It is possible that there are some problems with my excel document, that was mentioned... although not sure if there is, on which page?
Pin MM Pin Name GPIO Serial I2C SPI PWM CAN Audio XBAR FlexIO Analog SD/CSI/LCD
0 19 AD_B0_03 1.3 Serial1(6) RX SPI1(3) CS0 PWM1_X1 2_RX IO-17
1 17 AD_B0_02 1.2 Serial1(6) TX SPI1(3) MISO PWM1_X0 2_TX IO-16
2 47 EMC_04 4.4 PWM4_A2 2:TX_DATA IO-06 1:4
3 32 EMC_05 4.5 PWM4_B2 2:TX_SYNC IO-07 1:5
4 10 EMC_06 4.6 PWM2_A0 2:TX_BCLK IO-08 1:6
5 18 EMC_08 4.8 PWM2_A1 2:RX_DATA IO-17 1:8
6 71 B0_10 2.10 PWM2_A2, QT4_1 1:TX3_RX1 2:10 LCD_DATA6
7 56 B1_01 2.17 Serial4(4) RX PWM1_B3 1:TX_DATA IO-15 2:17, 3:17
8 54 B1_00 2.16 Serial4(4) TX PWM1_A3 1:RX_DATA IO-14 2:16, 3:16
9 69 B0_11 2.11 PWM2_B2,QT4_2 1:TX2_RX2 2:11 LCD_DATA7
10 55 B0_00 2.0 SPI(4) CS0 QT1_0 MQS_RIGHT 2:0 LCD_CLK
11 59 B0_02 2.2 SPI(4) MOSI QT1_2 1_TX 2:2 LCD_HSYNC
12 61 B0_01 2.1 SPI(4) MISO QT1_1 MQS_LEFT 2:1 LCD_ENABLE
13 57 B0_03 2.3 SPI(4) SCK QT2_0 1_RX 2:3 LCD_VSYNC
14/A0 34 AD_B1_02 1.18 Serial3(2) TX QT3_2 SPDIF_OUT 3:2 A1:7, A2:7
15/A1 38 AD_B1_03 1.19 Serial3(2) RX QT3_3 SPDIF_IN 3:3 A1:8, A2:8
16/A2 20 AD_B1_07 1.23 Serial2(3) RX Wire2(3) SCL SPDIF_EXTCLK 3:7 A1:12, A2:12 USDHC2_DATA3
17/A3 22 AD_B1_06 1.22 Serial2(3) TX Wire2(3) SDA SPDIF_LOCK 3:6 A1:11, A2:11 USDHC2_DATA2
18/A4 12 AD_B1_01 1.17 Serial3(2) RTS Wire(1) SDA QT3_1 3:1 A1:6, A2:6
19/A5 14 AD_B1_00 1.16 Serial3(2) CTS Wire(1) SCL QT3_0 3:0 A1:5, A2:5
20/A6 52 AD_B1_10 1.26 Serial5(8) TX 1:RX_SYNC 3:10 A1:15, A2:15
21/A7 50 AD_B1_11 1.27 Serial5(8) RX 1:RX_BCLK 3:11 A1:0, A2:0
22/A8 49 AD_B1_08 1.24 PWM4_A0 1_TX 3:8 A1:13, A2:13 USDHC2_CMD
23/A9 58 AD_B1_09 1.25 PWM4_A1 1_RX 1:MCLK 3:9 A1:14, A2:14 USDHC2_CLK
24/A10 53 AD_B0_12 1.12 Serial6(1) TX Wire1(4) SCL PWM1_X2 A1:1
25/A11 51 AD_B0_13 1.13 Serial6(1) RX Wire1(4) SDA PWM1_X3 GPT1_CLK A1:2
26/A12 67 AD_B1_14 1.30 SPI1(3) MOSI 1:TX_BCLK 3:14 A2:3
27/A13 8 AD_B1_15 1.31 SPI1(3) SCK 1:TX_SYNC 3:15 A2:4
28 4 EMC_32 3.18 Serial7(7) RX PWM3_B1
29 16 EMC_31 4.31 Serial7(7) TX SPI2(1) CS1 PWM3_A1
30 41 EMC_37 3.23 GPT1_3 3_RX 3:MCLK IO-23
31 43 EMC_36 3.22 GPT1_2 3_TX 3:TX_DATA IO-22
32 65 B0_12 2.12 1:TX1_RX3 IO-10 2:12 LCD_DATA8
33 63 EMC_07 4.7 PWM2_B0 2:MCLK IO-09 1:7
SD Pins - Cable connector(T4 34-39)
34 66 SD_B0_03 3.15 Serial5(8) RTS SPI2(1) MISO PWM1_B1 IO-07 DATA1
35 64 SD_B0_02 3.14 Serial5(8) CTS SPI2(1) MOSI PWM1_A1 IO-06 DATA0
36 60 SD_B0_01 3.13 Wire2(3) SDA SPI2(1) CS0 PWM1_B0 IO-05 CLK
37 62 SD_B0_00 3.12 Wire2(3) SCL SPI2(1) SCK PWM1_A0 IO-04 CMD
38 68 SD_B0_04 3.16 Serial5(8) TX FLEXSPI B_SSO_B PWM1_A2 IO-08 DATA2
39 70 SD_B0_05 3.17 Serial5(8) RX FLEXSPI B_DQS PWM1_B2 IO-09 DATA3
Micromod new pins
40 40 B0_04 2:04 Wire3(2) SCL QT2_1 2:4 LCD_DATA0
41 42 B0_05 2:05 Wire3(2) SDA QT2_2 2:5 LCD_DATA1
42 44 B0_06 2:06 QT3_0 2:6 LCD_DATA2
43 46 B0_07 2:07 QT3_1 2:7 LCD_DATA3
44 48 B0_08 2:08 QT3_2 2:8 LCD_DATA4
45 73 B0_09 2:09 QT4_0 2:9 LCD_DATA5
