Results 1 to 8 of 8
Thread: The Guild of Thieves on a Teensy 4.0
    Mar 2021
    8
    https://www.dettus.net/dMagnetic/teensy/guild001.elf
    Hello Guys!
    I just ported "The Guild of Thieves" to the Teensy 4.0
    Want to give it a try?
    Quote Originally Posted by dettus View Post
    Hello Guys!
    Thanks for the offer, gladly!
    Mar 2021
    8
    Quote Originally Posted by billfisher View Post
    Haha.
    If you want to change the graphics mode, just fire up a hex editor and look for the Faux Commandline within the .elf -File. It starts at 0x7541C.
    You can use it like a real commandline, however, make sure it ends with a 0x00.
    For the commandline options, just have a look into the instruction manual: http://www.dettus.net/dMagnetic/dMagnetic_030.pdf
    Mar 2021
    8
    Aaand here is a new screenshot with the monochrome Mode
    Jan 2021
    7
    love to try this as well, what sort of terminal emulator do you need for windows and how do you get it to actually run?
    Mar 2021
    8
    In theory, I would say "putty is a good terminal emulator under Windows", but for some reason it keeps me stuck at the "Please press Enter" message...
    However, the connection should be set to 115200,8N1, No flow control.
    Anyhow, under Linux, the command for uploading the .elf to the teensy is
    $ARDUINOPATH/hardware/tools/arm/bin/arm-none-eabi-objcopy -O ihex -R $ARDUINOPATH/.eeprom guild001.elf guild001.hex
    $ARDUINOPATH/hardware/tools/teensy_post_compile -file=guild001 -path=`pwd` -tools=$ARDUINOPATH/hardware/tools
    $ARDUINOPATH/hardware/tools/teensy_reboot
    and to play the game
    % sudo apt install cu
    % cu -l /dev/ttyACM0 -s 115200 --no-stop
    Jan 2021
    7
    lol - I'm a windows guy, and was getting stuck at the same place even with the same connection details. Thanks for trying!
    26,563
    Just to confirm (I'm not familiar with Guild of Thieves) the output is ASCII graphic sent over USB serial, right?
