Results 1 to 8 of 8
Thread: MIDI Out as also MIDI Thru?
    Jul 2016
    18
    Hi I'm following the circuit here: https://www.pjrc.com/teensy/td_libs_MIDI.html for Teensy 3.x. Many MIDI controllers and synths today use the MIDI Out port as the MIDI thru. I am trying the achieve the same thing. Using this circuit for the Teensy is it as simple as connecting the received signal from pin 6 on the 6N138 to Pin 5 on the MIDI Out DIN?
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,402
    I think you need to add some buffer (e.g. feed both sides of an AND gate or back-to-back NOT gates).
    A merge out should be feasible but I don't do serial MIDI much and can't recall how easy it really is.
    Jul 2020
    964
    The way "thru" works in such devices is using software I think, since the use of the output port has to be shared
    between local output packets and "thru" packets without mangling either. I think its common to be able to
    reconfigure MIDI channels for the "thru" packets too in such a setup so as to be able to prevent channel clashes.
    You can't get away with simply combining two MIDI streams at a low level, garbled packets will be very bad news,
    leaving notes stuck on and all sorts of mayhem.
    Feb 2013
    1,402
    Yes, merge must be done in software but 'thru' ports can just buffer the input signal. It's to allow a master controller daisy chain sound moduals.
    I was responding to the idea you could drive the port without a buffer but I didn't notice they mean to have a 'merge' output not a 'thru.'
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    156
    The MIDI library does a THRU from input to the output by default. You have to shut it off if not needed, or attach the function to a switch or soft control.
    Jul 2016
    18
    Quote Originally Posted by ETMoody3 View Post
    Oh wow I did not know this. Thanks for this info! Is there anywhere this explains this in more detail? I may want to have the option to disable this feature if it causes issues.
    Mar 2014
    New Ulm, Mn
    156
    https://fortyseveneffects.github.io/...ry/a00039.html
    Here's the documentation.
    Read the whole thing...you'll thank yourself later.
    Jul 2016
    18
    Awesome thanks!
