BJTs are typically slower than MOSFETs if the MOSFET is driven with enough current - however a
large MOSFET can have a lot of capacitance and need quite high currents to switch fast - so it
very much depends on the ratings of the MOSFET and the current available to drive it.
A small MOSFET for low current will typically be faster than a switching BJT in fact.
With a BJT don't expect to be able to switch more than 20 times the base current. So if your
teensy pin is rated at only 4mA, you'll not be able to switch more than 80mA with a single BJT.
You didn't actually say what "the signal is low current" actually means - "low current" means
_very_ different things in different contexts - use numbers and units, not adjectives. After all
every motor ever sold is "high torque" in the sales literature!
Yes a base-resistor is mandatory and needs to limit the current to protect both the Teensy and
the BJT itself - a Teensy 4.1 is much more delicate than most single BJTs in fact, and will
determine the minimum value of base resistor its safe to use.
