Hi there, this is my first post, so I apologize if I am a little green with all of this. I have been attempting to make a toy for my son that uses the Teensy 3.2 and audio shield along with a USB game controller that I have wired each button to individual pins for the Teensy to read. The concept is that each button on the controller triggers a wav file that I can customize. Right now, I am attempting to make it so that you can trigger music to play using playSDWav2. While the music is playing, you can trigger all of the sound effects with the other buttons using playSDWav1 simultaneously (going through a mixer to combine them). All of the output comes out of an 8ohm, .25w speaker that is connected to a PAM8302 amplifier. I am also using a Mac with the Teensyduino application and Teensy Loader to upload the code onto my Teensy.
Right now, everything is working as intended with the exception of a fatal crash that results in a loud buzzing noise. The buzzing noise seems to occur more frequently when two files are being played at once (usually when the background music is playing and the sound effect is being pressed in rapid succession), however it will also happen when a single wav file is being played as well (although less frequently). I found a thread where someone had a similar issue and suggested using an experimental SD library optimization by changing the SD_t3.h file, which I tried. It seems the problem is still persisting and I am not sure why.
I have noticed that specific files tend to trigger the crash more than others (the a button and left button are more consistently creating the buzzing crash), but I am not sure if it is related to my code or possibly the wav files themselves. I am also wondering if I am maybe just simply pushing the Teensy too hard with what I am trying to do. Any help would be greatly appreciated! Here is my complete code:
#include <Bounce.h>
//documentation for these libraries are found here: https://www.pjrc.com/teensy/gui/?info=AudioPlaySdWav
AudioPlaySdWav playSdWav2; //xy=291,430
AudioPlaySdWav playSdWav1; //xy=296,301
AudioMixer4 mixer1; //xy=563,363
AudioOutputI2S i2s1; //xy=780,362
AudioConnection patchCord1(playSdWav2, 0, mixer1, 1);
AudioConnection patchCord2(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord3(mixer1, 0, i2s1, 0);
AudioConnection patchCord4(mixer1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=64.5,50
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
//int buttonPins[] = {0,1,2,3,4,5,8,15,16,17,20,21};
Bounce buttonA = Bounce(0, 10);
Bounce buttonB = Bounce(1, 10);
Bounce buttonY = Bounce(2, 10);
Bounce buttonX = Bounce(3, 10);
Bounce buttonR = Bounce(4, 10);
Bounce buttonL = Bounce(5, 10);
Bounce buttonStart = Bounce(8, 10);
Bounce buttonUp = Bounce(15, 10);
Bounce buttonRight = Bounce(16, 10);
Bounce buttonDown = Bounce(17, 10);
Bounce buttonLeft = Bounce(20, 10);
Bounce buttonSelect = Bounce(21, 10);
//used for shorthand when checking if select button is being held
int selectPin = 21;
//used to determine whether the drum machine hihat is being looped or not in the drum state
bool loopOn = false;
//used to determine if the game state or drum state is active (inputting the Konami code will activate the drums tate)
bool gameState = true;
//sets the initial volume
float vol = 0.9;
//used to change volume by an increment set as num
void changeVolume(float num) {
vol = vol + num;
mixer1.gain(0, vol);
mixer1.gain(1, vol);
mixer1.gain(2, vol);
mixer1.gain(3, vol);
Serial.println(vol);
//tempo for the looped hihat in the drum state
int tempo = 200;
//array to hold file folder extensions for drum preset folders
char drumPresets[40][32];
//array to hold file folder extensions for game preset folders
char gamePresets[40][32];
//used to hold the number of drum and game presets to be used when switching presets
int numberOfDrums = 0;
int numberOfGames = 0;
//used to hold the number of background music files to be able to generate a random number that would pick a bgr file at random
//stores the number of BGR files in the same index corresponding to the index of the preset in gamePresets
//(therefore being able to be called using the same reference index stored in currentIndex
int numberOfBgr[40];
//variable used to determine which preset is currently active in the drum or game arrays, depending on whther or not the drum or game state is active
int currentIndex = 0;
//used to point to the string stored in the game or drum state arrays that will be used as the current folder extension acting as the current preset
const char *currentPreset;
//function to combine the current preset string (or preset folder) and the button pressed. \
//Concatenate file extension (variable named "combined") will look something like this: "_GAMES/MARIO/A/COIN.WAV"
void playFile(const char *input) {
char combined[32] = {0};
Serial.println(input);
strcpy(combined, currentPreset);
strcat(combined, "/");
strcat(combined, input);
//combined now looks like "_GAMES/MARIO/A" if input is "A."
//SD.open will then find the first file in the "A" folder and the name of this file will be concatenated onto combined variable
File folder = SD.open(combined);
File sound = folder.openNextFile();
if (!sound) {
Serial.println("no file to play");
return;
strcat(combined, sound.name());
Serial.println("combined: ");
Serial.println(combined);
//play the file
playSdWav1.play(combined);
int getRandomNumber(int maximum) {
srand((unsigned)millis());
return rand() % maximum;
//function to play a background music file from the "BGR" folder in the current preset folder
void playRandomBgr() {
Serial.println("\ntrying to play bgr");
strcat(combined, "/bgr");
File directory = SD.open(combined);
if (!numberOfBgr[currentIndex]){return;}
int bgrSize = numberOfBgr[currentIndex];
int randIndex = getRandomNumber(bgrSize) + 1;
Serial.println("random index = ");
Serial.print(randIndex);
Serial.print("\n\n");
for (int i = 1; i <= randIndex; i++) {
File entry = directory.openNextFile();
if (i == randIndex) {
strcat(combined, entry.name());
if (!entry) {
Serial.println("**no bgr to play**");
return;
Serial.println("trying to play ");
Serial.print(combined);
if (!SD.exists(combined)){
return;
playSdWav2.play(combined);
//the following code allows the Konami Code to be inputted for the purpose of switching from the game state to the drum state
char konamiCode[11][9] = {"Up", "Up", "Down", "Down", "Left", "Right", "Left", "Right", "B", "A", "Start"};
int konamiCodePlace = 0;
bool konamiCodeCheck(const char *input) {
//what to do if the last input of the konami code is pressed
if (!strcmp(konamiCode[konamiCodePlace], input)){
if (konamiCodePlace == 10) {
playSdWav2.stop();
Serial.println("***You did the konami code!***");
gameState = !gameState;
//will need to change so that you can get out of drumPresets if done a second time
currentPreset = drumPresets[0];
Serial.print(currentPreset);
}else{
//what to do if any other Konami code input is correctly pressed
konamiCodePlace++;
return true;
}else{
//what to do if Konami code input is not pressed
return false;
//files should be arranged in the following manner:
// _GAMES (or _DRUMS if a drum preset
// MARIO
// A
// COIN.WAV
// B
// JUMP.WAV
// X
// FIREBALL.WAV
// Y
// BLOCK.WAV
// L
// 1UP.WAV
// R
// POWERUP.WAV
// UP
// VINE.WAV
// DOWN
// PIPE.WAV
// LEFT
// BUMP.WAV
// RIGHT
// DEATH.WAV
// BGR (will not be present in a drum preset)
// OVERWRLD.WAV
// UNDRWRLD.WAV
// CASTLE.WAV
// WATER.WAV
//used to scan the SD card to populate preset arrays
void scanBgr(const char *folderName, int index) {
strcpy(combined, folderName);
File bgrDir = SD.open(combined);
Serial.print("\ntrying to scan ");
Serial.print(" for bgr and length is ");
int bgrInDir = 0;
while (true) {
File bgr = bgrDir.openNextFile();
if (bgr) {
bgrInDir++;
}else{
bgrDir.rewindDirectory();
numberOfBgr[index] = bgrInDir;
Serial.println(numberOfBgr[index]);
void scanFolder(const char *folderName, bool isGame) {
Serial.println("scanning folders");
File directory = SD.open(folderName);
int index = 0;
while (true) {
if (entry) {
if (isGame) {
scanBgr(combined, index);
strcpy(gamePresets[index], combined);
Serial.println(gamePresets[0]);
Serial.println(gamePresets[1]);
Serial.println(gamePresets[2]);
Serial.println(gamePresets[3]);
Serial.println("\n\n\n\n\n");
numberOfGames++;
}else{
//Serial.println(index);
strcpy(drumPresets[index], combined);
Serial.println(drumPresets[index]);
numberOfDrums++;
index++;
}else{
Serial.println("done with");
Serial.println(folderName);
directory.rewindDirectory();
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(15, INPUT_PULLUP);
pinMode(16, INPUT_PULLUP);
pinMode(17, INPUT_PULLUP);
pinMode(20, INPUT_PULLUP);
pinMode(21, INPUT_PULLUP);
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
scanFolder("_GAMES",true);
scanFolder("_DRUMS",false);
//drumPresets[0] = "_DRUMS/postal";
//gamePresets[0] = "_GAMES/megaman";
//gamePresets[1] = "_GAMES/smb";
//gamePresets[2] = "_GAMES/loz";
//gamePresets[3] = "_GAMES/sonic";
//currentIndex = 0;
//currentPreset = gamePresets[currentIndex];
currentPreset = gamePresets[getRandomNumber(numberOfGames)];
//going to loop hihat in the delay of the tempo
if (!gameState){
if (loopOn == true) {
//too loud
playFile("Y");
delay(tempo);
//what to do for each button press
if (buttonA.update()){
if (buttonA.fallingEdge()){
Serial.print("a");
playFile("A");
konamiCodeCheck("A");
if (buttonB.update()){
if (buttonB.fallingEdge()){
playFile("B");
konamiCodeCheck("B");
if (buttonX.update()){
if (buttonX.fallingEdge()){
playFile("X");
if (buttonY.update()){
if (buttonY.fallingEdge()){
playFile("Y");
if (buttonUp.update()){
if (buttonUp.fallingEdge()){
//if select is being held as hotkey, increase volume
if (digitalRead(selectPin) == LOW && vol < 1){
changeVolume(0.1);
playFile("Up");
konamiCodeCheck("Up");
if (buttonDown.update()){
if (buttonDown.fallingEdge()){
playFile("Down");
//if select is being held as hotkey, decrease volume
if (digitalRead(selectPin) == LOW && vol > 0.1){
changeVolume(-0.1);
konamiCodeCheck("Down");
if (buttonLeft.update()){
if (buttonLeft.fallingEdge()){
//if select is pressed also
if (digitalRead(selectPin) == LOW){
playSdWav2.stop();
//if it's greater than zero, increment up
if (currentIndex > 0){
currentIndex--;
//if it is zero, cycle back around to the last index
}else{
//what to do if in gameState
if (gameState){
//currentIndex = last index of gamePresets
currentIndex = numberOfGames - 1;
}else{
//currentIndex = last index of drumPresets
currentIndex = numberOfDrums - 1;
//sets the current preset with the previously set index
if (gameState) {
Serial.println(currentPreset);
}else{
currentPreset = drumPresets[currentIndex];
}else{
//do this only if select isn't pressed
konamiCodeCheck("Left");
//do this if select is pressed or not (put this with konamiCodeCheck if it should only be done without select
playFile("Left");
if (buttonRight.update()){
if (buttonRight.fallingEdge()){
playSdWav2.stop();
//if not in game state
if (!gameState) {
//notworking here?
//if not at the end of the list, index goes up
if (currentIndex < numberOfDrums - 1){
currentIndex++;
}else{
//if at the end of the list, index goes back to zero
currentIndex = 0;
//sets the drum preset
//what to do if in gamestate
}else{
if (currentIndex < numberOfGames - 1){
currentIndex++;
}else{
currentIndex = 0;
}else{
//check for konami code if select is not being pressed
konamiCodeCheck("Right");
//plays no matter what
playFile("Right");
if (buttonStart.update()){
if (buttonStart.fallingEdge()){
Serial.print("Start");
if (gameState) {
if (playSdWav2.isPlaying()){
//if in gamestate and something is already playing, stop playing
playSdWav2.stop();
}else{
//if not playing, start playing a random bgr
playRandomBgr();
konamiCodeCheck("Start");
//always happens whether successfully inputting code or not
//turns on loop if select is held
//**go back to make this work only in drum state
loopOn = !loopOn;
if (buttonSelect.update()){
if (buttonSelect.fallingEdge()){
if (buttonL.update()){
if (buttonL.fallingEdge()){
//if select is held as hotkey, decrease tempo (will increase the delay)
if (digitalRead(selectPin) == LOW && tempo > 100) {
tempo = tempo +5;
playFile("L");
if (buttonR.update()){
if (buttonR.fallingEdge()){
//if select is held as hotkey, increase tempo (will decrease the delay)
if (digitalRead(selectPin) == LOW && tempo < 1000) {
tempo = tempo -5;
playFile("R");
