MicroMod Beta Testing
I have no MM, and can't test anything, but it think it's fixed. If not.. well, then not.
Note, from now on, I don't support this lib anymore. You can still download or use it - but very likely there will be no updates anymore.
This basic functionality has to be in the core. Not in a lib. Have no idea why it is *still* not in the core.
I'll archive the repo.
Thanks Paul,
Should arrive here later this week :D
In the Mean time I have updated my Teensy 4 excel document up on github with more MicroMod pages/updates.
https://github.com/KurtE/TeensyDocuments/blob/master/Teensy4 Pins.xlsx
Hi, i have connected a wiznet w5500 to SPI1(3) but having problems communicating, is there a chance CS0 and MISO are swapped in your document?
MM pins 17, 19, or Teensy pins 0, 1
is there a chance CS0 and MISO are swapped in your diagram?
Yup, looks like those SPI functions may be mis-labled. The pin with Serial1 transmit has MISO as an alternate peripheral function.
Looking at pin 17:
MicroMod M.2 pin 17
Teensy pin 1
NXP pin AD_B0_02
peripherals (Teensy pinout card): TX1, MISO1, CTX2, PWM
AD_B0_02 mux documentation from the NXP reference manual (pages 471-472):
Where is this particular schematic located? The schematic of Sparkfun's website doesn't show those SPI names.
Was just about to ask the same question - went searching the Sparkfun site and looking at the schematic in post 1 and haven't been able to find that schematic. Also not sure what carrier board you are using but on the ATP carrier board I have been using this, if it helps:
It is possible that there are some problems with my excel document, that was mentioned... although not sure if there is, on which page?
Pin	MM Pin	Name	GPIO	Serial	I2C	SPI	PWM	CAN	Audio	XBAR	FlexIO	Analog	SD/CSI/LCD
 0	19	AD_B0_03	1.3	Serial1(6) RX		SPI1(3) CS0	PWM1_X1	2_RX		IO-17
 1	17	AD_B0_02	1.2	Serial1(6) TX		SPI1(3) MISO	PWM1_X0	2_TX		IO-16
 2	47	EMC_04	4.4				PWM4_A2		2:TX_DATA	IO-06	1:4
 3	32	EMC_05	4.5				PWM4_B2		2:TX_SYNC	IO-07	1:5
 4	10	EMC_06	4.6				PWM2_A0		2:TX_BCLK	IO-08	1:6
5	18	EMC_08	4.8				PWM2_A1		2:RX_DATA	IO-17	1:8
6	71	B0_10	2.10				PWM2_A2, QT4_1		1:TX3_RX1		2:10		LCD_DATA6
7	56	B1_01	2.17	Serial4(4) RX			PWM1_B3		1:TX_DATA	IO-15	2:17, 3:17
8	54	B1_00	2.16	Serial4(4) TX			PWM1_A3		1:RX_DATA	IO-14	2:16, 3:16
 9	69	B0_11	2.11				PWM2_B2,QT4_2		1:TX2_RX2		2:11		LCD_DATA7
10	55	B0_00	2.0			SPI(4) CS0	QT1_0		MQS_RIGHT		2:0     		LCD_CLK
11	59	B0_02	2.2			SPI(4) MOSI	QT1_2	1_TX			2:2		LCD_HSYNC
12	61	B0_01	2.1			SPI(4) MISO	QT1_1		MQS_LEFT		2:1     		LCD_ENABLE
13	57	B0_03	2.3			SPI(4) SCK	QT2_0	1_RX			2:3		LCD_VSYNC
14/A0	34	AD_B1_02	1.18	Serial3(2) TX			QT3_2		SPDIF_OUT		3:2	A1:7, A2:7
15/A1	38	AD_B1_03	1.19	Serial3(2) RX			QT3_3		SPDIF_IN		3:3	A1:8, A2:8
16/A2	20	AD_B1_07	1.23	Serial2(3) RX	Wire2(3) SCL				SPDIF_EXTCLK		3:7	A1:12, A2:12	USDHC2_DATA3
17/A3	22	AD_B1_06	1.22	Serial2(3) TX	Wire2(3) SDA				SPDIF_LOCK		3:6	A1:11, A2:11	USDHC2_DATA2
18/A4	12	AD_B1_01	1.17	Serial3(2) RTS	Wire(1) SDA		QT3_1				3:1	A1:6, A2:6
19/A5	14	AD_B1_00	1.16	Serial3(2) CTS	Wire(1) SCL		QT3_0				3:0	A1:5, A2:5
20/A6	52	AD_B1_10	1.26	Serial5(8) TX					1:RX_SYNC		3:10	A1:15, A2:15
21/A7	50	AD_B1_11	1.27	Serial5(8) RX					1:RX_BCLK		3:11	A1:0, A2:0
22/A8	49	AD_B1_08	1.24				PWM4_A0	1_TX			3:8	A1:13, A2:13	USDHC2_CMD
23/A9	58	AD_B1_09	1.25				PWM4_A1	1_RX	1:MCLK		3:9	A1:14, A2:14	USDHC2_CLK
24/A10	53	AD_B0_12	1.12	Serial6(1) TX	Wire1(4) SCL		PWM1_X2					A1:1
25/A11	51	AD_B0_13	1.13	Serial6(1) RX	Wire1(4) SDA		PWM1_X3	GPT1_CLK				A1:2
26/A12	67	AD_B1_14	1.30			SPI1(3) MOSI			1:TX_BCLK		3:14	A2:3
27/A13	8	AD_B1_15	1.31			SPI1(3) SCK			1:TX_SYNC		3:15	A2:4
28	4	EMC_32	3.18	Serial7(7) RX			PWM3_B1
29	16	EMC_31	4.31	Serial7(7) TX		SPI2(1) CS1	PWM3_A1
30	41	EMC_37	3.23				GPT1_3 	3_RX	3:MCLK	IO-23
31	43	EMC_36	3.22				GPT1_2	3_TX	3:TX_DATA	IO-22
32	65	B0_12	2.12						1:TX1_RX3	IO-10	2:12		LCD_DATA8
33	63	EMC_07	4.7				PWM2_B0		2:MCLK	IO-09	1:7
SD Pins - Cable connector(T4 34-39)
34	66	SD_B0_03	3.15	Serial5(8) RTS		SPI2(1) MISO	PWM1_B1			IO-07			DATA1
35	64	SD_B0_02	3.14	Serial5(8) CTS		SPI2(1) MOSI	PWM1_A1			IO-06			DATA0
36	60	SD_B0_01	3.13		Wire2(3) SDA	SPI2(1) CS0	PWM1_B0			IO-05			CLK
37	62	SD_B0_00	3.12		Wire2(3) SCL	SPI2(1) SCK	PWM1_A0			IO-04			CMD
38	68	SD_B0_04	3.16	Serial5(8) TX		FLEXSPI B_SSO_B	PWM1_A2			IO-08			DATA2
39	70	SD_B0_05	3.17	Serial5(8) RX		FLEXSPI B_DQS	PWM1_B2			IO-09			DATA3
Micromod new pins
40	40	B0_04	2:04		Wire3(2) SCL		QT2_1				2:4		LCD_DATA0
41	42	B0_05	2:05		Wire3(2) SDA		QT2_2				2:5		LCD_DATA1
42	44	B0_06	2:06				QT3_0				2:6		LCD_DATA2
43	46	B0_07	2:07				QT3_1				2:7		LCD_DATA3
44	48	B0_08	2:08				QT3_2				2:8		LCD_DATA4
45	73	B0_09	2:09				QT4_0				2:9		LCD_DATA5
Not sure if I understand you correctly. But as it seems, pin 0 and 1 (top two rows). CS0 and MISO should be swapped.
i guess something on those two lines are wrong
Might help to know what is wrong on these two lines:
Pin 0 (MMOD pin 17) is CS0 on SPI1 and (not the is not CS on the SPI object) - I am trying to show which CS of the SPI...
Pin 1 (MMOD pin 19) is the MISO on SPI1... I think...
At least from Paul's stuff above:
Looking at pin 17:
MicroMod M.2 pin 17
Teensy pin 1
NXP pin AD_B0_02
the problem is just that the MM pin numbers are swapped?
Pin.........MM Pin
0...........19(should be 17?)
1...........17(should be 19?)
Pin.........MM Pin
I don't believe so... Could be wrong.
My own test board has:
And while it has other problems, HI/LOW test of ringing out the IO pins appears to work fine...
And likewise if you look at the sparkfun STP board schematic you see:
These 2 numbers might be swapped, but the rest of the info looks correct.
Pin 0 really is AD_B0_03 with Serial1 RX and CAN2 RX and SPI1 CS. But it's connected to M.2 pin #19.
Likewise, pin 1 really is AD_B0_02 with Serial1 TX and CAN2 TX and SPI1 MISO. But it connects to M.2 pin #17.
From Sparkfun's schematic
and
Pin 0 really is AD_B0_03 with Serial1 RX and CAN2 RX. But it's on M.2 pin #19.
Likewise, pin 1 really is AD_B0_02 with Serial1 TX and CAN2 TX. Bit it's on M.2 pin #17.
and
ye, that's what i am trying to say, not complaining, KurtE's documents have been a great help when designing my carrier board.
But this is the reason i should have tried on the bench before makings pcbs!
Pin 0 really is AD_B0_03 with Serial1 RX and CAN2 RX. But it's connected to M.2 pin #19.
Likewise, pin 1 really is AD_B0_02 with Serial1 TX and CAN2 TX. But it connects to M.2 pin #17.
and
Thanks Paul, I think the issue is, that everyone is looking at an earlier version...
I updated the excel document back in July... Maybe I need to update any pictures as well...
Updated the PDF file as well.
Here is a saved image from the pdf:
Sorry about the confusion...
Tried again and got the right info this time. :)
Not sure exactly what I did before. I think I probably clicked the link on msg #980 or #981, but not sure now.
@KurtE Let me take this opportunity to thank you for those files. I use them when I develop on the Micromod. Appreciate it!
@KurtE i also wanna thank you for sharing those files, and sorry for me confusing everything. glad we sorted it out!
Happy new year!
For the heck of it, I updated my MMOD test kitchen sink board and added a few things... As I don't dare waste a square inch of space...
Ordering from PCBWay with partial assembly... This time most all of the SMD...
Includes:
breakout of all of the pins by Teensy number
USB Host
SDIO
DXL Servo support
Simple Audio, mostly for beeps
A t3.2/T4 like connector, to allow plugging in things, like Audio board, or Memory test board, LED board...
And probably > 10 problems :lol:
Anyway should be fun.
I'm going to take the plunge and start migrating a T3.6 based system to Teensy Micromod so I'll be designing a board with the M.2 connector.
Does anyone have a Kicad footprint and symbol already made for the Teensy micromod connector? I've done some searching and no luck. I can make them myself, but I expect they're out there somewhere.
thx, Doug
