((test == 1) && (buffer[i] != (i / 1024)))) {
          DBGSerial.print("Tx Buffer validate failed Index: ");
          DBGSerial.print(i, DEC);
          DBGSerial.print(" Value: ");
          DBGSerial.println(buffer[i], HEX);
          error_count++;
          if (error_count == 10)
    Note on the waits for the event to have happened I may also put in some form of timeout.
    SPI DMA seems to work on SPI and SPI1 on teensy 3.6
    I hacked around in the SPI class and made _dma_state volatile as well as making it public. Then you can query this state without having to implement an EventResponder (and having the implications with yield() etc).
    Something like:
    while(true) {
        if(SPI._dma_state == SPIClass:DMAState::completed) break;
        delayMicroseconds(10);
    With this, I can fill the screen of two SSD1306 OLEDs with text/boxes and updating them via SPI within 0.75 ms
    We were just writing simultaneously. Thanks a lot, will have a look!
    Comparing Kurt's code with my hack of exposing _dma_state, I am wondering if there is interest in a pull request that exposes _dma_state through a getter function?
    Then SPI_HAS_TRANSFER_ASYNC would always be 1. The only thing I am uncertain about is how the transfer API should look like, because at the moment, normal transfer and async transfer are differentiated whether an EventResponder REFERENCE is passed to the transfer function, which is quite implicit, I would say.
    Or are there plans to make the concept of the EventResponder more ubiquitous for example also for async i2c?
    9,219
    Quote Originally Posted by cinhcet View Post
    First, the last part: The EventResponder concept was something Paul setup as something he would like to fully integrate to take care of several different areas of event like code... So will it make it into something like I2C?
    Not sure. Probably would be nice, but will it ever get up to a high enough priority to get done? I am not sure. Obviously if someone took that on and did it, Paul would probably be interested, in reviewing and maybe adding.
    Originally when I was wanting to add Asynchronous SPI, my first implementations were with just passing in a pointer to callback function, but at that time Paul wanted to go through the EventResponder as a good test case, which also gave you options on when that gets called. So in the case when you want it fast, just setting up the responder to call immediate did not add a whole lot of overhead.
    Thanks a lot for your answer!
    From an outsiders perspective who did not know the history/current state of the EventResponder, I would argue that the EventResponder API should be optional and a more direct way with passing a pointer to a callback function as well as the ability to query the dma state could be a good addition to the SPI class.
    9,219
    I understand about simple callback...
    As for DMA state. The main issue may be, that how the DMA works is different for different processors. Like the T3.5 is sort of screwy if you try to use SPI1 or SPI2 as there is only one DMA event for both RX and TX and you can only use it for one of them... So it has to do other tricks. Also if your copy is larger than one DMA transfer can handle the underlying handler than restarts the DMA at the next locations... So the idea is you hopefully don't need to know all of those details.
    Ok, then I have misunderstood the code. As far as I could tell, _dma_state really tells if the whole transfer has finished, even if there are multiple ones needed.
    9,219
    You may be right that I kept an internal variable for state information. I have not used it in awhile.
    At the time we only wanted to add minimal new APIS to SPI that were different than the ones that the Arduino boards support. At the time I also had a Transfer16 version as well that was async. but that was removed.
