Note: I believe that the current beta has some of the fixes I put in earlier for the different functionality for the different pins:
That is there are 6 new pins:
Micromod new pins
For example:Code:40 40 B0_04 2:04 Wire?(2) SCL QT2_1 2:4 LCD_DATA0 41 42 B0_05 2:05 Wire?(2) SDA QT2_2 2:5 LCD_DATA1 42 44 B0_06 2:06 QT3_0 2:6 LCD_DATA2 43 46 B0_07 2:07 QT3_1 2:7 LCD_DATA3 44 48 B0_08 2:08 QT3_2 2:8 LCD_DATA4 45 73 B0_09 2:09 QT4_0 2:9 LCD_DATA5
The Wire library now has a Wire3 object for the two new pins 40 and 41
Also the other Wire2 object has same pins as T4 (as SDIO pins are same as T4 and not T4.1 and does not have bottom memory pins)
The PWM pins were updated SDIO pin numbers plus some new Quad TImers. Some of which are duplicates of other quad time pins.
I probably need to update my own FliexIO pins for the new pins which will be nice. Had some stuff edited on my machine, more for the fact that there are 8 of shifters... not 4... So will play with this one soon.
I have not looked yet to see if enough pins in the LCD_ pins to be used or not.
An interesting fun is going to be: looking at these carrier boards like the ATP board, and when I look at a pin labeled G10, having to translate that every time to know that is probably Teensy pin: 33
Again I added the ATP pins to one of my tables. Extract from....
Probably someone is going to have to make a set of decals or the like that you can easily mark up to know which pin is whichCode:Pin MM Pin MM ATP Machine Learning Machine 2nd use Name GPIO USB D+ 3 USB_D+ USB_D+ 28 4 3.3V_EN 3.3V_EN EMC_32 3.18 USB D- 5 USB_D- USB_D- 27/A13 8 G11 AD_B1_15 1.31 4 10 D0 D0 HEADER_CS EMC_06 4.6 18/A4 12 I2C_SDA I2C_SDA AD_B1_01 1.17 19/A5 14 I2C_SCL I2C_SCL AD_B1_00 1.16 29 16 I2C_INT# CAMERA_INT EMC_31 4.31 0 17 UART_TX1 TX1 AD_B0_03 1.3 5 18 D1 D1 CAMERA_TRIG EMC_08 4.8 1 19 UART_RX1 RX1 AD_B0_02 1.2 16/A2 20 UART_RX2 AD_B1_07 1.23 17/A3 22 UART_TX2 AD_B1_06 1.22 3 32 PWM0 PWM0 EMC_05 4.5 14/A0 34 A0 A0 AD_B1_02 1.18 HUSB D+ 35 USBHOST_D+ HUSB D- 37 USBHOST_D- 15/A1 38 A1 A1 AD_B1_03 1.19 40 40 G0/BUS0 CAMERA_D0 B0_04 2:04 30 41 CAN_RX EMC_37 3.23 41 42 G1/BUS1 CAMERA_D1 B0_05 2:05 31 43 CAN_TX EMC_36 3.22 42 44 G2/BUS2 CAMERA_D2 B0_06 2:06 43 46 G3/BUS3 CAMERA_D3 B0_07 2:07 2 47 PWM1 PWM1 CAM_VDD EMC_04 4.4 44 48 G4/BUS4 CAMERA_D4 B0_08 2:08 22/A8 49 BATT_VIN3 BATT_VIN3 AD_B1_08 1.24 21/A7 50 AUD_BCLK I2S_SCK PDM_CLK AD_B1_11 1.27 25/A11 51 I2C_SDA1 AD_B0_13 1.13 20/A6 52 AUD_LRCLK I2S_WS PDM_DAT AD_B1_10 1.26 24/A10 53 I2C_SCL1 AD_B0_12 1.12 8 54 AUD_IN I2S_SD CAMERA_PCLK B1_00 2.16 10 55 SPI_CS SPI_CS B0_00 2.0 7 56 AUD_OUT CAMERA_MCLK B1_01 2.17 13 57 SPI_SCK SPI_SCK B0_03 2.3 23/A9 58 AUD_MCLK AD_B1_09 1.25 11 59 SPI_SCOPI SPI_SCOPI B0_02 2.2 36 60 SDIO_SCK SD_B0_01 3.13 12 61 SPI_CIPO SPI_CIPO B0_01 2.1 37 62 SDIO_CMD SD_B0_00 3.12 33 63 G10 CAMERA_VSYNC EMC_07 4.7 35 64 SDIO_DATA0 SD_B0_02 3.14 32 65 G9 CAMERA_HSYNC B0_12 2.12 34 66 SDIO_DATA1 SD_B0_03 3.15 26/A12 67 G8 AD_B1_14 1.30 38 68 SDIO_DATA2 SD_B0_05 3.17 9 69 G7/BUS7 CAMERA_D7 B0_11 2.11 39 70 SDIO_DATA3 SD_B0_04 3.16 6 71 G6/BUS6 CAMERA_D6 B0_10 2.10 45 73 G5/BUS5 CAMERA_D5 B0_09 2:09 --- ---- ---- SD Pins - Cable connector(T4 34-39)
Nice work Mike - I should fire up PinTest and can ID those two.
BTW - the Beta Teensy MMod arrived today in good shape. GOSH that PCB is THIN!
I got 3 other MCU PCB's and didn't notice how thin as I screwed them in and set them aside the other week.
Rts cts pins show unconnected on schematic on first post
Mike: On ATP CARRIER :: CTS and RTS pins show NO CONNECTION
> Explains why they were not found - Pin test cannot find them either.
Also finding PIN 22 is showing "HELD HIGH" When MM_T is on either Machine Learn or ATP carrier
> That pin does not show on edge (or in @KurtE notes above?) , not sure where it is connected?
For this BETA MicroMod_Teensy on ATP Carrier and Machine Learning::
> "BOOT" button does the bootloader "Button" function.
> "RESET" button Power Off/On
Note:
> Machine Learn board has pullups on 18/19 { i2c }
> ATP does not have Pullups on 18/19
> Logger Carrier shows #22 again and these pins HIGH on PullDown Start : 10,18,19,22,41,42
Here for ref : github.com/TeensyUser/doc/tree/master/examples/GPIO/pinList
> is a sketch by @luni that ID's all the pins by # to their GPIO_PORT I just did a PR to include :: || defined (ARDUINO_TEENSY_MICROMOD)
FWIW - a T_4.0 era start on pin checking called "NewPinTest" when a board had some trouble with shorted pins - but never cleaned to be perfect or pretty:
Directions for USE:Code:uint32_t xx = 3; // pick TEST inloop() :: 0,1,2 >> change this before compile - or add query in setup() to set void setup() { Serial.begin(115200); while (!Serial && millis() < 4000 ); Serial.println("Compile Time:: " __FILE__ " " __DATE__ " " __TIME__); analogReadRes(12); analogWriteRes(12); Serial.print("This Teensy Digital Pin Count :: "); Serial.println(NUM_DIGITAL_PINS); HelpMe(); } uint32_t cnt = 0; void loop() { cnt++; if ( xx == 0 ) { // array pinsSDIO[] requires PINS JUMPERED: 34>37, 35>38, 36>39 sdioTestPWM( cnt ); } else if ( xx == 1 ) { // This code changes Voltage seen on each pin // Freq changes in pin pairs: 34/35, 36/37, 38/39 sdioTestVolts( cnt ); } else if ( xx == 2 ) { // Paul's code changes FREQ to each pin // uint32_t xx = 2; // change this before compile - or add query in setup() to set loopPaulHz(); } else if ( xx == 3 ) { allPinTest( cnt ); } else if ( xx == 4 ) { aLogPinTest( cnt ); } int xxQ = tellMe( 0 ); if (xxQ < 10 ) xx = xxQ; } elapsedMillis emiWait; uint32_t emWaitM; uint32_t pinsSDIO[9] = { 34, 35, 36, 37, 38, 39, 34, 35, 36 }; //note first three repeat duplicates //uint32_t pinsSDIO[9] = { 34, 35, 36, 37, 39, 38, 34, 35, 36 }; FASTRUN void sdioTestPWM( uint32_t cnt) { int ii, mm, nn; if ( cnt % 2 ) mm = 0; else mm = 3; for ( ii = mm; ii < mm + 3; ii++ ) { nn = ii + 3; // pinMode( pinsSDIO[ii], INPUT_DISABLE); // Not required - pin state set on analogWrite pinMode( pinsSDIO[nn], INPUT); } for ( ii = mm; ii < mm + 3; ii++ ) { nn = ii + 3; //analogWriteFrequency( pinsSDIO[ii], (nn + (cnt % 4)) * 1000000 ); // Similar results on changing or other frequencies analogWriteFrequency( pinsSDIO[ii], 16664000 ); analogWrite( pinsSDIO[ii], 128 ); delayMicroseconds( 4); uint32_t pCnt = 0, Cnt0 = 0, Cnt1 = 0; while ( 0 == digitalReadFast( pinsSDIO[nn] ) ); while ( digitalReadFast( pinsSDIO[nn] ) ); emiWait = 0; emWaitM = millis() + 500; while ( emiWait < 500 ) { // while ( emWaitM >millis() ) { while ( 0 == digitalReadFast( pinsSDIO[nn] ) ) Cnt0++; while ( digitalReadFast( pinsSDIO[nn] ) ) Cnt1++; pCnt++; } Serial.print(ii); Serial.print(" Cnt="); Serial.print(pCnt * 2); Serial.print(" PWM out ="); Serial.print(pinsSDIO[ii]); Serial.print(" Dig Read ="); Serial.print(pinsSDIO[nn]); Serial.print(" Cnt0's="); Serial.print(Cnt0); Serial.print(" Cnt1's="); Serial.print(Cnt1); Serial.println(); } Serial.println(); } FASTRUN void sdioTestVolts( uint32_t cnt) { int ii, nn; for ( ii = 0; ii < 6; ii++ ) { nn = 1 + ii; analogWriteFrequency( pinsSDIO[ii], nn * 1000 ); analogWrite( pinsSDIO[ii], nn * 32 ); } while (1) { } } uint32_t n = 0; void loopPaulHz() { #ifdef GPIO8_GDIR GPIO8_GDIR |= (0x3F << 12); n++; GPIO8_DR = (GPIO8_DR & ~(0x3F << 12)) | ((n & 0x3F) << 12); delayMicroseconds(50); #endif } uint32_t pinLast[NUM_DIGITAL_PINS]; void allPinTest( uint32_t cnt ) { uint32_t ii, SET; Serial.print("PULLDOWN Start Vals:\n "); SET = 0; Serial.print("PULLDOWN :: TEST to 3.3V\n "); for ( ii = 0; ii < NUM_DIGITAL_PINS; ii++) { pinMode( ii, INPUT_PULLDOWN ); delayMicroseconds( 5 ); pinLast[ii] = digitalReadFast( ii ); if (pinLast[ii]) { Serial.print("\nd#="); Serial.print( ii ); Serial.print( " val=" ); } Serial.print( pinLast[ii] ); Serial.print(','); } Serial.println(); Serial.println(); while ( 1 ) { uint32_t jj, dd = 0, cc = 0; cc = 0; for ( ii = 0; ii < NUM_DIGITAL_PINS; ii++) { jj = digitalReadFast( ii ); if ( jj != pinLast[ii] ) { dd = 1; cc++; pinLast[ii] = jj; Serial.print("d#="); Serial.print( ii ); if ( pinLast[ii] ) Serial.print( "\t" ); Serial.print( " val=" ); Serial.print( pinLast[ii] ); Serial.print(','); } if ( cc > 1 ) { Serial.println(">>>"); } if ( Serial.available() ) { while ( Serial.available() ) Serial.read(); if ( 0 == SET ) { SET = 1; Serial.print("PULLUP :: TEST TO GND\n "); } else { SET = 0; Serial.print("PULLDOWN :: TEST to 3.3V\n "); } for ( ii = 0; ii < NUM_DIGITAL_PINS; ii++) { if ( 0 == SET ) pinMode( ii, INPUT_PULLDOWN ); else pinMode( ii, INPUT_PULLUP ); delayMicroseconds( 20 ); pinLast[ii] = digitalReadFast( ii ); if (SET != pinLast[ii]) { Serial.print("d#="); Serial.print( ii ); Serial.print( " val=" ); Serial.println( pinLast[ii] ); } } } } if ( dd ) { dd = 0; Serial.println(); delay( 50 ); } } } PROGMEM char showText [][48] = { "Enter # below for test choice\t ver0.1\n", "\t0: test 34,35,36 crossed to 36,37,38\n", "\t1: change voltage on 34-39\n", "\t2: change Freq on 34-39\n", "\t3: All Pins Test digital\n", "\t4: Test Analog A0-A13 \n", "" }; int tellMe( int whatNow ) { int retVal = 0; if ( 0 == whatNow ) if ( Serial.available() ) while ( Serial.available() ) Serial.read(); else return 100; HelpMe(); while ( Serial.available() ) { char chi = Serial.read(); if ( chi >= '0' && chi <= '9' ) retVal = chi - '0'; } return retVal; } void HelpMe() { uint32_t ii = 0; while ( 0 != showText[ii][0] ) { Serial.print( showText[ii] ); ii++; } } uint32_t pinAlog[ 14 ] = {A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13}; // FAKE NUM_ANALOG_INPUTS==14 t4 p#14-#27 void aLogPinTest( uint32_t cnt ) { uint32_t ii, SET; Serial.print("PULLDOWN Start Vals:\n "); SET = 0; Serial.print("PULLDOWN :: TEST to 3.3V\n "); for ( ii = 0; ii < NUM_DIGITAL_PINS; ii++) { pinMode( ii, INPUT_PULLDOWN ); delayMicroseconds( 5 ); pinLast[ii] = digitalReadFast( ii ); if (pinLast[ii]) { Serial.print("\nd#="); Serial.print( ii ); Serial.print( " val=" ); } Serial.print( pinLast[ii] ); Serial.print(','); } Serial.println(); Serial.println(); while ( 1 ) { uint32_t jj, dd = 0, cc = 0; cc = 0; for ( ii = 0; ii < NUM_DIGITAL_PINS; ii++) { jj = digitalReadFast( ii ); if ( jj != pinLast[ii] ) { dd = 1; cc++; pinLast[ii] = jj; Serial.print("d#="); Serial.print( ii ); if ( pinLast[ii] ) Serial.print( "\t" ); Serial.print( " val=" ); Serial.print( pinLast[ii] ); Serial.print(','); } if ( cc > 1 ) { Serial.println(">>>"); } if ( Serial.available() ) { while ( Serial.available() ) Serial.read(); if ( 0 == SET ) { SET = 1; Serial.print("PULLUP :: TEST TO GND\n "); } else { SET = 0; Serial.print("PULLDOWN :: TEST to 3.3V\n "); } for ( ii = 0; ii < NUM_DIGITAL_PINS; ii++) { if ( 0 == SET ) pinMode( ii, INPUT_PULLDOWN ); else pinMode( ii, INPUT_PULLUP ); delayMicroseconds( 20 ); pinLast[ii] = digitalReadFast( ii ); if (SET != pinLast[ii]) { Serial.print("d#="); Serial.print( ii ); Serial.print( " val=" ); Serial.println( pinLast[ii] ); } } } } if ( dd ) { dd = 0; Serial.println(); delay( 50 ); } } }
<edited code to compile on non-1062's : removing a PJRC freq cycle test>Code:It gives a static reading of the pins in Pull Up or Pull Down when that 'test mode' is entered. Ideally with nothing connected all pins should show 0 on PULL DOWN and 1 on PULL UP, when things are connected, or there are issues they will print the pin number for unexpected values. The SerMon displayed notes: "PULLDOWN :: TEST to 3.3V" and "PULLUP :: TEST TO GND" Are for dynamic testing as noted use a WIRE either at 3.3V or GND and carefully touch the other 'testable' pins and they will show a change by number. Touching a Single pin as indicated should only change a single pin (otherwise it is a short to any other changing pins) and a single pin change should be as expected transitioning 0>1 or 1>0 depending on the test.
Last edited by defragster; 04-03-2021 at 08:32 AM. Reason: add more info, add needed 1062 ifdef
@FrankB - made edits to support MMod and turn off HardFault define: T4_PowerButton.zip (too late here to do PR or edit)
Using (with #ifdef edits to support ARDUINO_TEENSY_MICROMOD above) :: github.com/FrankBoesing/T4_PowerButton
This quick edit to power.ino changes it to RESET when the power button is pressed : in added ZIP above as added examples reset.ino
Code:#include "T4_PowerButton.h" void myCallback(void) { digitalWriteFast( 13, 1); Serial.print(" RESTART Teensy ..."); delay(100); SCB_AIRCR = 0x05FA0004; delay(100); } void setup() { Serial.begin(115200); while (!Serial && millis() < 4000 ); if (arm_power_button_pressed()) { Serial.println("Restart after power down"); } else { Serial.println("First power on"); } pinMode(13, OUTPUT); set_arm_power_button_callback(&myCallback); //Start callback } void loop() { digitalWriteFast( 13, !digitalReadFast(13)); delay(100); }
@defragster - @KurtE
RTS/CTS not connected - I saw that on the schematic as well but wasn't sure if I was missing something or not. Guess I would have repurposed them. Oh well. With a little luck maybe I will be get mine today instead of tomorrow.
@defragster
Pin 22 is identified as BATT_VIN/22/A23 on the T4 schematic = its pin 49 on the M.2 connector - I think if I am reading it right.Also finding PIN 22 is showing "HELD HIGH" When MM_T is on either Machine Learn or ATP carrier
SD SDIO breakout board
Got curious and found that Adafruit actually one: https://www.adafruit.com/product/4682. It also has a Detect pin that we can have some fun with
Going to be interesting to see if it works.
@Paul
Just pushed a change to the Teensy4 Quad Encoder Library to support the Teensy MicroMod. Warning haven't tested it yet - but will once I get the board which looks like tomorrow
My MMOD is in town now at our mail box. Hopefully get there in the next few days... Have a few things going on here at home, so not sure which day.
RTS/CTS - I don't know why they did not bring out some Teensy pins out for these... It is supposed to be for the:
Again not sure why they did not give pins for these.Code:UART_RTS1 O UART ready to send. 3.3V UART_CTS1 I UART clear to send. 3.3V
For RTS, this could be any digital pin as we work with it that way.
For CTS - It needs to be a CTS pin for that, which there is only one defined:
LPUART6_CTS_B GPIO_EMC_30 ALT2
Which we have not used on any T4.x yet...
However you can setup a CTS using any available XBAR pin as long as you are not trying to use an XBAR pin for the RX pin of that uart... So they could define
Which reminds me I probably need to double check that table in HardwareSerial.cpp...
I think it is defined the same as T4 which I think we have XBARIO pins of (4-10, 14-17,22, 23)
So could find one of the other XBar pins we have not used...
Suddenly qwiic peripherals seem more interesting.
Morning @KurtE
Neither do I that why when I saw it on the schematic as not connected I got confused.
Anyway - there are probably a few places where we used ARDUINO_TEENSY40/TEENSY41 vs __IMXRT1062_ . Think in our display libraries with just used IMXRT1062 as well as in SPI. If I remember correctly.
I did remember to check QUAD ENCODER lib. From what I remember of the libs think we primarily used the 1062 ifdef's.
Yep - May order one at some point, not sure where yet, looks like digikey has them... Can always test the boards SDIO with the data logger board or the machine learning board.
however the interesting thing with debugging some of the stuff on their boards could be challenging. That is for example the camera, not sure where or how will hook up Logic Analyzer to check out the signals.
Wish they had the Kitchen Sink adapter board. One that has: ATP, plus USB, plus SDIO, plus CAMERA, QWIIC
Most of the display libraries that we updated to do things like:
like we did in the ILI9488_t3... I started that in the ILI9341_t3n with SPIN, but then we moved tables over to SPI.Code:// Now validate the pins if (spi_port->pinIsMOSI(_mosi) && spi_port->pinIsSCK(_sclk)) { //spi_port= &SPI; if(!(spi_port->pinIsMISO(_miso))) { _miso = 0xff; // set miso to 255 as flag it is bad
Should probably double check SPI.
I believe in most case it is defined the same as for Teeny 4. That is the tables are defined like:
I thought I checked the pins that were compatible with the T4s, but should double check againCode:#if defined(ARDUINO_TEENSY41) const SPIClass::SPI_Hardware_t SPIClass::spiclass_lpspi1_hardware = { CCM_CCGR1, CCM_CCGR1_LPSPI1(CCM_CCGR_ON), DMAMUX_SOURCE_LPSPI1_TX, DMAMUX_SOURCE_LPSPI1_RX, _spi_dma_rxISR1, 42, 54, 4 | 0x10, 3 | 0x10, 1, 0, IOMUXC_LPSPI1_SDI_SELECT_INPUT, 43, 50, 4 | 0x10, 3 | 0x10, 1, 0, IOMUXC_LPSPI1_SDO_SELECT_INPUT, 45, 49, 4 | 0x10, 3 | 0x10, 1, 0, IOMUXC_LPSPI1_SCK_SELECT_INPUT, 44, 255, 255, 4 | 0x10, 0, 0, 1, 0, 0, 0, 0, 0, &IOMUXC_LPSPI1_PCS0_SELECT_INPUT, 0, 0 }; #else const SPIClass::SPI_Hardware_t SPIClass::spiclass_lpspi1_hardware = { CCM_CCGR1, CCM_CCGR1_LPSPI1(CCM_CCGR_ON), DMAMUX_SOURCE_LPSPI1_TX, DMAMUX_SOURCE_LPSPI1_RX, _spi_dma_rxISR1, 34, 4 | 0x10, 1, IOMUXC_LPSPI1_SDI_SELECT_INPUT, 35, 4 | 0x10, 1, IOMUXC_LPSPI1_SDO_SELECT_INPUT, 37, 4 | 0x10, 1, IOMUXC_LPSPI1_SCK_SELECT_INPUT, 36, 4 | 0x10, 1, 0, &IOMUXC_LPSPI1_PCS0_SELECT_INPUT }; #endif
Agree. But no such luck. Have a feeling they were trying to keep carrier boards small and focused. But don't think it would have taken much to add in the camera to the ATP board. Since Adafruit ships from NY which is not far from me, should have it tomorrow, I hope. Reason I got it is that I didn't want to have to keep switching boards.
Other thing I was thinking about is the temperature profile with this new board. There is not much mass on the MCU board so wondering what the heating profile is going to be. Saw this video from VisualMicro on running the teensy at 1Ghz. Interesting results showing coremarks and temperature profile:
Figured I was going to run through our stable of displays and try and hook up the i2c test board we have as a double check. Then fix the libs as appropriately.
I did look at the HX83.. lib and it looked ok, as you said.
What will be interesting is testing Wire3 pins as we don't have Wire3 on T4 or 4.1...
Oooh. Missed that - that's your wire? on pins 40 and 41? Is wire3 even defined in wireIMXRT.h? I am getting myself confused again. This is what's in wireIMXRT.h currently:
So do we need aCode://#define WIRE_HAS_END 1 #define WIRE_IMPLEMENT_WIRE #define WIRE_IMPLEMENT_WIRE1 #define WIRE_IMPLEMENT_WIRE2
?Code:#if defined(ARDUINO_TEENSY_MICROMOD) #define WIRE_IMPLEMENT_WIRE3 #endif
EDIT: Now is this correct as well"
According to the schematic pins24/25 are wire1 but this is showing Wire2? Or am I missing somethingCode:constexpr TwoWire::I2C_Hardware_t TwoWire::i2c3_hardware = { CCM_CCGR2, CCM_CCGR2_LPI2C3(CCM_CCGR_ON), #if defined(ARDUINO_TEENSY41) {{17, 1 | 0x10, &IOMUXC_LPI2C3_SDA_SELECT_INPUT, 2}, {44, 2 | 0x10, &IOMUXC_LPI2C3_SDA_SELECT_INPUT, 1}}, {{16, 1 | 0x10, &IOMUXC_LPI2C3_SCL_SELECT_INPUT, 2}, {45, 2 | 0x10, &IOMUXC_LPI2C3_SCL_SELECT_INPUT, 1}}, #else // T4 and ARDUINO_TEENSY_MICROMOD {{17, 1 | 0x10, &IOMUXC_LPI2C3_SDA_SELECT_INPUT, 2}, {36, 2 | 0x10, &IOMUXC_LPI2C3_SDA_SELECT_INPUT, 1}}, {{16, 1 | 0x10, &IOMUXC_LPI2C3_SCL_SELECT_INPUT, 2}, {37, 2 | 0x10, &IOMUXC_LPI2C3_SCL_SELECT_INPUT, 1}}, #endif IRQ_LPI2C3 }; TwoWire Wire1(&IMXRT_LPI2C3, TwoWire::i2c3_hardware); PROGMEM constexpr TwoWire::I2C_Hardware_t TwoWire::i2c4_hardware = { CCM_CCGR6, CCM_CCGR6_LPI2C4_SERIAL(CCM_CCGR_ON), {{25, 0 | 0x10, &IOMUXC_LPI2C4_SDA_SELECT_INPUT, 1}, {0xff, 0xff, nullptr, 0}}, {{24, 0 | 0x10, &IOMUXC_LPI2C4_SCL_SELECT_INPUT, 1}, {0xff, 0xff, nullptr, 0}}, IRQ_LPI2C4 }; TwoWire Wire2(&IMXRT_LPI2C4, TwoWire::i2c4_hardware); #if defined(ARDUINO_TEENSY_MICROMOD) PROGMEM constexpr TwoWire::I2C_Hardware_t TwoWire::i2c2_hardware = { CCM_CCGR2, CCM_CCGR2_LPI2C2(CCM_CCGR_ON), {{41, 2 | 0x10, &IOMUXC_LPI2C2_SDA_SELECT_INPUT, 1}, {0xff, 0xff, nullptr, 0}}, {{40, 2 | 0x10, &IOMUXC_LPI2C2_SCL_SELECT_INPUT, 1}, {0xff, 0xff, nullptr, 0}}, IRQ_LPI2C4 }; TwoWire Wire3(&IMXRT_LPI2C2, TwoWire::i2c2_hardware);
there could maybe be more micromods in different teensies in future? who knows, but make it specific for the 4.x?
Code:#if defined(ARDUINO_TEENSY_MICROMOD) && defined(__IMXRT1062__)
