Page 3 of 41 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 51 to 75 of 1020
Thread: MicroMod Beta Testing
  1. #51
    10,316
    there could maybe be more micromods in different teensies in future? who knows, but make it specific for the 4.x?
    #if defined(ARDUINO_TEENSY_MICROMOD) && defined(__IMXRT1062__)
    There may be other Micromods, but these names, like: ARDUINO_TEENSY40, ARDUINO_TEENSY41, ARDUINO_TEENSY_MICROMOD
    Are names that come directly out of boards.txt and platform.txt
    That is in Platform.txt we have:
    ## Compile c++ files
    recipe.cpp.o.pattern="{compiler.path}{build.toolchain}{build.command.g++}" -c {build.flags.optimize} {build.flags.common} {build.flags.dep} {build.flags.cpp} {build.flags.cpu} {build.flags.defs} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DF_CPU={build.fcpu} -D{build.usbtype} -DLAYOUT_{build.keylayout} "-I{build.path}/pch" {includes} "{source_file}" -o "{object_file}"
    And in boards.txt we have:
    That is for teensy 4.1 we have:
    teensy41.name=Teensy 4.1
    #teensy41.upload.maximum_size=8126464
    teensy41.build.board=TEENSY41
    and likewise:
    teensyMM.name=Teensy MicroMod
    #teensyMM.upload.maximum_size=16515072
    teensyMM.build.board=TEENSY_MICROMOD
    So I am assuming that if there are new MM for different teensy boards we would probably maybe have names like:
    TEENSY_MICROMOD3 if it was a 3x version... But could be wrong
  2. #52
    10,316
    Oooh. Missed that - that's your wire? on pins 40 and 41? Is wire3 even defined in wireIMXRT.h? I am getting myself confused again. This is what's in wireIMXRT.h currently:
    //#define WIRE_HAS_END 1
    #define WIRE_IMPLEMENT_WIRE
    #define WIRE_IMPLEMENT_WIRE1
    #define WIRE_IMPLEMENT_WIRE2
    So do we need a
    #define WIRE_IMPLEMENT_WIRE3
    Yes - we should probably add that. I don't think anywhere in our imxrt code actually looks at that define but should add for
    consistency.
    As for The Wire3 object, I think it is correct, obviously may need to hook up and verify:
    According to the schematic pins24/25 are wire1 but this is showing Wire2? Or am I missing something[/QUOTE]
    PROGMEM
    constexpr TwoWire::I2C_Hardware_t TwoWire::i2c2_hardware = {
    	CCM_CCGR2, CCM_CCGR2_LPI2C2(CCM_CCGR_ON),
    		{{41, 2 | 0x10, &IOMUXC_LPI2C2_SDA_SELECT_INPUT, 1}, {0xff, 0xff, nullptr, 0}},
    		{{40, 2 | 0x10, &IOMUXC_LPI2C2_SCL_SELECT_INPUT, 1}, {0xff, 0xff, nullptr, 0}},
    	IRQ_LPI2C4
    TwoWire Wire3(&IMXRT_LPI2C2, TwoWire::i2c2_hardware);
    The names here like: i2c2_hardware is showing that this is Hardware I2C #2 which we did not have a version of before...
    But we are defineing it as the logical Object Wire3...
    Note on Teensy 4.x boards, our Wire objects are not defined in the same order as the underlying hardware I2C objects.
    Like:
    Wire is using I2C1
    Wire1 is using I2C3
    Wire2 is using I2C4
    And now:
    Wire3 is using I2C2
    Now as for pins: 24 and 25, they are the same pins used on T4 and T4.1
    24/A10 53 AD_B0_12 1.12 Serial6(1) TX Wire2(4) SCL PWM1_X2 A1:1
    25/A11 51 AD_B0_13 1.13 Serial6(1) RX Wire2(4) SDA PWM1_X3 GPT1_CLK A1:2
    So it is actually on I2C4 but in Teensy world is is Wire2...
    But not sure what their schematic is trying to show.
    It may be simply be, their way of saying it routes their I2C1 marker on for example their ATP card.
    Likewise they show 18 and 19 as SCL and SDA and likewise they don't show anything for 16 and 17...
  3. #53
    New York
    8,117
    Still a bit confused, not trying to give you a hard time, but trying to get my head around this:
    TwoWire Wire(&IMXRT_LPI2C1, TwoWire::i2c1_hardware); -> LPI2C1 -> 18, 19: Go it makes sense Wire is on pins18, 19
    TwoWire Wire1(&IMXRT_LPI2C3, TwoWire::i2c3_hardware); -> LPI2C3 -> 16,17 for both T4.1 and MicroMod: Wire1 on pins 16,17 correct?
    TwoWire Wire2(&IMXRT_LPI2C4, TwoWire::i2c4_hardware); -> LPI2C4 -> 24,25: Got it Wire2 on pins 24, 25
    TwoWire Wire3(&IMXRT_LPI2C2, TwoWire::i2c2_hardware); -> LPI2C2 -> pins 40, 41 for Wire3 ok understand.
    Now on the MicroMod schematic in post #1
    Its showing SDA1/SCL1 (assume this means Wire1 in their terms and what we usually see) is on pins 24, 25. Based on the above Pin24/25 is Wire2 on the Teensy.
    This is why I am getting confused - we would have to remember that Wire1 on the MicroMod would be Wire3 on the Teensy. Not a big deal for me but may lead to some other confusion.
  4. #54
    15,843
    SD SDIO breakout board
    Got curious and found that Adafruit actually one: https://www.adafruit.com/product/4682. It also has a Detect pin that we can have some fun with
    Going to be interesting to see if it works.
    On MMod DataLogger and MACHINE LEARNING PIN 10 is the CARD INSERT says NewPinTest!
  5. #55
    New York
    8,117
    On MMod DataLogger" PIN 10 is the CARD INSERT says NewPinTest!
    That's strange - wonder what they are doing. If you look at the schematic its showing CS going to sdcard DAT3/CS pin wonder if they are dual purposing it or just a strange naming convention?
  6. #56
    10,316
    Me a hard time ... I honestly did not give it a second thought... I take it as something for SPARKFUN.
    I did most of the hacking for some of these changes after Paul added the Pin definitions for this board to the Teensy4 directory, long before we saw the schematic. So we had:
    #define CORE_PIN24_BIT		12
    #define CORE_PIN25_BIT		13
    #define CORE_PIN24_PORTREG	GPIO6_DR
    #define CORE_PIN25_PORTREG	GPIO6_DR
    So we know that Pin 24 is in my table as 1.12 (Port 6 is high speed of Port 1) and 25 is 1.13
    Which matched my Excel documents for T4 and T4.1 as well:
    And honestly I did not really look overly careful at their schematic bubbles. I simply in this case: saw the 24 in the bubble and the 53 and marked up my excel document...
    I just assumed they marked it that way as to match their two QWIIC connectors on the ATP.
    On another thought here on the camera. I wonder if anyone in US sells something like this 24 pin FPC breakout board:
  7. #57
    New York
    8,117
    Hows this:
    https://www.amazon.com/uxcell-Conver.../dp/B07RWMSVNH
    EDIT: Guess I will just give it a try and see what happens with the way it is. If it doesn't work then we know.
  8. #58
    10,316
    Hows this:
    just ordered one...
  9. #59
    New York
    8,117
    just ordered one...
    Cool I did as well as long as I was there
  10. #60
    15,843
    Updated that above, ATP has no SD.
    There is an SD on the Input and Display board and it has Pin 10 HIGH with NewPinTest start and no response on any pin # when card goes In/Out.
    NewPinTest shows these pins Held High:
    d#=4 val=1,0,0,0,0,0,
    d#=10 val=1,0,0,0,0,0,0,0,
    d#=18 val=1,
    d#=19 val=1,0,0,0,0,0,0,0,0,0,
    d#=29 val=1,0,0,0,0,0,0,0,0,0,0,
    d#=40 val=1,0,
    d#=42 val=1,0,0,0,
    I also updated @luni :: github.com/TeensyUser/doc/tree/master/examples/GPIO/pinList { did a PR and has been done }
    I made a version of NewPinTestPL that prints it on start For the MMod.Teensy it shows these pin mappings:
    This Teensy Digital Pin Count :: 46
    PIN   GPIOn-BITm  |  GPIOn-BITm    PIN
    00  -> GPIO6-03   |   GPIO6-02  ->  01
    01  -> GPIO6-02   |   GPIO6-03  ->  00
    02  -> GPIO9-04   |   GPIO6-12  ->  24
    03  -> GPIO9-05   |   GPIO6-13  ->  25
    04  -> GPIO9-06   |   GPIO6-16  ->  19
    05  -> GPIO9-08   |   GPIO6-17  ->  18
    06  -> GPIO7-10   |   GPIO6-18  ->  14
    07  -> GPIO7-17   |   GPIO6-19  ->  15
    08  -> GPIO7-16   |   GPIO6-22  ->  17
    09  -> GPIO7-11   |   GPIO6-23  ->  16
    10  -> GPIO7-00   |   GPIO6-24  ->  22
    11  -> GPIO7-02   |   GPIO6-25  ->  23
    12  -> GPIO7-01   |   GPIO6-26  ->  20
    13  -> GPIO7-03   |   GPIO6-27  ->  21
    14  -> GPIO6-18   |   GPIO6-30  ->  26
    15  -> GPIO6-19   |   GPIO6-31  ->  27
    16  -> GPIO6-23   |   GPIO7-00  ->  10
    17  -> GPIO6-22   |   GPIO7-01  ->  12
    18  -> GPIO6-17   |   GPIO7-02  ->  11
    19  -> GPIO6-16   |   GPIO7-03  ->  13
    20  -> GPIO6-26   |   GPIO7-04  ->  40
    21  -> GPIO6-27   |   GPIO7-05  ->  41
    22  -> GPIO6-24   |   GPIO7-06  ->  42
    23  -> GPIO6-25   |   GPIO7-07  ->  43
    24  -> GPIO6-12   |   GPIO7-08  ->  44
    25  -> GPIO6-13   |   GPIO7-09  ->  45
    26  -> GPIO6-30   |   GPIO7-10  ->  06
    27  -> GPIO6-31   |   GPIO7-11  ->  09
    28  -> GPIO8-18   |   GPIO7-12  ->  32
    29  -> GPIO9-31   |   GPIO7-16  ->  08
    30  -> GPIO8-23   |   GPIO7-17  ->  07
    31  -> GPIO8-22   |   GPIO8-12  ->  37
    32  -> GPIO7-12   |   GPIO8-13  ->  36
    33  -> GPIO9-07   |   GPIO8-14  ->  35
    34  -> GPIO8-15   |   GPIO8-15  ->  34
    35  -> GPIO8-14   |   GPIO8-16  ->  39
    36  -> GPIO8-13   |   GPIO8-17  ->  38
    37  -> GPIO8-12   |   GPIO8-18  ->  28
    38  -> GPIO8-17   |   GPIO8-22  ->  31
    39  -> GPIO8-16   |   GPIO8-23  ->  30
    40  -> GPIO7-04   |   GPIO9-04  ->  02
    41  -> GPIO7-05   |   GPIO9-05  ->  03
    42  -> GPIO7-06   |   GPIO9-06  ->  04
    43  -> GPIO7-07   |   GPIO9-07  ->  33
    44  -> GPIO7-08   |   GPIO9-08  ->  05
    45  -> GPIO7-09   |   GPIO9-31  ->  29
  11. #61
    New York
    8,117
    @defragster
    When I referencing the schematic I was looking at the datalogger schematic not the ATP carrier. Didnt look at the Machine learning schematic.
    Well just got my micromod from PJRC - thanks @Paul for the care package. But if you all what to laugh - I have a million cables but not USB-C cables so I am off to the store to get one then I can start playing.
  12. #62
    10,316
    @defragster
    Been there, found that out when I purchased my first carrier board with the ESP
  13. #63
    15,843
    Not laughing @mjs513 ... but I will say 'I told you so'
    USB-C - so awesome and yet such a pain. I ended up buying like 10 cables in combination to match and switch for new phone and chargers. Also helps with external HDD that is USB-C too - and new computer with a front USB-C.
    And the cable here is heavy/stiff and tends to pull the little carrier boards to the floor as configured - and SFun connectors are all surface mount.
  14. #64
    Germany
    1,798
    I updated my little MicroMod helper files which I made for my DIY MicroMod T3.2. Should work now with the MicroMod T4. It contains the mapping of the MM pins to the Teensy pins so that you can use the pin names as defined by Sparkfun (and printed on the carrier boards). It also has a helper class for the 8bit bus functionality.
    Since I currently don't have a MMT4 board the update was done dry and probably has some bugs in it. If somebody wants to try: https://github.com/luni64/TeensyHelp...src/MicroModT4
    Usage:
    #include "Arduino.h"
    #include "MicroModT4/MicroModTeensy.h"
    using namespace MMT;
    MM32::BUS bus;                      // might be better to have that as a predefined singleton
        pinMode(G0, OUTPUT);            // name mapping MicroMod -> TeensyPins
        digitalWriteFast(G0, HIGH);
        // bus (G0..G7) helpers:
        pinMode(bus, OUTPUT);          // set pinMode for entire bus
        bus = 0x12;                    // write 8bit value to bus
        pinMode(bus, INPUT_PULLUP);
        uint8_t val = bus;             // read 8bit value from bus
    15,843
    @Paul - quick summary - Beta MMod Teensy working as a 'normal Teensy' here with the IDE.
    Programming and T_SerMon working properly on the sketches so far.
    Only odd thing @mjs513 found (build size) resolved with that PR that has been pulled in.
    Just ran 15MB Little FS test - write not speedy? - but it works and reads 5X better:
    Start Big write of 2048000 Bytes.........................
    Big write /0_2MBfile.txt took  4.11 Sec for 2048000 Bytes : file3.size()=2048000
    	Big write KBytes per second 498.90
    Bytes Used: 2228224, Bytes Total:15728640
    printDirectory PRO_DISK
    FILE	0_2MBfile.txt		2048000
    FILE	B_file.txt		1536
    FILE	C_file.txt		2048
    FILE	D_file.txt		2560
    FILE	E_file.txt		3072
    FILE	F_file.txt		3584
    FILE	G_file.txt		4096
    FILE	H_file.txt		4608
    FILE	I_file.txt		5120
    FILE	J_file.txt		5632
    FILE	K_file.txt		6144
    FILE	L_file.txt		6656
    FILE	M_file.txt		7168
    FILE	N_file.txt		7680
    FILE	O_file.txt		8192
    FILE	P_file.txt		8704
    FILE	Q_file.txt		9216
    FILE	R_file.txt		9728
    FILE	S_file.txt		10240
    FILE	T_file.txt		10752
    FILE	U_file.txt		11264
     0 dirs with 21 files of Size 2176000 Bytes
     Total 21 files of Size 2176000 Bytes
    Delete with read verify all #bigfile's
    	Verify /0_2MBfile.txt bytes 2048000 : ..................................................	GOOD! >>  bytes 2048000
    	Big read&compare KBytes per second 2606.02
    <edit>
    'R' - Teensy reset data survives, of course
    'f' - format unused works quickly without data or integrity loss, of course
    'new program' - wipes disk, of course
  16. #66
    15,843
    @Paul: Running above 15 MB LFSInterity in the middle of '5' loops it refused programming - there was active serial output?
    After '0' : Stop running "loops"
    Updating for larger file create it 'Failed Programming'
    > After that it then worked to push the upload
    > Have cleared Loader\Verbose and will try repro ...
    Tail of TLoader Verbose:
    :00:33.223 (post_compile 12): Sending command: comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_post_compile)
    13:00:33.224 (loader): remote cmd from 1556: "dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\"
    13:00:33.224 (loader): remote cmd from 1556: "file:LFSintegrity.ino.hex"
    13:00:33.224 (post_compile 12): Status: 1, 1, 0, 1, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\, LFSintegrity.ino.hex
    13:00:33.224 (post_compile 12): Sending command: dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\
    13:00:33.224 (post_compile 12): Sending command: file:LFSintegrity.ino.hex
    13:00:33.239 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:00:33.242 (loader): remote cmd from 1556: "status"
    13:00:33.243 (post_compile 12): Status: 1, 1, 0, 1, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\, LFSintegrity.ino.hex
    13:00:33.243 (post_compile 12): Disconnect
    13:00:33.256 (loader): remote connection 1556 closed
    13:00:33.506 (post_compile 13): Begin, version=1.54-beta7, high-res time
    13:00:33.508 (loader): remote connection 1556 opened
    13:00:33.508 (loader): remote cmd from 1556: "comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_post_compile)"
    13:00:33.508 (loader): remote cmd from 1556: "status"
    13:00:33.509 (post_compile 13): Sending command: comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_post_compile)
    13:00:33.510 (post_compile 13): Status: 1, 1, 0, 1, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\, LFSintegrity.ino.hex
    13:00:33.510 (post_compile 13): Sending command: dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\
    13:00:33.510 (loader): remote cmd from 1556: "dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\"
    13:00:33.510 (loader): remote cmd from 1556: "file:LFSintegrity.ino.hex"
    13:00:33.510 (post_compile 13): Sending command: file:LFSintegrity.ino.hex
    13:00:33.525 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:00:33.532 (loader): remote cmd from 1556: "status"
    13:00:33.533 (post_compile 13): Status: 1, 1, 0, 1, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\, LFSintegrity.ino.hex
    13:00:33.533 (post_compile 13): Disconnect
    13:00:33.556 (loader): remote connection 1556 closed
    13:00:33.556 (post_compile 14): Running teensy_reboot: "T:\arduino-1.8.13_t54\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY_MICROMOD" "-port=usb:0/140000/0/1" "-portlabel=COM21 Serial" "-portprotocol=Teensy"
    13:00:33.557 (loader): remote connection 756 opened
    13:00:33.572 (loader): remote connection 1440 opened
    13:00:33.572 (loader): remote cmd from 1440: "show:arduino_attempt_reboot"
    13:00:33.572 (loader): got request to show arduino rebooting message
    13:00:33.574 (loader): remote cmd from 1440: "comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_reboot)"
    13:00:33.574 (loader): remote cmd from 1440: "status"
    13:00:33.578 (loader): remote cmd from 1440: "status"
    13:00:33.628 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    13:00:33.629 (ports 5): remove: loc=usb:0/140000/0/1
    13:00:33.629 (ports 5): usb_remove: usb:0/140000/0/1
    13:00:33.629 (ports 5): nothing new, skipping HID & Ports enum
    13:00:33.651 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:00:33.651 (ports 5): nothing new, skipping HID & Ports enum
    13:00:33.651 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    13:00:33.652 (ports 5): nothing new, skipping HID & Ports enum
    13:00:33.682 (loader): remote cmd from 1440: "status"
    13:00:33.793 (loader): remote cmd from 1440: "status"
    13:00:33.874 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    13:00:33.875 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000cede2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:00:33.875 (ports 5): found_usb_device, loc=usb:0/140000/0/1    Port_#0001.Hub_#0002
    13:00:33.875 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0106
    13:00:33.875 (ports 5): found_usb_device, devinst=00000007
    13:00:33.875 (ports 5): add: loc=usb:0/140000/0/1, class=HID, vid=16C0, pid=0478, ver=0106, serial=000cede2, dev=\\?\usb#vid_16c0&pid_0478#000cede2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:00:33.875 (ports 5): hiddev_from_devinst_list: iface=0
    13:00:33.876 (ports 5): found_usb_device complete
    13:00:33.877 (ports 5): usb_add: usb:0/140000/0/1  [no_device] (Teensy MicroMod) Bootloader
    13:00:33.886 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:00:33.886 (ports 5): update_usb_device, devinst list change, old had 1, new has 2
    13:00:33.886 (ports 5): hiddev_from_devinst_list: iface=0
    13:00:33.887 (ports 5): hid, found devinst=0000000B
    13:00:33.887 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#6&156f921f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    13:00:33.887 (ports 5): hid,  opened handle
    13:00:33.887 (ports 5):  devinst=0000000B, location=usb:0/140000/0/1
    13:00:33.887 (ports 5):  vid=16C0, pid=0478, ver=0106, usepage=FF9C, use=0026
    13:00:33.887 (ports 5):  devpath=\\?\hid#vid_16c0&pid_0478#6&156f921f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    13:00:33.887 (ports 5): usb_add: usb:0/140000/0/1  hid#vid_16c0&pid_0478 (Teensy MicroMod) Bootloader
    13:00:33.906 (loader): Device came online, code_size = 16515072
    13:00:33.906 (loader): Board is: Teensy MicroMod (IMXRT1062), version 1.06
    13:00:33.921 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:00:33.921 (loader): set background IMG_ONLINE
    13:00:33.937 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:00:33.938 (loader): elf appears to be for Teensy MicroMod (IMXRT1062) (16515072 bytes)
    13:00:33.938 (loader): elf binary data matches hex file
    13:00:33.938 (loader): elf file is for Teensy MicroMod (IMXRT1062)
    13:00:33.938 (loader): begin operation
    13:00:33.949 (loader): remote cmd from 1440: "status"
    13:00:33.959 (loader): flash, block=0, bs=1024, auto=1
    13:00:33.959 (loader):  gauge old value = 0
    13:00:33.959 (loader): flash, block=1, bs=1024, auto=1
    13:00:34.109 (loader):  gauge old value = 1
    13:00:34.110 (loader): flash, block=2, bs=1024, auto=1
    13:00:44.128 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:00:44.128 (ports 5): nothing new, skipping HID & Ports enum
    13:01:04.154 (serialmon 16): Begin, version=1.54-beta7, high-res time
    13:01:04.154 (serialmon 16): listening for location: usb:0/140000/0/1
    13:01:04.154 (serialmon 16): LoadLibrary cfgmgr32 ok
    13:01:04.154 (serialmon 16): LoadLibrary ntdll ok
    13:01:04.158 (serialmon 16): callback 0024
    13:01:04.158 (serialmon 16): callback 0081
    13:01:04.159 (serialmon 16): callback 0083
    13:01:04.159 (serialmon 16): hWnd = 3412364
    13:01:04.160 (serialmon 16): loop stdin, ready=262143
    13:01:04.161 (serialmon 16): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000cede2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:01:04.161 (serialmon 16): found_usb_device, loc=usb:0/140000/0/1    Port_#0001.Hub_#0002
    13:01:04.161 (serialmon 16): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0106
    13:01:04.161 (serialmon 16): found_usb_device, devinst=00000008
    13:01:04.161 (serialmon 16): add: loc=usb:0/140000/0/1, class=HID, vid=16C0, pid=0478, ver=0106, serial=000cede2, dev=\\?\usb#vid_16c0&pid_0478#000cede2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:01:04.161 (serialmon 16): hiddev_from_devinst_list: iface=0
    13:01:04.163 (serialmon 16): found_usb_device complete
    13:01:04.163 (serialmon 16): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#1234560#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:01:04.163 (serialmon 16): found_usb_device, loc=usb:0/140000/0/6/4    Port_#0004.Hub_#0006
    13:01:04.163 (serialmon 16): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0280
    13:01:04.163 (serialmon 16): found_usb_device, devinst=00000009
    13:01:04.163 (serialmon 16): add: loc=usb:0/140000/0/6/4, class=USB, vid=16C0, pid=0483, ver=0280, serial=1234560, dev=\\?\usb#vid_16c0&pid_0483#1234560#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:01:04.163 (serialmon 16):   comport_from_devinst_list attempt
    13:01:04.163 (serialmon 16):   found Ports in classguid_list at index=1
    13:01:04.163 (serialmon 16):   port COM22 found from devnode
    13:01:04.163 (serialmon 16): hid, found devinst=0000000D
    13:01:04.163 (serialmon 16): usb_add: usb:0/140000/0/6/4
    13:01:04.337 (loader): program: write error
    13:01:04.337 (loader): HID/win32: HidD_GetPreparsedData ok, device still online :-)
    13:01:04.341 (loader): end operation, total time = 30.404 seconds
    13:01:04.343 (loader): set background IMG_DOWNLOAD_ERROR
    13:01:04.344 (loader): redraw timer set, image 11 to show for 4000 ms
    13:01:04.347 (loader): remote connection 1440 closed
    13:01:04.347 (loader): remote connection 756 closed
    13:01:04.347 (loader): remote connection 756 opened
    13:01:04.348 (serialmon 16): usb_add: usb:0/140000/0/1
    13:01:04.348 (serialmon 16): ignoring partial USB device discovery (Windows XP issue?)
    13:01:04.613 (serialmon 16): retry device discovery (Windows XP workaround)
    13:01:04.614 (serialmon 16): hid, found devinst=0000000D
    13:01:04.864 (serialmon 16): retry device discovery (Windows XP workaround)
    13:01:04.865 (serialmon 16): hid, found devinst=0000000D
    13:01:05.116 (serialmon 16): retry device discovery (Windows XP workaround)
    13:01:05.117 (serialmon 16): hid, found devinst=0000000D
    13:01:05.370 (serialmon 16): retry device discovery (Windows XP workaround)
    13:01:05.372 (serialmon 16): hid, found devinst=0000000D
    13:01:05.623 (serialmon 16): retry device discovery (Windows XP workaround)
    13:01:05.624 (serialmon 16): hid, found devinst=0000000D
    13:01:05.877 (serialmon 16): retry device discovery (Windows XP workaround)
    13:01:05.878 (serialmon 16): hid, found devinst=0000000D
    13:01:06.130 (serialmon 16): retry device discovery (Windows XP workaround)
    13:01:06.131 (serialmon 16): hid, found devinst=0000000D
    13:01:06.385 (serialmon 16): timeout
    13:01:06.386 (serialmon 16): hid, found devinst=0000000D
    13:01:08.354 (loader): redraw, image 10
    13:01:08.354 (loader): set background IMG_ONLINE
    13:01:11.015 (loader): Verbose Info event
  17. #67
    15,843
    @Paul :: Update to p#66 repro:
    IDE Ctrl+U began upload with TLoader and nothing ever appeared again in IDE console:
    Memory Usage on Teensy MicroMod:
      FLASH: code:74616, data:9528, headers:7212   free for files:16423716
       RAM1: code:98304 (69864 used), variables:21184   free for local variables:404800
       RAM2: variables:12384  free for malloc/new:511904
    Using library LittleFS at version 1.0.0 in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\LittleFS
    Using library SPI at version 1.0 in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SPI
    Using library SdFat at version 2.0.5-beta.1 in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat
    T:\arduino-1.8.13_t54\hardware\teensy/../tools/teensy_post_compile -file=LFSintegrity.ino -path=C:\Users\Tim\AppData\Local\Temp\arduino_build_76521 -tools=T:\arduino-1.8.13_t54\hardware\teensy/../tools -board=TEENSY_MICROMOD -reboot -port=usb:0/140000/0/1 -portlabel=hid#vid_16c0&pid_0478 Bootloader -portprotocol=Teensy
    <edit note>: Teensy loader auto UNCHECKED "AUTO" and is sitting at that place with the image of the MMod_Teensy on the program.
    >> Next Upload attempt works as expected
    TLoader went in to ERASE then 'failed program':
    13:05:40.630 (loader): remote connection 1548 closed
    13:05:44.113 (loader): file changed
    13:05:44.114 (post_compile 22): Begin, version=1.54-beta7, high-res time
    13:05:44.129 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:05:44.131 (loader): remote connection 1316 opened
    13:05:44.131 (post_compile 22): Sending command: comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_post_compile)
    13:05:44.136 (loader): remote cmd from 1316: "comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_post_compile)"
    13:05:44.137 (loader): remote cmd from 1316: "status"
    13:05:44.139 (loader): remote cmd from 1316: "dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\"
    13:05:44.139 (post_compile 22): Status: 1, 1, 0, 2, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\, LFSintegrity.ino.hex
    13:05:44.139 (post_compile 22): Sending command: dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\
    13:05:44.140 (loader): remote cmd from 1316: "file:LFSintegrity.ino.hex"
    13:05:44.140 (post_compile 22): Sending command: file:LFSintegrity.ino.hex
    13:05:44.155 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:05:44.161 (loader): remote cmd from 1316: "status"
    13:05:44.163 (post_compile 22): Status: 1, 1, 0, 2, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\, LFSintegrity.ino.hex
    13:05:44.163 (post_compile 22): Disconnect
    13:05:44.181 (loader): remote connection 1316 closed
    13:05:44.441 (post_compile 23): Begin, version=1.54-beta7, high-res time
    13:05:44.444 (loader): remote connection 1524 opened
    13:05:44.445 (post_compile 23): Sending command: comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_post_compile)
    13:05:44.445 (loader): remote cmd from 1524: "comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_post_compile)"
    13:05:44.446 (loader): remote cmd from 1524: "status"
    13:05:44.448 (loader): remote cmd from 1524: "dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\"
    13:05:44.449 (post_compile 23): Status: 1, 1, 0, 2, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\, LFSintegrity.ino.hex
    13:05:44.449 (post_compile 23): Sending command: dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\
    13:05:44.450 (loader): remote cmd from 1524: "file:LFSintegrity.ino.hex"
    13:05:44.450 (post_compile 23): Sending command: file:LFSintegrity.ino.hex
    13:05:44.466 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:05:44.475 (loader): remote cmd from 1524: "status"
    13:05:44.478 (post_compile 23): Status: 1, 1, 0, 2, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_76521\, LFSintegrity.ino.hex
    13:05:44.478 (post_compile 23): Disconnect
    13:05:44.496 (loader): remote connection 1524 closed
    13:05:44.496 (post_compile 24): Running teensy_reboot: "T:\arduino-1.8.13_t54\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY_MICROMOD" "-port=usb:0/140000/0/1" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
    13:05:44.498 (loader): remote connection 1524 opened
    13:05:44.519 (loader): remote connection 1404 opened
    13:05:44.521 (loader): remote cmd from 1404: "show:arduino_attempt_reboot"
    13:05:44.523 (loader): got request to show arduino rebooting message
    13:05:44.527 (loader): remote cmd from 1404: "comment: Teensyduino 1.54-beta7 - WINDOWS (teensy_reboot)"
    13:05:44.530 (loader): remote cmd from 1404: "status"
    13:05:44.555 (loader): remote cmd from 1404: "status"
    13:05:44.586 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    13:05:44.587 (ports 5): remove: loc=usb:0/140000/0/1
    13:05:44.587 (ports 5): usb_remove: usb:0/140000/0/1
    13:05:44.587 (ports 5): nothing new, skipping HID & Ports enum
    13:05:44.611 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:05:44.611 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    13:05:44.612 (ports 5): nothing new, skipping HID & Ports enum
    13:05:44.669 (loader): remote cmd from 1404: "status"
    13:05:44.779 (loader): remote cmd from 1404: "status"
    13:05:44.835 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    13:05:44.836 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000cede2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:05:44.836 (ports 5): found_usb_device, loc=usb:0/140000/0/1    Port_#0001.Hub_#0002
    13:05:44.836 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0106
    13:05:44.836 (ports 5): found_usb_device, devinst=00000007
    13:05:44.836 (ports 5): add: loc=usb:0/140000/0/1, class=HID, vid=16C0, pid=0478, ver=0106, serial=000cede2, dev=\\?\usb#vid_16c0&pid_0478#000cede2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:05:44.837 (ports 5): hiddev_from_devinst_list: iface=0
    13:05:44.837 (ports 5): found_usb_device complete
    13:05:44.838 (ports 5): usb_add: usb:0/140000/0/1  [no_device] (Teensy MicroMod) Bootloader
    13:05:44.847 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:05:44.847 (ports 5): update_usb_device, devinst list change, old had 1, new has 2
    13:05:44.847 (ports 5): hiddev_from_devinst_list: iface=0
    13:05:44.848 (ports 5): hid, found devinst=0000000B
    13:05:44.848 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#6&156f921f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    13:05:44.848 (ports 5): hid,  opened handle
    13:05:44.848 (ports 5):  devinst=0000000B, location=usb:0/140000/0/1
    13:05:44.848 (ports 5):  vid=16C0, pid=0478, ver=0106, usepage=FF9C, use=0026
    13:05:44.848 (ports 5):  devpath=\\?\hid#vid_16c0&pid_0478#6&156f921f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    13:05:44.848 (ports 5): usb_add: usb:0/140000/0/1  hid#vid_16c0&pid_0478 (Teensy MicroMod) Bootloader
    13:05:44.859 (loader): Device came online, code_size = 16515072
    13:05:44.863 (loader): Board is: Teensy MicroMod (IMXRT1062), version 1.06
    13:05:44.882 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:05:44.886 (loader): set background IMG_ONLINE
    13:05:44.906 (loader): File "LFSintegrity.ino.hex". 91360 bytes, 1% used
    13:05:44.911 (loader): elf appears to be for Teensy MicroMod (IMXRT1062) (16515072 bytes)
    13:05:44.914 (loader): elf binary data matches hex file
    13:05:44.918 (loader): elf file is for Teensy MicroMod (IMXRT1062)
    13:05:44.922 (loader): begin operation
    13:05:44.938 (loader): remote cmd from 1404: "status"
    13:05:44.953 (loader): flash, block=0, bs=1024, auto=1
    13:05:44.958 (loader):  gauge old value = 0
    13:05:44.963 (loader): flash, block=1, bs=1024, auto=1
    13:05:45.117 (loader):  gauge old value = 1
    13:05:45.122 (loader): remote cmd from 1404: "status"
    13:05:45.133 (loader): flash, block=2, bs=1024, auto=1
    13:05:50.163 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:05:50.164 (ports 5): nothing new, skipping HID & Ports enum
    13:06:15.331 (serialmon 26): Begin, version=1.54-beta7, high-res time
    13:06:15.331 (serialmon 26): listening for location: usb:0/140000/0/1
    13:06:15.331 (serialmon 26): LoadLibrary cfgmgr32 ok
    13:06:15.331 (serialmon 26): LoadLibrary ntdll ok
    13:06:15.334 (serialmon 26): callback 0024
    13:06:15.334 (serialmon 26): callback 0081
    13:06:15.335 (serialmon 26): callback 0083
    13:06:15.336 (serialmon 26): hWnd = 5509874
    13:06:15.336 (serialmon 26): loop stdin, ready=262143
    13:06:15.337 (serialmon 26): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000cede2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:06:15.337 (serialmon 26): found_usb_device, loc=usb:0/140000/0/1    Port_#0001.Hub_#0002
    13:06:15.337 (serialmon 26): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0106
    13:06:15.337 (serialmon 26): found_usb_device, devinst=00000008
    13:06:15.337 (serialmon 26): add: loc=usb:0/140000/0/1, class=HID, vid=16C0, pid=0478, ver=0106, serial=000cede2, dev=\\?\usb#vid_16c0&pid_0478#000cede2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:06:15.337 (serialmon 26): hiddev_from_devinst_list: iface=0
    13:06:15.339 (serialmon 26): found_usb_device complete
    13:06:15.339 (serialmon 26): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#1234560#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:06:15.339 (serialmon 26): found_usb_device, loc=usb:0/140000/0/6/4    Port_#0004.Hub_#0006
    13:06:15.339 (serialmon 26): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0280
    13:06:15.339 (serialmon 26): found_usb_device, devinst=00000009
    13:06:15.339 (serialmon 26): add: loc=usb:0/140000/0/6/4, class=USB, vid=16C0, pid=0483, ver=0280, serial=1234560, dev=\\?\usb#vid_16c0&pid_0483#1234560#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:06:15.339 (serialmon 26):   comport_from_devinst_list attempt
    13:06:15.339 (serialmon 26):   found Ports in classguid_list at index=1
    13:06:15.339 (serialmon 26):   port COM22 found from devnode
    13:06:15.340 (serialmon 26): hid, found devinst=0000000D
    13:06:15.340 (serialmon 26): usb_add: usb:0/140000/0/6/4
    13:06:15.357 (loader): program: write error
    13:06:15.359 (loader): HID/win32: HidD_GetPreparsedData ok, device still online :-)
    13:06:15.366 (loader): end operation, total time = 30.439 seconds
    13:06:15.370 (loader): set background IMG_DOWNLOAD_ERROR
    13:06:15.373 (loader): redraw timer set, image 11 to show for 4000 ms
    13:06:15.384 (loader): remote connection 1404 closed
    13:06:15.384 (loader): remote connection 1524 closed
    13:06:15.384 (loader): remote connection 1524 opened
    13:06:15.385 (serialmon 26): usb_add: usb:0/140000/0/1
    13:06:15.385 (serialmon 26): ignoring partial USB device discovery (Windows XP issue?)
    13:06:15.635 (serialmon 26): retry device discovery (Windows XP workaround)
    13:06:15.636 (serialmon 26): hid, found devinst=0000000D
    13:06:15.888 (serialmon 26): retry device discovery (Windows XP workaround)
    13:06:15.889 (serialmon 26): hid, found devinst=0000000D
    13:06:16.139 (serialmon 26): retry device discovery (Windows XP workaround)
    13:06:16.141 (serialmon 26): hid, found devinst=0000000D
    13:06:16.393 (serialmon 26): retry device discovery (Windows XP workaround)
    13:06:16.394 (serialmon 26): hid, found devinst=0000000D
    13:06:16.646 (serialmon 26): retry device discovery (Windows XP workaround)
    13:06:16.647 (serialmon 26): hid, found devinst=0000000D
    13:06:16.899 (serialmon 26): retry device discovery (Windows XP workaround)
    13:06:16.900 (serialmon 26): hid, found devinst=0000000D
    13:06:17.153 (serialmon 26): retry device discovery (Windows XP workaround)
    13:06:17.154 (serialmon 26): hid, found devinst=0000000D
    13:06:17.405 (serialmon 26): timeout
    13:06:17.406 (serialmon 26): hid, found devinst=0000000D
    13:06:19.385 (loader): redraw, image 10
    13:06:19.391 (loader): set background IMG_ONLINE
  18. #68
    15,843
    Usage:
    Pulled that library and not seeing it work in IDE with p#64 sketch?
    Getting various moving errors with attempts to fix
    Invalid library found in T:\tCode\libraries\TeensyHelpers: no headers files (.h) found in T:\tCode\libraries\TeensyHelpers
    Perhaps do a Verify build in IDE to see what it needs?
    That header path is not discovered within lib/src folder by IDE it seems?
    And making a local sketch folder with those files shows not looking for library:
    MMhelpLuni:6: error: 'MM32' does not name a type
    MMhelpLuni: In function 'void setup()':
    MMhelpLuni:14: error: 'bus' was not declared in this scope
    MMhelpLuni:18: warning: unused variable 'val'
    <EDIT> - Just noticed this compiling another unrelated sketch the IDE shows:
  19. #69
    New York
    8,117
    @defragster = @KurtE
    Well I did purchase a USB-C cable from Sparkfun but it was the wrong one, didn't look close enough. It was a USBC to USBC cable Any got one now Blink loaded and ran no problem now for the I2C test.
  20. #70
    15,843
    As noted - they are a challenge ... the ~10 I bought are various end configs and lengths. Between device and computer or charger they are all a mix. Nice havin one on a new computer - but only one means still need old style - but half of new chargers are USB-C now ... wireless or wallwart
  21. #71
    New York
    8,117
    Ok ran the following test on I2C QWIIC connectors and a Sparkfun QWIIC Keypad:
    1. SDA - Wire
    Qwiic KeyPad Example
    Initialized. Firmware Version: v1.0
    Press a button: * to do a space. # to go to next line.
         88888888880009632147 0854
    012456789 777775555 00008888555
    All good. Keypad found and operational
    2. SDA1 - Wire1 (keypad1.begin(Wire1))
    Keypad does not appear to be connected. Please check wiring. Freezing...]
    No good not recognized so SDA1 not equivalent to Wire1.
    3. SDA1 - Wire2 (keypad1.begin(Wire2))
    00088855522233366699
    99552211
    9966555 88855223366997744331
    So SDA1 = Wire2. So do we change this?
    Ok - have to test the rest later when I find the rest of my QWIIC stuff.
  22. #72
    New York
    8,117
    @defragster - @Paul
    Just ran LFSIntegrity as well on DMAMEM ramdisk and its failing:
    :: /6_dir/O_file.txt  RAM_DISK +++ Add [sz 8192 add 8192] @KB/sec 2232.15 {1618.65}  ++ O   Verify /6_dir/O_file.txt 16384B  @KB/sec 2481.67
    :: /6_dir/P_file.txt  RAM_DISK +++ Add [sz 8704 add 8704] @KB/sec 2286.31 {1670.31}  ++ P   Verify /6_dir/P_file.txt 17408B  @KB/sec 2488.99
    :: /6_dir/Q_file.txt  RAM_DISK +++ Add [sz 9216 add 9216] @KB/sec 2280.62 {1684.83}  ++ Q   Verify /6_dir/Q_file.txt 18432B  @KB/sec 2492.83
    :: /6_dir/R_file.txt  RAM_DISK +++ Add [sz 9728 add 9728] @KB/sec 2280.89 {1704.87}  ++ R   Verify /6_dir/R_file.txt 19456B  @KB/sec 2497.88
    :: /6_dir/S_file.txt  RAM_DISK +++ Add [sz 10240 add 3677] @KB/sec 342.08 {301.00}
    	write fail ERR# -28 0xFFFFFFE4
    0[  3.05 M](0.01925 M elap) Awaiting input 0123456789RdwcghkFqvplmusSBbyYxfan+-? loops left 0
    but I think more importantly if I run littlefs_teensy_test1a and try to access the W25Q128 flash it fails to start it hangs at
    myfs.begin()
    EDIT: SPIFlash not working either for the W25Q128
  23. #73
    10,316
    Been there, done that (Again) I thought I had it handled as my two Ipads use the USB-c, but they have it for both ends... So I now have an Amazon Basic...
    Sorry I have not been to town to pick it up, so playing with MTP/MSC trying to get date times... But that is a story for different thread.
  24. #74
    15,843
    @defragster - @Paul
    I just confirmed github.com/PaulStoffregen/LittleFS - has the WIPE 'w' command that was the last added AFAIK ... a month back.
    @mjs513 - assume you are current? Only fail on RAM?
    @Paul _ trying to switch to RAM - the PROG LFS drive worked fine - again 'Program Error' on initial upload when 15MB needed formatting.
    Odd RAM failing? Works here? Seems that is "DISK FULL" ERROR.
    Check for "#define ROOTONLY " and these lines:
    #define SUBADD 10	// bytes added each pass (*times file number)
    #define BIGADD 400 // 1024	// bytes added each pass - bigger will quickly consume more space
  25. #75
    New York
    8,117
    @defragster
    No PSRAM on MicroMod- try switching to DMAMEM. Ran into that as well.
    Still can figure out why QSPI Flash isn't working - I can't mess the wiring up on that one.
    OK got SPIFlash working - had wiring backwards.
    MISO is COPI (12)
    MOSI is CIPO (11)
    LittleFS Test
    flash begin
    Flash ID: EF 40 18  80
    Flash size is 16.00 Mbyte
    attempting to mount existing media
    success
    TotalSize (Bytes): 16777216
    started
    MAKE files
    printDirectory
    FILE	bigfile.txt  		616448
    FILE	mtpindex.dat		0
    DIR	structureData1 /
    	FILE	temp_test.txt		19
     0 dirs with 1 files of Size 19 Bytes
    FILE	temp_test1.txt		19
    FILE	temp_test2.txt		19
    FILE	temp_test3.txt		1024
    FILE	workshop.pdf		8894873
     1 dirs with 6 files of Size 9512383 Bytes
    printDirectory
    FILE	mtpindex.dat		0
    	FILE	temp_test.txt		38
     0 dirs with 1 files of Size 38 Bytes
    FILE	temp_test1.txt		38
    FILE	temp_test2.txt		38
    FILE	temp_test3.txt		2048
     1 dirs with 6 files of Size 9513445 Bytes
    Disk Usuage:
    Bytes Used: 9551872, Bytes Total:16777216
    Test for SOME DATA TO TEST
