Results 1 to 3 of 3
Thread: Question about SPI chip select timing.
    Oct 2020
    14
    I am testing SPI with the teensy 4.1 with the goal of using the DAC7554 with it. I have not actually hooked them up together yet, as I have just been investigating the SPI signals from the Teensy. I noticed the fall time of the chip select seemed really slow compared to the clock and data, to the point where I would be surprised if it worked. I tried connecting to other pins and just pulling them low, and they all respond this way, even the pins that are currently sending clock and data.
    Here is the script I am using, as well as an image from the oscilloscope.
    int value1 = 0x8026;
    int value2 = 0x0801;
    int value3 = 0x8027;
    int value4 = 0x0000;
    void setup (void)
      Serial.begin (9600);
      Serial.println ("Starting");
      digitalWrite(SS, HIGH);  // ensure SS stays high for now
      // Put SCK, MOSI, SS pins into output mode
      // also put SCK, MOSI into LOW state, and SS into HIGH state.
      // Then put SPI hardware into Master mode and turn SPI on
      SPI.begin ();
      // Slow down the master a bit
      SPI.setClockDivider(SPI_CLOCK_DIV8);
    }  // end of setup
    void loop (void)
      // enable Slave Select
      digitalWrite(SS, LOW);
      SPI.transfer (1);   // initiate transmission
      SPI.transfer (11);
      SPI.transfer (22);
      SPI.transfer (33);
      SPI.transfer (44);
      // disable Slave Select
    delay (1);
    Jul 2020
    964
    Set pin SS as an output - the Teensy SPI lib doesn't do this for you. Look under "Basic Usage" here:
    https://www.pjrc.com/teensy/td_libs_SPI.html
    Oct 2020
    14
    Thank you! I actually figured this out by using a different example. I should have waited just a bit longer before posting. I got the teensy working with the dac as well and it even works up to 50mhz spi clock. That means it can update all 4 channels at 200khz 12bit resolution! And JLCPCB has tons of them.
