Reading from SPI
MarkTed
New member
Hey, I'm having trouble reading from the SPI1 port of the teensy 4.1. I am able to write using the SPI1 port, and the data I am trying to read is present on the MISO1 pin (41) of the teensy when I use an oscilloscope, but I am unable to read that data into a variable in my code for some reason.
void PLLSend(int regData, int chipNum)
  int byte1;
  int byte2;
  int byte3;
  byte byte4;
  byte byte5;
  byte byte6;
  byte1 = regData / 65536;
  byte2 = regData % 65536;
  byte3 = byte2 % 256;
  byte2 = byte2 / 256;
  switch (chipNum)
    case 1:
      digitalWrite(30, LOW);
      digitalWrite(29, LOW);
      digitalWrite(28, LOW);
      //delayMicroseconds(2);
    case 2:
      digitalWrite(28, HIGH);
      delayMicroseconds(1);
    case 3:
      digitalWrite(29, HIGH);
    case 4:
    case 5:
      digitalWrite(30, HIGH);
    case 6:
    case 7:
    case 8:
  SPI1.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE0));
  digitalWrite(40, HIGH);
  byte4 = SPI1.transfer(byte1);
  byte5 = SPI1.transfer(byte2);
  byte6 = SPI1.transfer(byte3);
  digitalWrite(40, LOW); //Deselecting Chip
  SPI1.endTransaction();
  //Serial.print(byte4);
  //Serial.print(byte5);
  //Serial.print(byte6);
The first section is used for splitting the 24 bit data being passed into three 8 bit chunks that I can send with "SPI1.transfer". The switch statement is for setting the CS spin for one of 8 chips using a 3 to 8 arbiter chip. The very last section is my SPI code which should work as far as I'm aware, but I get noting using the "Serial.print" functions. It just shows me that data being read is all zeros.
Any help would be appreciated. Thank you!
Thank you for the fast response! I'm not completely sure where my pin 41 assumption came from, but I have edited the hardware to match the proper pin assignments and still have the same issue.
